Full Version: LibreELEC Testbuilds for RaspberryPi (Kodi 17.0)
(2016-07-18, 23:16)popcornmix Wrote: [ -> ]
(2016-07-18, 22:46)asavah Wrote: [ -> ]PS just checked on a pretty old master build I have on ubuntu x86_64 (034aa80) the issue is there.
So it looks like it's a core issue and not pi specific.
I can not provide access to the stream(s) because the access is limited to my ISP's internal network.
Best to report this in the OS independent forum. Include a debug log (wiki) from a recent Ubuntu build where hopefully the right dev (FernetMenta) will see,
Will do as soon as I get a little free time, probably on the weekend,
I'd need to build the fresh master and find a publicly available live stream with multiple languages to provide as example.
(2016-07-18, 23:35)nickrob84 Wrote: [ -> ]
(2016-07-18, 20:42)Milhouse Wrote: [ -> ]
(2016-07-18, 19:43)nickrob84 Wrote: [ -> ]The weather info on homescreen issue isn't a addon problem. Uninstalled met office and installed yahoo and still same issue. What sort od log would be of use?
The usual, debug log (wiki).
http://pastebin.com/raw/dWGb7bTs
http://pastebin.com/raw/A1im5U4E
Couple of recent ones on the latest build where I have reloaded met office addon and tried to change the setting to show on home screen. I think anyway.
Neither of your logs is a debug log so there's nothing useful there. One of your logs has this error several times, but I don't know what it applies to as it's not a debug log:
21:34:20 36212.531250 T:1961873408 ERROR: Control 55 in window 10025 has been asked to focus, but it can't
Enable debugging, restart Kodi (so that debugging is enabled from the start) then reproduce the problem and finally upload only kodi.log to a pastebin site.
You reported this issue with #0715, I asked you to confirm if it worked with #0714 but haven't seen your reply. Identify the last working build and maybe we can focus on a particular change. Alternatively contact the Weather add-on maintainers.
I don't know what changed but the met office weather information is now showing on the home screen for the first time since 0714! Probably user error. Let's see if it stays.
@Milhouse
This is my log concerning my thread on libreelec-forum https://forum.libreelec.tv/thread-956.html
-> https://paste.ee/p/Syjbf
As I wrote the streams I get from plugin.video.southpark_unofficial and plugin://plugin.video.rocketbeanstvlive were played fluently from the beginning in Libreelec Alpha 002. So I suspect changes in Videoplayer.
(2016-07-18, 16:11)smp1 Wrote: [ -> ]I noticed an issue in recent builds when testing the 1080i content. When I try to play the same file a few times in a row - it will eventually fail to play until I reboot the RPi.
How to reproduce: play the file for 3 seconds, press Stop. Repeat until it fails.
This should be fixed in the upcoming build tonight.
0719 is out now, weather info gone again.
New LibreELEC.tv Krypton build #0719: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.7.0-rc7 #1 Tue Jul 19 21:07:00 BST 2016 armv6l GNU/Linux
# vcgencmd version
Jul 15 2016 17:54:00
Copyright (c) 2012 Broadcom
version efa728fef77ea14ceb1500caf0146395fa282a0f (clean) (release)
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160719210519-#0719-g4af5a0e [Build #0719]
# vcdbg log msg 2>&1 | grep DTOK
002392.948: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of LibreELEC.tv master (4af5a0e1, changelog) and tip of XBMC master (bd911cc5, changelog) with the following modifications:
  • Includes newclock5 patches
  • Excludes the LibreELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.7.y
  • Includes latest bcm2835-driver master (051aed71, ahead +8)
  • Includes latest kodi-platform master (c8188d82)
  • Includes latest libcec master (6d68d212)
  • Includes latest libnfs master (fac3a954, ahead +34)
  • Includes latest p8-platform master (041a8c6c, ahead +1)
  • Includes latest addons: inputstream.mpd (aad30ba0, +13), inputstream.rtmp (7bf2298e), inputstream.smoothstream (31e7afef, +3), peripheral.joystick (6090a90e, +1), pvr.argustv (e536f32e), pvr.demo (01c68c88), pvr.dvblink (0bf16840, +1), pvr.dvbviewer (35902f5d), pvr.filmon (efd379b8), pvr.hdhomerun (a71e816d), pvr.hts (856e72a4, +1), pvr.iptvsimple (1ea1f36e), pvr.mediaportal.tvserver (3ba23b7b, +1), pvr.mythtv (1bcf081a, +5), pvr.nextpvr (ecbd6e5c, +1), pvr.njoy (b5d65655), pvr.pctv (12d8baf1), pvr.stalker (4e9b11c8, +5), pvr.vbox (36d3717b, +1), pvr.vdr.vnsi (d7bc89eb, +5), pvr.vuplus (d7f5685a, +1), pvr.wmc (1f3240da, +1)
  • Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
  • Include [env] ed774729: Intel: Implement Passthrough-Range
  • Include [env] 98c65e6a: Kodi: Use Limited Range by default
  • Include [env] patch: Add kodi binary addons (pvr, adsp, other)
  • Include [env] patch: Don't build ADSP addons
  • Include [env] patch: Bump included addon versions to prevent online updates
  • Include [env] patch: Install libbrcmEGL/libbrcmGLESv2 shared libraries, with sym links for backward compatability
  • Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
  • Include [env] patch: Add experimental splash video for RPi
  • Include [env] patch: ffmpeg: bump 3.1.1
  • Include [env] PR:481: linux: Update to 4.7 (WIP)
  • Include [env] PR:526: Cpu temperature readings for devices with aml_thermal interface
  • Include [env] PR:535: init: Add upgrade check to avoid incompatible upgrades [RFC,WIP]
  • Include [env] PR:546: systemd: Do not unmount /storage and /flash at shutdown as this always fails
  • Include [env] PR:548: connman: bump to 1.33
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
  • Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
  • Include [pkg] PR:10141: set tvshow thumb on *all seasons node
Build Highlights:
  1. connman: bump to 1.33
  2. ffmpeg/mmal updates
Build Details:
  1. LibreELEC.tv:
    • lcdproc: do not use freetype from host (PR:549, 1 commit, 1 file changed)
  2. XBMC:
    • [cmake/linux] Code coverage (PR:10095, 5 commits, 8 files changed)
    • Add new option installed to Addons.GetAddons to allow listing of addo… (PR:10140, 1 commit, 4 files changed)
    • [addons] reinstate multidir repositories. partially reverts eec2e0aba… (PR:10135, 1 commit, 2 files changed)
    • [listprovider] respect select action setting (PR:10126, 1 commit, 1 file changed)
    • Fix retrieve all the information before update (PR:10142, 1 commit, 2 files changed)
    • FIX: HEADSET_PLUG broadcast intent is code-only (PR:10138, 1 commit, 2 files changed)
  3. newclock5:
    • New commits in this build:
      • mmalffmpeg: Enable thread safe callbacks (503eaeb5)
      • mmal: Switch to a pool class attached to decoder output (0cf9bc86)
      • mmal: Fix some ugliness with acquire/release of video buffers (4ab31392)
      • mmalrender: Add sharpness control (5eb4c1fa)
    • Updated commits in this build:
    • Commits no longer in build:
      • mmalrender: Improve logging for pool creation (4e779a84)
      • mmal: Include state in CMMALBuffer (a363551f)
      • mmalrender: Use flag in omvb structure for detecting submitted pictures (8747f5b4)
      • mmalffmpeg: Move gpu image pool into a separate class (3aa899f1)
      • mmalrender: Reduce number of opaque pool elements (cfb55278)
      • mmal: Move decoded picture pool from renderer to decoder (01a402e1)
      • mmal: Include buffer encoding in buffer objects (e235de05)
      • mmalrender: Configure mmal lazily as packets are received (22aea872)
      • mmalrender: More verbose logging (c491a198)
      • mmalrender: Add pts of frame to log (1e725e4b)
      • [mmalrenderer] Add sharpness control (b070fea5)
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] PR:548: connman: bump to 1.33
    • Added: [pkg] PR:10141: set tvshow thumb on *all seasons node
(2016-07-19, 23:25)nickrob84 Wrote: [ -> ]0719 is out now, weather info gone again.
Yahoo weather still works for me. Are you using something different?
Bill
Seems to me it works one day, not the next - sounds very much like an addon/network/remote server issue. Without a debug log or evidence of any actual error there's nothing to investigate.
In 0719 there is an issue with HEVC playback. If you use "skip forward" button to jump from one HEVC file to another - there is a lot of video corruption and RPi could lock up (will require a hard reset).
@popcornmix maybe my post #1444 is also relevant to you as I see, I don't know the experts.
Without other changes on my system, I suddenly got described problems with these streams when I updated to LibreELEC Alpha 003 (or milhouse builds over the last weeks), 002 was fine.
Maybe the problem lies in changes in Videoplayer. Please have a look.
(2016-07-20, 04:10)marriol123343 Wrote: [ -> ]Without other changes on my system, I suddenly got described problems with these streams when I updated to LibreELEC Alpha 003 (or milhouse builds over the last weeks), 002 was fine.
Unfortunately the south park add-on doesn't work in the UK (geo-blocked).
If any other sources that I can play show this problem I could look into it.
Otherwise if you can identify the first Milhouse nightly build with the problem, that would help narrow it down.
I found that the irrecord in lirc 0.9.4 does not work properly. I could not get it to terminate and write the .conf file, it would not respond to the final "return".
I used an earlier LE with lirc 0.9.1 it worked perfectly.
I wonder if the even newer lirc 0.9.4a would work?
(2016-07-20, 14:31)donbrew Wrote: [ -> ]I found that the irrecord in lirc 0.9.4 does not work properly. I could not get it to terminate and write the .conf file, it would not respond to the final "return".
Could you post some more details? What kind of IR receiver and remote are you using? How did you start irrecord? What did irrecord show at the start (you should see something like "Using driver default on device /dev/lirc0")?
I've just tested with build 0719 on a RPi1, recorded some 20 keys of my Hauppauge remote using lirc_rpi and it worked fine. irrecord started with "irrecord --device /dev/lirc0 --driver default"
so long,
Hias
@HiassofT @Milhouse
Lirc 0.9.4a is out, you may want to update the package Tongue
