Seems random when stopping. Will play more tomorrow
Anyone testing on SQL with smb?
Suddenly not working will try backtrack to working build.
Also audio is not restored from suspend (GUI sounds or videoplayer).
PHP Code:
13:39:54 698.860718 T:140610438088768 NOTICE: VideoPlayer: Opening: smb://NSA320S/films/Howard.the.Duck.1986.1080p/Howard.the.Duck.1986.1080p.mp4
13:39:54 698.860840 T:140610438088768 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
13:39:54 698.861389 T:140607724099328 NOTICE: Creating InputStream
13:42:41 865.624084 T:140607724099328 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://USERNAME:PASSWORD@NSA320S/films/Howard.the.Duck.1986.1080p'
unix_err:'6e' error : 'Connection timed out'
13:42:41 865.624207 T:140607724099328 ERROR: GetDirectory - Error getting smb://NSA320S/films/Howard.the.Duck.1986.1080p/
passwords.xml is set btw
Okay, this version works fine:
#1011, 11-Oct-2016: Generic -- Release post (Cherry Trail/Bay Trail audio support for 4.8 kernel; peripheral.joystick updates)
...let me check others...
This broke it:
#1018, 18-Oct-2016: Generic -- Release post (Samba fixes; inputstream.mpd updates)
This ok up to here:
#1017, 17-Oct-2016: Generic -- Release post (New 4.8.2 kernel)
Hmm. The Samba changes should have no effect on smb:// as they relate entirely to the configuration of the Samba server in LibreELEC, and not the way in which Kodi communicates with your NAS.
badaas if you run the following command in #1020 and reboot, the Samba server will be back to the pre-#1018 configuration - does it make any difference?
wget -q "https://raw.githubusercontent.com/LibreELEC/LibreELEC.tv/master/packages/network/samba/config/smb.conf" -O /storage/.config/samba.conf
Hi Milhouse, are there any advantages with Mesa 13.0?
When it's released we can find out, is there anything in particular that needs fixing by 13.0?
(2016-10-21, 14:47)badaas Wrote: [ -> ]Anyone testing on SQL with smb?
PHP Code:
i use smb with sql and no problems...
(2016-10-20, 23:09)Roby77 Wrote: [ -> ]This a kernel issue
Black screen when ?
i got this blackscreen problem too and i use a chromebox (Haswell Celeron).
New LibreELEC.tv Krypton build #1021:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.8.2 #1 SMP Fri Oct 21 21:11:27 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161021210421-#1021-g7fe628e [Build #1021]
# Kodi version
Kodi (17.0-BETA4 Git:e143904). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (7fe628ef,
changelog) and tip of
XBMC master (e143904b,
- Includes FernetMenta "VideoPlayer" patches
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (c559955d, ahead +17)
- Includes latest libnfs master (2edbd147)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (4c8013f6), inputstream.rtmp (70cb86f6), inputstream.smoothstream (081c6c43), peripheral.joystick (1aee01f9, +27), pvr.argustv (87cb6780), pvr.demo (01c68c88), pvr.dvblink (043aa892, +1), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (c091da30), pvr.iptvsimple (adee8a7f, +3), pvr.mediaportal.tvserver (845479b6), pvr.mythtv (2f3dfcdc, +2), pvr.nextpvr (6a2128d8, +1), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (c966c5fd), pvr.vdr.vnsi (5b47bd06, +1), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Includes commits from xbmc/master, ahead +2 (FernetMenta)
- Exclude [env] libcec-PR208.patch: merged upstream (libcec)
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
- Include [env] PR:837: lcdd: initial addon
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: drm/i915: Fix backwards test in Chris Wilson patch (link) (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] patch: drm/i915: Limit the depth of the display pipeline to the framebuffer (linux)
- Include [pkg] PR:33: bye bye lcdproc (service.libreelec.settings)
- Include [pkg] PR:34: system update - fix cross-device linking (service.libreelec.settings)
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
- Include [pkg] PR:10714: AESinkAUDIOTrack: Don't false alarm with m_offset
- Include [pkg] PR:10739: Fixed OnPlayBackResumed not getting fired anymore.
Build Highlights:
- Minors
Build Details:
- LibreELEC.tv:
- changed url from openelec.tv to libreelec.tv (PR:857, 1 commit, 1 file changed)
- dvb-tools: add w_scan (PR:855, 1 commit, 3 files changed)
- kodi: fix aml audio patch (PR:851, 1 commit, 1 file changed)
- samba: fix browsing and clean up smb.conf (PR:849, 1 commit, 1 file changed)
- installer: replace dialog with whiptail (PR:854, 8 commits, 9 files changed)
- XBMC:
- Use new add-on hooks to enable/disable peripheral add-ons (PR:10734, 1 commit, 3 files changed)
- [filesystem/nfs] - ensure that the last access time of a context is u… (PR:10737, 1 commit, 1 file changed)
- disable debug in depends in Release builds (PR:10728, 2 commits, 9 files changed)
- [skin.estuary] Fix mute icon (PR:10742, 1 commit, 1 file changed)
- pvr.vdr.vnsi:
- send wol on system resume (PR:92, 1 commit, 2 files changed)
- Added: [pkg] PR:10739: Fixed OnPlayBackResumed not getting fired anymore.
I'm having the same issue @
badaas is having with smb, I reverted back to #1017 build and everything is back to normal, no issues accessing smb share from a Windows 10 PC and NAS. All builds after #1017 and #1021 today exhibit the same issue.
