I recently updated my LibreELEC-Generic.x86_64-8.0-Milhouse build from build #0416 to #0424 and I used the '.tar' file.
But I just read on
https://libreelec.tv/download-temp/ it says
New Install and Manual Update for LibreELEC (.img.gz)
So did I use the wrong file to update? it seems to have worked ok.
(2016-04-27, 22:27)parker.hugh Wrote: [ -> ]I recently updated my LibreELEC-Generic.x86_64-8.0-Milhouse build from build #0416 to #0424 and I used the '.tar' file.
But I just read on https://libreelec.tv/download-temp/ it says New Install and Manual Update for LibreELEC (.img.gz)
No, you did it right. You used the automatic update option. The .img file is for clean install or doing a manual upgrade. So you are all good!
(2016-04-27, 20:20)Roby77 Wrote: [ -> ]On n3150 i reverted back to 420 cause 423 and 424 freeze often on gui (kodi alive cause ssh query works)
I can't also be able to load edid at startup using libreelec
I will post a log asap (regarding screen freeze)
Yes , 423 and 424 freeze and crash frequently on my n3700 as well .
Crash log :
http://sprunge.us/eVZU
(2016-04-27, 22:52)lleon596 Wrote: [ -> ] (2016-04-27, 20:20)Roby77 Wrote: [ -> ]On n3150 i reverted back to 420 cause 423 and 424 freeze often on gui (kodi alive cause ssh query works)
Crash log : http://sprunge.us/eVZU
Please remove qazar and retry.
(2016-04-27, 20:20)Roby77 Wrote: [ -> ]I can't also be able to load edid at startup using libreelec
I have this same issue
Let me know if/which logs are required
(2016-04-27, 21:32)gjwAudio Wrote: [ -> ]c) are you aware of any video test-files that can be used to determine the offset(s) needed for a users particular setup ?
This test pattern is from Spears & Munsil HD Benchmark and is for 23.976 frame rate. You can test Dolby Digital/Dolby Digital TrueHD/DTS-HD Master Audio. First two tracks play from center channel, the other two play front L & R -
AV-Sync test pattern. The beep tone is supposed to start in the middle of video frame "0" (after 20ms).
same here on my N3700....
HI,
where can i find a working Amazon Prime Addon?
Here we go
Upgraded again from 0420 to 0424 and freeze / crash after 2/3 minuts
Log:
http://sprunge.us/YEbi this after kodi gui freeze
kodi freeze>crash>restart>video corrupt>black screen
This after all
Log:
http://sprunge.us/CbCU
Quote:[ 79.338717] [drm] stuck on render ring
[ 79.344813] [drm] GPU HANG: ecode 8:0:0xfffffffe, in kodi.bin [587], reason: Ring hung, action: reset
[ 79.344817] [drm] GPU hangs can indicate a bug anywhere in the entire gfx stack, including userspace.
[ 79.344819] [drm] Please file a _new_ bug report on bugs.freedesktop.org against DRI -> DRM/Intel
[ 79.344821] [drm] drm/i915 developers can then reassign to the right component if it's not a kernel issue.
[ 79.344823] [drm] The gpu crash dump is required to analyze gpu hangs, so please always attach it.
[ 79.344825] [drm] GPU crash dump saved to /sys/class/drm/card0/error
^^ Do this please and file this bugreport. It's a kernel regression.
