(2016-10-17, 08:43)pacoma2610 Wrote: [ -> ]Go back to #1015 because the errors are back:
08:03:06 216.508743 T:140348096510016 ERROR: CGUITextureManager::GetTexturePath: could not find texture 'overlays/arrowdown.png'
08:03:06 216.792740 T:140348096510016 ERROR: Previous line repeats 11 times.
08:03:06 216.792786 T:140348096510016 ERROR: CGUITextureManager::GetTexturePath: could not find texture 'default/bg.jpg'
08:03:06 216.810120 T:140348096510016 ERROR: CGUITextureManager::GetTexturePath: could not find texture 'dialogs/separator-grey.png'
08:03:06 216.863739 T:140347090913024 ERROR: Window Translator: Can't find window videolibrary
08:04:04 274.787781 T:140347082520320 ERROR: Previous line repeats 3 times.
08:04:04 274.787872 T:140347082520320 ERROR: GetDirectory - Error getting
08:04:04 275.089569 T:140348077573888 ERROR: CGUITextureManager::GetTexturePath: could not find texture 'xx'
08:04:04 275.331177 T:140347090913024 ERROR: Window Translator: Can't find window videolibrary
08:04:12 282.685852 T:140348077573888 ERROR: GetDirectory - Error getting
08:04:14 284.935211 T:140348077573888 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://USERNAME[email protected]/TV-Serien%202/Blue%20Bloods/../extrafanart'
unix_err:'2' error : 'No such file or directory'
08:04:14 284.935272 T:140348077573888 ERROR: GetDirectory - Error getting smb://192.168.1.100/TV-Serien 2/Blue Bloods/../extrafanart/
Unless you can reproduce these errors with stock Estuary you shouldn't be reporting them here - they're third-party skin errors, so contact your skin maintainer.
As for the SMB errors, nobody knows if those extrafanart directories of yours exist or not, or if you've simply got a problem in your network that has broken SMB (reboot the [Windows] server etc.).
Please excuse me for my bad description, I wanted to say, with the update from # 1015 to # 1016 the settings of the skins are set to standard. The settingslevel of Kodi itself remains with me on expert.
I will test later with the default Skin....
(2016-10-17, 09:09)pacoma2610 Wrote: [ -> ]the settings of the skins are set to standard.
Unfortunately that still doesn't make any sense, the setting level controls the visibility of the options and not their actual value.
However if all this happened with a third-party skin and it can't be reproduced with stock Estuary then there's not really very much I'm able to do.
This is logical, in future the builds will test with the standard skins.
I think it has something to do with the reloading difficulties in Krypton.
#1011, 11-Oct-2016: Generic -- Release post (Cherry Trail/Bay Trail audio support for 4.8 kernel; peripheral.joystick updates) <- does HD audio work now or ??
/ Stainlessdk
sadly no
there is no option for passthrough, everything works awsome
(2016-10-17, 21:23)stainlessdk Wrote: [ -> ]sadly no there is no option for passthrough, everything works awsome
It does not support passthrough. Kernel does not / audio device does not. It can only do 24 bit audio and for PT you need 16 bit.
New LibreELEC.tv Krypton build #1017:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.8.2 #1 SMP Mon Oct 17 21:03:40 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161017210220-#1017-g15c3a1c [Build #1017]
# Kodi version
Kodi (17.0-BETA4 Git:2702d19). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (15c3a1cb,
changelog) and tip of
XBMC master (2702d19a,
- Includes FernetMenta "VideoPlayer" patches
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (62b8520c, ahead +15)
- Includes latest libnfs master (2edbd147)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (4e4c7258, +12), inputstream.rtmp (70cb86f6), inputstream.smoothstream (081c6c43), peripheral.joystick (25c12ee7, +21), pvr.argustv (87cb6780), pvr.demo (01c68c88), pvr.dvblink (043aa892, +1), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (c091da30), pvr.iptvsimple (adee8a7f, +3), pvr.mediaportal.tvserver (845479b6), pvr.mythtv (2f3dfcdc, +2), pvr.nextpvr (6a2128d8, +1), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (c966c5fd), pvr.vdr.vnsi (dd95edef), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Includes commits from xbmc/master, ahead +2 (FernetMenta)
- Exclude [env] libcec-PR208.patch: merged upstream (libcec)
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
- Include [env] PR:837: lcdd: initial addon
- Include [env] PR:846: linux: update to linux-4.8.2
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: drm/i915: Fix backwards test in Chris Wilson patch (link) (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] patch: drm/i915: Limit the depth of the display pipeline to the framebuffer (linux)
- Include [pkg] PR:33: bye bye lcdproc (service.libreelec.settings)
- Include [pkg] PR:34: system update - fix cross-device linking (service.libreelec.settings)
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
- Include [pkg] PR:10714: AESinkAUDIOTrack: Don't false alarm with m_offset
Build Highlights:
- New 4.8.2 kernel
Build Details:
- XBMC:
- [estuary] grey text on focused item == unreadable (PR:10719, 1 commit, 2 files changed)
- [gui] add listitem.appearances for actors / directors (PR:10698, 1 commit, 2 files changed)
- Fix c/p error in stereoscopic inversion for block format (PR:10718, 1 commit, 1 file changed)
- inputstream.mpd:
- Added: [env] PR:846: linux: update to linux-4.8.2
(2016-10-11, 05:54)Milhouse Wrote: [ -> ] (2016-10-11, 05:25)atoulmin Wrote: [ -> ]Well, when I turn on HArdware acceleration, obviously "intel" for my NUC. The home page will take forever to load instead of being instant in previous builds. I get tearing on the screen when scrolling, and tearing playing videos on youtube.
Turning acceleration off on builds below #930 gives me the same "tearing" Turning acceleration on with builds below #930 works as expected "no tearing"
I've just tested build #1010 and Chromium with intel hardware acceleration, and don't see any tearing on a Skylake NUC6i5SYH (I visited the LE home page, scrolled up and down several times, visited news.bbc.co.uk and scrolled various pages and viewed a few videos again without any tearing). Chromium was the only add-on installed in what is otherwise a "clean" kodi installation - can you try testing without any other addons?
I have just done a clean install of the latest build #1016 I still get the same
Issue.
I also have problems with hw acceleration, chromium and Intel Bay Trail - NUC.
With my NUC DN2820 only "sw accelerated" in chromium is possible - i´ve noticed this, after switching in the Amazon add-on from inputstream to browser.
In the chromium add-on hw acc is set for "intel". Isn´t it possible to get hw acc with this bay trail nuc?
(2016-10-18, 07:54)atoulmin Wrote: [ -> ]I have just done a clean install of the latest build #1016 I still get the same
Issue.
You've said this all started with #0930 but there's nothing in #0930 that might cause this other than the updated kernel. I wonder if a new build of the Chromium add-on is required (unfortunately it's not currently building).
(2016-10-18, 08:25)debutanker Wrote: [ -> ]I also have problems with hw acceleration, chromium and Intel Bay Trail - NUC.
Have you always had this behaviour? Do you have this same problem with LibreELEC release 7.90.007?
(2016-10-18, 11:28)Milhouse Wrote: [ -> ] (2016-10-18, 07:54)atoulmin Wrote: [ -> ]I have just done a clean install of the latest build #1016 I still get the same
Issue.
You've said this all started with #0930 but there's nothing in #0930 that might cause this other than the updated kernel. I wonder if a new build of the Chromium add-on is required (unfortunately it's not currently building).[
Thats my thoughts, will just have to ride this one out
Somewhere between build #1014 and #1016 we lost the ability for numerical time GOTO.
I just checked that build #1013 allowed me during playback to jump to a particular playback time, and in builds #1016 and the latest #1017 numerical keypresses during fullscreen playback have no effect.
(2016-10-18, 11:28)Milhouse Wrote: [ -> ]Have you always had this behaviour? Do you have this same problem with LibreELEC release 7.90.007?
Thx for sharing your thoughts with me!
If i remember correctly (been testing chromium on my nuc long time ago...), i got the same problems with libreelec and the first versions of chromium. After some updates in the chromium add-on i was able to get hw acc and play amazon videos without stuttering.
I havn't tested it with 7.90.007 but i will do asap and share my experience.
