Audio sync issues with Video set to change refresh rate on start/stop and passthrough audio enabled.
This is on 2 different HTPCs, one AMD APU and one NVIDIA GTX + AMD, one Asrock one MSI board.
I can set audio ahead/behind but it doesn't stay the same for different container types, ie. mkv/mp4/avi etc, or different qualities.
I can set to sync with display for video and ofc passthrough disabled and all is ok.
This is 2 different TVs, on 4k LG on Sharp Aquos.
Thanks for builds, very much appreciated! 8)
badaas is this a recent problem, which build did this start with?
(2016-10-08, 14:44)Milhouse Wrote: [ -> ]@badaas is this a recent problem, which build did this start with?
Sorry, latest build.
The previous build I could set on 4k tv to ahead by 200ms and it seemed to work across all formats [passthrough to tv to optical soundbar - this works fine for all other devices/tv/apps].
I noticed it worse last night on Aquos [AMD APU 5350 + MSI], I couldnt set sync across formats on passthrough + set tv to refresh rate.
I can't see if it is in previous builds past the last 2 as only just started using this libreelec OS.
I know on windows kodi 17 latest beta's all has been ok on both HTPCs.
Media is stored on a hardwired NAS and database is SQL on the same NAS, never had issues [not sure that relevant but just in case!]
(2016-10-07, 00:00)Milhouse Wrote: [ -> ] (2016-10-06, 18:44)wookl Wrote: [ -> ]How does one reenable long press?
Are you saying there's a problem with longpress? Please describe in more detail...
I am using a fire tv bluetooth remote with a nuc5c, when I press the "enter" button I start to play a movie. It used to be so that when I long-pressed the "enter" button the context menu would come up, but when I try to hold the "enter" button it is doing repeat presses of play instead of a long press.
(2016-10-08, 22:08)wookl Wrote: [ -> ] (2016-10-07, 00:00)Milhouse Wrote: [ -> ] (2016-10-06, 18:44)wookl Wrote: [ -> ]How does one reenable long press?
Identify the build that introduced the change of behaviour. Assuming this is intentional then you'll need to create a custom remote.xml that includes your longpress.
New LibreELEC.tv Krypton build #1008:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.8.0 #1 SMP Sat Oct 8 21:07:12 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161008210557-#1008-g5d0b534 [Build #1008]
Based on tip of
LibreELEC.tv master (5d0b5347,
changelog) and tip of
XBMC master (2379b8eb,
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (62b8520c, ahead +15)
- Includes latest libnfs master (048e7737, ahead +59)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (b45f98ff, +8), inputstream.rtmp (70cb86f6), inputstream.smoothstream (081c6c43), peripheral.joystick (abff3165), pvr.argustv (87cb6780), pvr.demo (01c68c88), pvr.dvblink (e842db92), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (c091da30), pvr.iptvsimple (57b546a3, +2), pvr.mediaportal.tvserver (845479b6), pvr.mythtv (b1b426f3), pvr.nextpvr (f99b17d3), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (c966c5fd), pvr.vdr.vnsi (dd95edef), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Exclude [env] libcec-PR208.patch: merged upstream (libcec)
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
- Include [env] PR:759: linux: update to linux-4.8.0 [WIP]
- Include [env] PR:792: scripts/build: use MinSizeRel cmake build type
- Include [env] PR:796: scripts/build: cleanup
- Include [env] PR:800: xf86-video-intel: enable dri3 and make it default
- Include [env] PR:807: Network: smb & ntfs config mods
- Include [env] PR:810: path: remove regex dependency when processing packages
- Include [env] PR:812: libdrm: update to libdrm-2.4.71
- Include [env] PR:813: scripts/build: no need to setup toolchain twice and before really building
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Revert [env] PR:793: projects/*/options: disable lcdproc for all projects except Generic/Virtual (Reverted until add-on available)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
- Include [pkg] PR:10543: [platform] - add unique hardware identifier as info label
- Include [pkg] PR:10572: [CryptThreading] replace hardcoded value for CRYPTO_LOCK by macro
- Include [pkg] PR:10641: [video] fix NFO parsing of <namedseason>'s
- Include [pkg] PR:10658: support reusing of CFile::m_pFile
Build Highlights:
- PR:10658: support reusing of CFile::m_pFile
Build Details:
- LibreELEC.tv:
- kodi: correct patch on WP after 17b3 changes (PR:818, 1 commit, 1 file changed)
- tvheadend42: wizard fix + general config updates (PR:814, 1 commit, 3 files changed)
- XBMC:
- [doxygen] Add revision when API was changed or expanded (PR:10631, 1 commit, 15 files changed)
- VideoPlayer: drop some outdated pullup correction code that does more… (PR:10651, 1 commit, 3 files changed)
- [cmake/jenkins] Build with CMake (PR:10649, 1 commit, 22 files changed)
- CUtil::MakeShortenPath() should return true if the given path is already short enough (fixes #16783) (PR:10640, 1 commit, 1 file changed)
- FIX: [gles;oes] confusion between field and index (PR:10653, 1 commit, 1 file changed)
- [webserver] CHTTPImageHandler: add GetLastModifiedDate implementation (PR:10032, 3 commits, 4 files changed)
- [android] AMC: align allowed ref with player (PR:10655, 1 commit, 1 file changed)
- [docs] clarify checkbox uasge in PR template (2379b8eb)
- pvr.iptvsimple:
- Handle time offset in EPG programme start and end times (PR:89, 2 commits, 3 files changed)
- Added: [pkg] PR:10658: support reusing of CFile::m_pFile
(2016-10-08, 11:27)Milhouse Wrote: [ -> ]Read the first post, there's an "Installing" section.
Hello. So I made it but it still does not solve the problem with some adoons like More Power or from czech republic SosačTV. Installation not work.
Can't help without a debug log, but unless those add-ons claim to be Krypton compatible there's no point trying to install them with these builds.
don007 MorePower looks to be far from legit so please don't ask about that add-on in future, there's no support on these forums for add-ons that facilitate piracy.
(2016-10-09, 11:18)Milhouse Wrote: [ -> ]@don007 MorePower looks to be far from legit so please don't ask about that add-on in future, there's no support on these forums for add-ons that facilitate piracy.
Excuse me. It will not happen
Milhouse changing to 4.8.1 in next build?
The builds will use 4.8.1 tonight, but I don't expect there to be any difference as far as LE and Kodi are concerned.
Hi Milhouse,
i have an audio problem.
With my Zotac ci520 Intel Core i3-4020Y there is no DTS passthrough, only DD51.
With my Zotac ci321 Intel 2961Y there is no problem with DTS.
I used build #1008.
