(2016-09-17, 12:02)fritsch Wrote: [ -> ]Not so sure - you have audio, but dts-hd, truehd is missing if I got that right which is a big difference.
So what happens in 1080p60 same issue?
Actually, if i use the RX460 HDMI 2 port, i have no sound at all ... so the link is related.
If i use the mother board HDMI, i have no sound for DTS HD MA and Dolby True HD (but only if i activate the RX460 : that means video = rx460, audio = motherboard hdmi.)
New LibreELEC.tv Krypton build #0917:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.7.4 #1 SMP Sat Sep 17 21:25:04 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160917212349-#0917-g082a8ea [Build #0917]
Based on tip of
LibreELEC.tv master (082a8ead,
changelog) and tip of
XBMC master (c6a62cfa,
- Includes FernetMenta "VideoPlayer" patches
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (62b8520c, ahead +15)
- Includes latest libnfs master (fac3a954, ahead +34)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (2c8ffc7b), inputstream.rtmp (91bb3741), inputstream.smoothstream (081c6c43), peripheral.joystick (263aa849), pvr.argustv (299088b5), pvr.demo (01c68c88), pvr.dvblink (ea3d98cc), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (48b2e261), pvr.iptvsimple (a4c52558), pvr.mediaportal.tvserver (42c91b1c), pvr.mythtv (b1b426f3), pvr.nextpvr (4dabcf41), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (7df63b24), pvr.vbox (2750c92a), pvr.vdr.vnsi (da5fdd5a), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Includes commits from xbmc/master, ahead +2 (FernetMenta)
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] PR:738: scripts/mkimage: Add run mode, remember default selection, resize gpt partitions
- Include [env] PR:739: linux-firmware build system rework
- Include [env] PR:746: kodi: update to 17.0-beta2-6e9d6fb
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: drm/i915: Fixes and diagnostics for Braswell (linux)
- Include [pkg] patch: peripheral.joystick: Disable udev and see if stability improves (peripheral.joystick)
- Include [pkg] patch: drm/i915: Fix backwards test in Chris Wilson patch (link) (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] patch: drm/i915: Limit the depth of the display pipeline to the framebuffer (linux)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
- Include [pkg] PR:10445: require click action to activate slider controls
Build Highlights:
- Start of Kodi 17.0 beta3 cycle
Build Details:
- LibreELEC.tv:
- projects/Odroid_C2: Revert HK Audio & enable multichannel PCM & HD passthrough (PR:742, 1 commit, 7 files changed)
- linux: Enable support for new hardware (AMD GPUs, Chromeboox) (PR:743, 2 commits, 2 files changed)
- Imx6 updates (PR:745, 3 commits, 3 files changed)
- XBMC:
- bump to 17.0 beta 3 (PR:10349, 1 commit, 2 files changed)
- Revert "bump to 17.0 beta 3" (PR:10474, 1 commit, 2 files changed)
- AE-Fixes (PR:10477, 2 commits, 2 files changed)
- maybe fix android crash after #10335 (PR:10476, 1 commit, 2 files changed)
- [contextmenu] remove incorrect log message (PR:10475, 1 commit, 1 file changed)
- [Estuary] Misc stuff (PR:10470, 2 commits, 5 files changed)
- bump to 17.0 beta 3 (PR:10478, 1 commit, 2 files changed)
- pvr.mediaportal.tvserver:
- Oops... forgot to update the addon version to 2.4.5 (42c91b1c)
- Added: [env] PR:746: kodi: update to 17.0-beta2-6e9d6fb
Hello there,
thanks for all your work!
I have a problem with the wlan functionality on my Asrock Beebox N3150. I can see the network with it's SSID, when trying to connect I get the message "Network error. Invalid arguments". Changing passwords and completly removing password protection did not help. Seems to be driver related maybe. Any ideas?
Best regards
Brainex
Hi Milhouse,
fyi:
build #0912c
you remember, starts my Zotac Box ci520 with IR
Zotac ZBox ci50 Intel Core i3 4020Y, 1,5GHz, Intel HD 4200
There is a little stuttering in videoplayback. I remember someone post this.
#0913y
#0917l
no audio on my device, but on my Zboxci321 Intel haswell Celeron 2961Y
both work perfect, audio and video.....
(2016-09-18, 11:48)Brainex Wrote: [ -> ]Hello there,
Best regards
Brainex
Not really. Does it work with LibreELEC 7.0.2 or LibreELEC 7.90.005?
there are here some people wth devices based on z8300 or i3735z with bios UEFI32bit ??
Im prepared some build for test - let me know ...
Good news everybody. I tested one of the 4.8-builds, and the power on issue seems to be resolved, so now there's nothing standing in the way of progress!
Milhouse I am not sure if you can help me with this or I if I need to revert to openmediaelec which I used successfully previously.
I am trying to configure my gyration remote with Lirc using this guide
http://kodi.wiki/view/How-to:Gyration_US...using_Lirc
The problem I am having is there is no etc/rc.local file or /etc/lirc/lircd.conf and that folder is locked.
Instead of ~usernamerunningxbmc/.xbmc/userdata/Keymap.xml I am using /storage/.kodi/userdate/keymaps/gem.xml (this was generate by the keymap, so I thought it best to use this file.
And instead of this file ~usernamerunningxbmc/.xbmc/userdata/Lircmap.xml, I create /storage/.kodi/userdate/keymaps/Lircmap.xml.
Do you have any ideas how I can resolve this?
Thanks again for your time.
New LibreELEC.tv Krypton build #0918:
Generic
# uname -a
Linux NUC 4.7.4 #1 SMP Sun Sep 18 21:06:02 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160918210447-#0918-g88a20f0 [Build #0918]
Based on tip of
LibreELEC.tv master (88a20f0b,
XBMC master (3f23348b,
- Includes latest addons: inputstream.mpd (2c8ffc7b), inputstream.rtmp (91bb3741), inputstream.smoothstream (081c6c43), peripheral.joystick (263aa849), pvr.argustv (299088b5), pvr.demo (01c68c88), pvr.dvblink (ea3d98cc), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (48b2e261), pvr.iptvsimple (a4c52558), pvr.mediaportal.tvserver (42c91b1c), pvr.mythtv (b1b426f3), pvr.nextpvr (4dabcf41), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7, +4), pvr.vbox (2750c92a), pvr.vdr.vnsi (da5fdd5a), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Include [env] patch: RPi2: Enable CONFIG_KERNEL_MODE_NEON
Build Highlights:
- Minors
Build Details:
- LibreELEC.tv:
- kodi: update to 17.0-beta2-6e9d6fb (PR:746, 8 commits, 19 files changed)
- XBMC:
- [osx] - fix sse flags when using autoconf/xcode (PR:10473, 2 commits, 2 files changed)
- Fix "Custom" view mode not showing in view mode list (PR:10481, 1 commit, 1 file changed)
- add Pull request template (PR:10379, 1 commit, 1 file changed)
- [estuary] avoid hyphens in front of temperatures (PR:10487, 1 commit, 2 files changed)
- [PVR] Fix PVR not working after using kodi login screen (trac#16813) (PR:10480, 3 commits, 16 files changed)
- [settings] make skin settings button more obvious (PR:10252, 1 commit, 2 files changed)
- [docs] add Pull request template (df6e9d76)
- pvr.stalker:
- Fix crash (PR:75, 4 commits, 48 files changed)
- Added: [env] patch: RPi2: Enable CONFIG_KERNEL_MODE_NEON
(2016-09-18, 23:42)madmarkym Wrote: [ -> ]@Milhouse I am not sure if you can help me with this or I if I need to revert to openmediaelec which I used successfully previously.
Sorry, not a lirc expert by any stretch of the imagination. Presumably this is a "general" LibreELEC issue (same problem in 7.0.2?) in which case please ask on the LibreELEC forum for support. I need to restrict this thread to issues directly related to these builds, rather than try to solve every problem - hope you understand.
What I can say is that the equivalent of the /etc/rc.local file in LibreELEC is your /storage/.config/autostart.sh file. Not sure about /etc/lirc/lircd.conf, but someone on the LibreELEC team will know.
Use /storage/.config/lircd.conf
But please use the LibreELEC forum for further questions.
Milhouse,
The last 3 update builds do not boot on my Samsung chromebox,
What has changed from 3 builds ago ?
The last build that works for me is from 0909.
Thank you.
(2016-09-18, 12:32)Superbert Wrote: [ -> ]Hi Milhouse,
fyi:
build #0912c
#0913y
#0917l
I know it sounds crazy.
I tried with "adjust refreshrate off". It works perfekt. I tested #0917l.
Powering my boxes off and later on, i wondered: no audio again. Refreshrate off.
Now I flashed #0917m.
Atm everythings works.
