(2016-04-23, 17:33)Milhouse Wrote: [ -> ]...
.... texturecache.py is included in these builds.
Texturecache included ! GREAT !
Since #423 Chromium should be included... but I can't find it.
I installed from scratch using official LEv7 then applied your latest #501 tar on my NUC5i3
Thank you
EDIT:
Default Skin
15:48:48 5.331750 T:139710626252864 NOTICE: Running database version Textures13
15:48:48 5.334392 T:139710626252864 NOTICE: Running database version MyMusic60
15:48:48 5.338246 T:139710626252864 NOTICE: Running database version MyVideos104
15:48:48 5.339359 T:139710626252864 NOTICE: Running database version TV29
15:48:48 5.340070 T:139710626252864 NOTICE: Running database version Epg11
15:48:48 5.340718 T:139710626252864 NOTICE: start dvd mediatype detection
15:48:48 5.462393 T:139710626252864 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
15:48:48 5.592199 T:139710626252864 NOTICE: initialize done
15:48:48 5.592229 T:139710626252864 NOTICE: Running the application...
15:48:48 5.596354 T:139710169077504 WARNING: Create - unsupported protocol(androidapp) in androidapp://sources/apps/
15:48:48 5.606026 T:139710626252864 NOTICE: starting zeroconf publishing
15:48:48 5.606264 T:139710626252864 NOTICE: WebServer: Started the webserver
15:48:48 5.606300 T:139710626252864 NOTICE: starting upnp client
15:48:48 5.630269 T:139709531526912 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
15:48:48 5.630316 T:139709531526912 NOTICE: UDP: Listening on port 9777
15:48:48 5.796865 T:139710143899392 WARNING: CSkinInfo: failed to load skin settings
15:48:50 7.151501 T:139710626252864 NOTICE: UDev: Added /var/media/SimpleDrive
15:48:50 7.687773 T:139710626252864 NOTICE: UDev: Added /var/media/1T
15:48:51 8.212983 T:139710626252864 NOTICE: UDev: Added /var/media/MyBook
15:54:24 341.801910 T:139708910794496 ERROR: GetDirectory - Error getting
15:54:29 346.893982 T:139710160684800 ERROR: Previous line repeats 1 times.
15:54:29 346.894012 T:139710160684800 WARNING: could not find codec parameters for /var/media/1T/01-17-090125-15-POP-403-000.bin
15:54:29 346.894073 T:139710160684800 ERROR: ExtractThumb - Error creating demuxer
15:54:45 362.526489 T:139710160684800 WARNING: could not find codec parameters for /var/media/1T/01-17-090125-15-POP-403-000.bin
15:54:45 362.526581 T:139710160684800 ERROR: ExtractThumb - Error creating demuxer
15:55:44 421.069366 T:139710152292096 ERROR: GetDirectory - Error getting -
15:56:35 472.863647 T:139710160684800 WARNING: CSkinInfo: failed to load skin settings
15:56:35 472.881683 T:139710626252864 WARNING: Skin has invalid include: CommonBackground
15:56:35 472.881744 T:139710626252864 WARNING: Skin has invalid include: VisibleFadeEffect
15:56:35 472.881775 T:139710626252864 WARNING: Skin has invalid include: WindowTitleCommons
15:56:35 472.903748 T:139710626252864 ERROR: Control 1000 in window 13001 has been asked to focus, but it can't
15:57:34 531.647095 T:139710626252864 ERROR: failed to set m_originalLocale to en_US.UTF-8
12:00:13 690.511719 T:139710626252864 ERROR: GetDirectory - Error getting addons://sources/
12:00:13 690.511841 T:139710626252864 ERROR: CGUIMediaWindow::GetDirectory(addons://sources/) failed
12:00:51 728.931335 T:139710626252864 ERROR: Unable to activate the previous window
