(2016-10-22, 16:44)badaas Wrote: [ -> ] (2016-10-22, 16:21)Milhouse Wrote: [ -> ]So, with the LE Samba server OFF (no processes running), and using only the default settings (ie. without /storage/.config/samba.conf), do you still have smb:// problems with builds #1018 and later? As that would make very little sense...
Yes, still problems.
1018 no samba.conf and server off. Busy spinner ad inifinitum.
Then it cannot be due to the Samba config change as you're not using the Samba server. If @
peak3d doesn't respond I'll try and revert the inputstream.mpd changes in the next build.
(2016-10-22, 16:51)badaas Wrote: [ -> ]And this no audio from resume log:
1017
This started with #1017, you don't see this with #1016?
Reply from @peak3d:
peak3d Wrote:@Milhouse 150% sure that there is no depndency inputstream / smb://
So not sure how to proceed at this point...
Pardon me for asking in this thread, but is SW decoding of 12-bit HEVC video supported? I've been testing x265 lately and found out that the 12-bit encodes produce a somewhat smaller file compared to the 10-bit one. It's just like x264 and 8-bit vs. 10-bit, the latter one creates smaller files with identical settings.
Try it. Most likely the CPU that can do that for 4k needs to be invented :-) first.
Well, my encodes are 720p so they're a bit lighter to process
If you count the time to encode that stuff ... you can buy Terrabytes of hard disk space ...
(2016-10-22, 19:01)fritsch Wrote: [ -> ]If you count the time to encode that stuff ... you can buy Terrabytes of hard disk space ...
It's not that slow anymore, plenty of speedups are available with a negligible quality hit. It requires around 2x the time x264 does so it's not a big deal as I can leave the computer working 24/7.
New LibreELEC.tv Krypton build #1022:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.8.2 #1 SMP Sat Oct 22 21:05:34 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161022210415-#1022-g69bca63 [Build #1022]
# Kodi version
Kodi (17.0-BETA4 Git:cf08208). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (69bca63e,
changelog) and tip of
XBMC master (cf082085,
- Includes FernetMenta "VideoPlayer" patches
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (c559955d, ahead +17)
- Includes latest libnfs master (2edbd147)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (4c8013f6), inputstream.rtmp (70cb86f6), inputstream.smoothstream (081c6c43), peripheral.joystick (87a23de8, +28), pvr.argustv (87cb6780), pvr.demo (01c68c88), pvr.dvblink (043aa892, +1), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (c091da30), pvr.iptvsimple (adee8a7f, +3), pvr.mediaportal.tvserver (845479b6), pvr.mythtv (2f3dfcdc, +2), pvr.nextpvr (6a2128d8, +1), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (c966c5fd), pvr.vdr.vnsi (5b47bd06, +1), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Includes commits from xbmc/master, ahead +2 (FernetMenta)
- Exclude [env] libcec-PR208.patch: merged upstream (libcec)
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
- Include [env] PR:837: lcdd: initial addon
- Include [env] PR:859: linux: add support for VIA82XX audio in Generic builds
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: drm/i915: Fix backwards test in Chris Wilson patch (link) (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] patch: drm/i915: Limit the depth of the display pipeline to the framebuffer (linux)
- Include [pkg] PR:33: bye bye lcdproc (service.libreelec.settings)
- Include [pkg] PR:34: system update - fix cross-device linking (service.libreelec.settings)
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
- Include [pkg] PR:10714: AESinkAUDIOTrack: Don't false alarm with m_offset
- Include [pkg] PR:10739: Fixed OnPlayBackResumed not getting fired anymore.
Build Highlights:
- Clean build.
- Enable integrated AC97 support with VIA chipsets
Build Details:
- LibreELEC.tv:
- imx6: build all additional drivers (PR:865, 1 commit, 1 file changed)
- XBMC:
- smart playlists: fix drill down from artists lists that have role based rules (PR:10700, 1 commit, 1 file changed)
- [xbmc][Fix] Guard against double free by setting our deleted values to nullptr (PR:10745, 1 commit, 1 file changed)
- peripheral.joystick:
- [readme] Move repo to xbmc org (87a23de8)
- Added: [env] PR:859: linux: add support for VIA82XX audio in Generic builds
(2016-10-22, 14:07)Milhouse Wrote: [ -> ]7.90.007 doesn't include the updated Samba config - it uses the same config I asked you to download - so if you're having problems with stock 7.90.007 it probably has nothing to do with the Samba server configuration change.
Can you delete the original config and reboot your SMB server?
Okay, your suggestion worked, smb is working fine now with a clean install of build #1022 this time. I'm still not sure why #1017 just worked as is, but at least now I can use newer builds.
At the end of the day, it was something simple. Thank you Milhouse
(2016-10-22, 23:54)Maverick-DBZ- Wrote: [ -> ]Okay, your suggestion worked, smb is working fine now with a clean install of build #1022 this time. I'm still not sure why #1017 just worked as is, but at least now I can use newer builds.
That's good, thanks. Maybe something went a little wonky in #1018-#1021, though not sure what or why, and the #1022 clean build straightened it out.
Hopefully @
badaas will also see better results with #1022.
another question regarding intelnuc 5cpyh
i have been reading that to install windows ( which i dont want todo) you need to download usb 3 drivers as it only has usb 4 ports.
Is libreelec installable from USB stick without the need for special drivers
thanks in advance
(2016-10-22, 22:06)piotrasd Wrote: [ -> ]@fritsch
Any idea why i getting crash each time i want play something ...
http://pastebin.com/LrzzZLfj (latest KODI from master and latest mesa)
This start happen after bump
No - there is absolutely nothing in your log. No crash / nothing, it's even a cut logfile and I have no idea what you are running. If you feel it's mesa related -> bugs.freedesktop.org and btw. "latest" is not a version, especially if the header of the log is cut.
