(2016-09-16, 08:11)alxtr1bal Wrote: [ -> ]And here is the kodi.log, with #0914 , rx 460 disabled.
HDMI->AVR->Monitor
http://sprunge.us/DMQU
Yeah - retry it in 1080p mode, please. 4k@60 might need some driver changes via HDMI 2.0. Btw. all these findings should be tracked on bugs.freedesktop.org the AMD guys are really fast in fixing stuff after they are aware.
Switch to Estuary skin, please.
You can post the kodi.log from the version you procude this screenshot? That looks not what should happen :-)
Quote:14:25:22 19.869953 T:139769230723136 NOTICE: Enumerated ALSA devices:
14:25:22 19.870098 T:139769230723136 NOTICE: Device 1
14:25:22 19.870855 T:139769230723136 NOTICE: m_deviceName : default
14:25:22 19.870960 T:139769230723136 NOTICE: m_displayName : Default (IntelHDMI IntelHDMI)
14:25:22 19.871050 T:139769230723136 NOTICE: m_displayNameExtra:
14:25:22 19.871140 T:139769230723136 NOTICE: m_deviceType : AE_DEVTYPE_PCM
14:25:22 19.871223 T:139769230723136 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR
14:25:22 19.871313 T:139769230723136 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
14:25:22 19.871401 T:139769230723136 NOTICE: m_dataFormats : AE_FMT_S24NE4
14:25:22 19.871489 T:139769230723136 NOTICE: m_streamTypes : No passthrough capabilities
PT on that hardware never worked and won't likely work as it only supports AE_FMT_S24NE4 output format natively. Btw. that you even have audio at all just works as milhouse picks WIP patches nowhere near mainline.
fritsch thanks for explanation of the problem.
(2016-09-16, 21:11)fritsch Wrote: [ -> ]Cherio Miss Sophie!
Cherio ''Mr vw cheating software''
external usb sound card ordrered.
I am having a problem trying to get xrandr working with my rx460 GPU, is it likely that the new driver will address that issue or is there another underlying problem?
Here is a dmesg log with both monitors connected
http://sprunge.us/PJhf
By the way I can't thank you enough for all your help debugging my problems
(2016-09-16, 23:17)madmarkym Wrote: [ -> ]I am having a problem trying to get xrandr working with my rx460 GPU, is it likely that the new driver will address that issue or is there another underlying problem?
fritsch probably has some idea about xrandr (although as he's at Kodi DevCon, hopefully he's getting some r'n'r). Thank you for persevering while we got your card to work, still need to find a better solution that doesn't require users to create a custom xorg.conf.
A bit delayed with the builds tonight, but should have a build up soon - fingers crossed it hasn't broken anything...
_Spook_ - haven't forgotten, your builds are next on the list...
New LibreELEC.tv Krypton build #0916:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.7.4 #1 SMP Fri Sep 16 23:54:39 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160916235324-#0916-gb094ddc [Build #0916]
Based on tip of
LibreELEC.tv master (b094ddc0,
changelog) and tip of
XBMC master (20ae66d1,
- Includes FernetMenta "VideoPlayer" patches
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (62b8520c, ahead +15)
- Includes latest libnfs master (fac3a954, ahead +34)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (2c8ffc7b, +11), inputstream.rtmp (91bb3741, +5), inputstream.smoothstream (081c6c43, +2), peripheral.joystick (263aa849, +34), pvr.argustv (299088b5), pvr.demo (01c68c88), pvr.dvblink (ea3d98cc), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (48b2e261), pvr.iptvsimple (a4c52558), pvr.mediaportal.tvserver (3c39bd0c, +7), pvr.mythtv (b1b426f3), pvr.nextpvr (4dabcf41), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (7df63b24, +12), pvr.vbox (2750c92a), pvr.vdr.vnsi (da5fdd5a, +1), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Includes commits from xbmc/master, ahead +2 (FernetMenta)
- Exclude [env] kodi-999.11-fix-aarch64-compile.patch: Merged upstream
- Exclude [env] kodi-999.99-PR10309.patch: Merged upstream
- Exclude [env] kodi-999.99-Revert-PR10247.patch: Not required
- Exclude [env] libcec-PR208.patch: Merged upstream
- Include [env] 868099f1: linux: Enable ChromeOS laptop hardware support
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: ffmpeg: Bump to 3.1.3-Krypton-Beta3 (e9002c3)
- Include [env] patch: kodi: Fix addon wrapper after PR:10335
- Include [env] patch: linux: Enable DRM_AMD_POWERPLAY (power management), DRM_AMDGPU_CIK (pre-Polaris support) and DRM_AMD_ACP (audio co-pro)
- Include [env] PR:738: scripts/mkimage: Add run mode, remember default selection, resize gpt partitions
- Include [env] PR:739: linux-firmware build system rework
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: drm/i915: Fixes and diagnostics for Braswell (linux)
- Include [pkg] patch: peripheral.joystick: Disable udev and see if stability improves (peripheral.joystick)
- Include [pkg] patch: drm/i915: Fix backwards test in Chris Wilson patch (link) (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] patch: drm/i915: Limit the depth of the display pipeline to the framebuffer (linux)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
- Include [pkg] PR:10445: require click action to activate slider controls
Build Highlights:
- Drop mesa 12.1.0-devel, revert back to v12.0.3
- Drop libdrm 2d00869, revert to v2.4.70
- Drop xf86-video-amdgpu 6a1ba04, revert to v1.1.1
Build Details:
- LibreELEC.tv:
- Package updates: xf86-video-amdgpu 1.1.1, xf86-video-ati 7.7.1 (PR:741, 2 commits, 2 files changed)
- xf86-video-amdgpu: update to 1.1.1
- xf86-video-ati: update to 7.7.1
- change gnu.org download location (PR:733, 1 commit, 23 files changed)
- Use interactive CPU scaling governor for all WeTek projects (PR:740, 3 commits, 6 files changed)
- XBMC:
- [win32][fix] Add app manifest to the build to mark us as dpi aware (PR:10468, 1 commit, 2 files changed)
- [win32] Update appxmanifest and add banner.png (PR:10469, 1 commit, 2 files changed)
- AE: fix mem leak in tempo filter (PR:10471, 1 commit, 1 file changed)
- [Estuary][PVR] Handle visibility of PVR home screen entries like the other home screen entries. (PR:10472, 2 commits, 5 files changed)
- inputstream.mpd:
- Added: [env] PR:739: linux-firmware build system rework
- Updated: [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
(2016-09-17, 01:30)Milhouse Wrote: [ -> ]New LibreELEC.tv Krypton build #0916: Generic
# uname -a
# lsb_release
Based on tip of LibreELEC.tv master (b094ddc0, changelog) and tip of XBMC master (20ae66d1, changelog) with the following modifications:- Includes FernetMenta "VideoPlayer" patches
Build Highlights:
Build Details:
- LibreELEC.tv:
- XBMC:
- inputstream.mpd:
Everything is still is running as before no problems to report
(2016-09-17, 02:59)madmarkym Wrote: [ -> ]Everything is still is running as before no problems to report
Thanks for the confirmation!
