Full Version: LibreELEC Testbuilds for x86_64 (Kodi 17.0)
Be aware: FernetMenta and I don't have any hardware here, we cannot test anything, we cannot support anything. As you are on your own I also won't post the kodi vaapi hevc 10 bit patch, but I give you a hint: check if ffmpeg's avctx profile is FF_PROFILE_HEVC_MAIN_10 and if that's the case set the profile of vaapi to VAProfileHEVCMain10.
After that check if the driver supports it. The change is a two liner if (ffmpeg's 10 bit profil) set vaapi profile to Main10 else to Main.
^^ if you manage that + the ffmpeg patch. I am curious about your experience, but I won't start debugging blindly.
I am such a Linux Noob, but I will give it a try the nex view days :-) Thanks.
Hardware is rare, I was lucky to get one.
That was towards piotrasd who sent me a PM. He has the same capable hw and can most likely provide you a build.
New LibreELEC.tv Krypton build #1027: Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.8.4 #1 SMP Thu Oct 27 21:05:46 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161027210429-#1027-g43e4f93 [Build #1027]
# Kodi version
Kodi (17.0-BETA5 Git:e2333bf). Platform: Linux x86 64-bit
Based on tip of LibreELEC.tv master (43e4f934, changelog) and tip of XBMC master (e2333bfb, changelog) with the following modifications: Build Highlights:
  1. ffmpeg: update to 3.1.5-Krypton-Beta5-1 (AMD GPU initial i-frame fix)
  2. Implement seeking with numeric input
  3. Fix zip addon installs (PR:10794)
Build Details:
  1. LibreELEC.tv:
    • add valgrind to debug builds (PR:884, 2 commits, 2 files changed)
    • hyperion: update to 355a324, enable qt5 (PR:856, 6 commits, 10 files changed)
    • lcdd: initial addon (PR:837, 3 commits, 27 files changed)
    • Decommission PKG_PRIORITY (PR:886, 1 commit, 4 files changed)
    • config/functions: change debug_strip syntax (PR:889, 1 commit, 1 file changed)
    • config/path: remove PKG_PRIORITY (PR:890, 1 commit, 1 file changed)
    • linux: add support for VIA82XX audio in Generic builds (PR:859, 1 commit, 1 file changed)
    • projects/WeTek_Play_2: Enable CONFIG_DYNAMIC_DEBUG - it is required by WeTek DVB module (PR:891, 1 commit, 1 file changed)
  2. XBMC:
    • FIX: [droid;apps] handles missing res icon (PR:10777, 1 commit, 3 files changed)
    • Fade the current controller while mapping its buttons (PR:10761, 1 commit, 4 files changed)
    • Backport Windowing stuff from SPMC (PR:10743, 6 commits, 11 files changed)
    • SeekHandler: handle the seeking with numeric input. (PR:10769, 4 commits, 6 files changed)
    • [skins] add seek label to video fullscreen (PR:10786, 1 commit, 2 files changed)
    • libdvd/Makefile: cross-compile, allow to specify the ar command (PR:10782, 0 commits, 0 files changed)
    • ActiveAEFilter: Add missing include for avcodec_fill_audio_frame (PR:10791, 1 commit, 1 file changed)
    • Change splash db upgrade logic (PR:10731, 1 commit, 8 files changed)
    • Revert "[xbmc][win]Build addons with debug info on Windows" (PR:10793, 1 commit, 3 files changed)
  3. libcec:
    • fixed: removed debian Replaces/Provides/Conflicts (cf438566)
  4. pvr.vbox:
    • Fixed tabs, comments, redundant braces and method change (std:Confusedize()>0) to (!std::empty()) (PR:145, 1 commit, 6 files changed)
  5. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] patch: ffmpeg: update to 3.1.5-Krypton-Beta5-1
    • Added: [pkg] PR:10794: [addons] make sure temp dir exists before running CFileOperationJob
Builds 10.26 and 10.27, FLAC files are not playing. They start, then the GUI hangs.
http://sprunge.us/aXRi
**edit**
Disabling the visualization fixed the issue.
@Milhouse:
Is support for MSI FM2 AMD boards with AMD A series A8-5600K processor dropped in these builds and those of Libreelec in general?
Trying to update from OpenELEC-Generic.x86_64-6.0.3 to Libreelec by usb fresh install, but all of the builds start booting and after the prompt; boot: the pc restarts itself.
When I do the same with the older OpenELEC-Generic.x86_64-6.0.3 created usb stick the first boot process continues and I'm able to install it.
When I drop your build in the update folder and reboot the update process completes but after the initiated reboot the pc keeps looping from the "syslinux 6.0.3 ..." and then reboots again.
See also this post by someone with the same hardware:
https://forum.libreelec.tv/thread-1272.html
(2016-10-28, 00:46)rudrood Wrote: [ -> ]@Milhouse:
Try doing a clean install of 7.90.007 and report back.
Hello
I have been trying to setup libreelec on my HTPC
The HTPC runs fine under windows 10 but I would like to run the JeOS concept, with TVHeadend PVR
Hadware configuration :
Intel Skylake Core i5 CPU
8 GB RAM
Atheros Wifi Adapter
Hauppauge HVR-2205 DVB-T/T2 Dual tuner card with IR receiver and Hauppauge remote (not MCE)
Libreelec itself runs fine, but no matter what try I am unable to get the Hauppauge IR receiver recognised
I am running the latest build by Milhouse as below
# uname -a
Linux LibreElec 4.8.4 #1 SMP Thu Oct 27 21:05:46 BST 2016 x86_64 GNU/Linux
# lsb_release
Hauppauge card gets recognised as below from the dmesg ouput
[    3.770557] Linux video capture interface: v2.00
[    3.772612] saa7164 driver loaded
[    3.772644] saa7164 0000:04:00.0: enabling device (0000 -> 0002)
[    3.772716] CORE saa7164[0]: subsystem: 0070:f123, board: Hauppauge WinTV-HVR2205 [card=13,autodetected]
[    3.772718] saa7164[0]/0: found at 0000:04:00.0, rev: 129, irq: 18, latency: 0, mmio: 0xdf400000
[    3.941629] saa7164_downloadfirmware() no first image
[    3.941655] saa7164_downloadfirmware() Waiting for firmware upload (NXP7164-2010-03-10.1.fw)
[    3.948081] saa7164_downloadfirmware() firmware read 4019072 bytes.
[    3.948082] saa7164_downloadfirmware() firmware loaded.
[    3.948083] Firmware file header part 1:
[    3.948083]  .FirmwareSize = 0x0
[    3.948084]  .BSLSize = 0x0
[    3.948084]  .Reserved = 0x3d538
[    3.948084]  .Version = 0x3
[    3.948085] saa7164_downloadfirmware() SecBootLoader.FileSize = 4019072
[    3.948089] saa7164_downloadfirmware() FirmwareSize = 0x1fd6
[    3.948090] saa7164_downloadfirmware() BSLSize = 0x0
[    3.948090] saa7164_downloadfirmware() Reserved = 0x0
[    3.948090] saa7164_downloadfirmware() Version = 0x1661c00
[   10.758495] saa7164_downloadimage() Image downloaded, booting...
[   10.865109] saa7164_downloadimage() Image booted successfully.
[   10.865123] starting firmware download(2)
[   13.668314] saa7164_downloadimage() Image downloaded, booting...
[   15.481651] saa7164_downloadimage() Image booted successfully.
[   15.481665] firmware download complete.
[   15.532766] tveeprom 5-0000: Hauppauge model 151009, rev B2I6, serial# 4035638696
[   15.532770] tveeprom 5-0000: MAC address is 00:0d:fe:8a:f5:a8
[   15.532773] tveeprom 5-0000: tuner model is SiLabs Si2157 (idx 186, type 4)
[   15.532776] tveeprom 5-0000: TV standards PAL(B/G) NTSC(M) PAL(I) SECAM(L/L') PAL(D/D1/K) ATSC/DVB Digital (eeprom 0xfc)
[   15.532778] tveeprom 5-0000: audio processor is SAA7164 (idx 43)
[   15.532780] tveeprom 5-0000: decoder processor is SAA7164 (idx 40)
[   15.532782] tveeprom 5-0000: has radio, has IR receiver, has no IR transmitter
[   15.532784] saa7164[0]: Hauppauge eeprom: model=151009
[   15.585005] i2c i2c-7: Added multiplexed i2c bus 8
[   15.585007] si2168 7-0064: Silicon Labs Si2168-B40 successfully identified
[   15.585008] si2168 7-0064: firmware version: B 4.0.2
[   15.588976] si2157 5-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
[   15.589316] DVB: registering new adapter (saa7164)
[   15.589318] saa7164 0000:04:00.0: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)...
[   15.610394] i2c i2c-7: Added multiplexed i2c bus 9
[   15.610396] si2168 7-0066: Silicon Labs Si2168-B40 successfully identified
[   15.610397] si2168 7-0066: firmware version: B 4.0.2
[   15.613748] si2157 6-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
[   15.614088] DVB: registering new adapter (saa7164)
[   15.614090] saa7164 0000:04:00.0: DVB: registering adapter 1 frontend 0 (Silicon Labs Si2168)...
[   15.651058] saa7164[0]: registered device video0 [mpeg]
[   15.882682] saa7164[0]: registered device video1 [mpeg]
[   16.097552] saa7164[0]: registered device vbi0 [vbi]
[   16.097722] saa7164[0]: registered device vbi1 [vbi]
So the tveeprom section sees that there is a IR receiver but that never shows up in input devices as below
cat /proc/bus/input/devices
I: Bus=0019 Vendor=0000 Product=0003 Version=0000
N: Name="Sleep Button"
P: Phys=PNP0C0E/button/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
U: Uniq=
H: Handlers=kbd event0
B: PROP=0
B: EV=3
B: KEY=4000 0 0
I: Bus=0019 Vendor=0000 Product=0001 Version=0000
N: Name="Power Button"
P: Phys=PNP0C0C/button/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
U: Uniq=
H: Handlers=kbd event1
B: PROP=0
B: EV=3
B: KEY=10000000000000 0
P: Phys=LNXPWRBN/button/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
U: Uniq=
H: Handlers=kbd event2
B: PROP=0
B: EV=3
I: Bus=0019 Vendor=0000 Product=0006 Version=0000
N: Name="Video Bus"
P: Phys=LNXVIDEO/video/input0
S: Sysfs=/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input3
U: Uniq=
H: Handlers=kbd event3
B: PROP=0
B: EV=3
B: KEY=3e000b00000000 0 0 0
I: Bus=0003 Vendor=413c Product=2106 Version=0110
N: Name="DELL Dell QuietKey Keyboard"
P: Phys=usb-0000:00:14.0-12/input0
S: Sysfs=/devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12:1.0/0003:413C:2106.0001/input/input7
U: Uniq=
H: Handlers=sysrq kbd leds event4
B: PROP=0
B: EV=120013
B: KEY=1000000000007 ff9f207ac14057ff febeffdfffefffff fffffffffffffffe
B: MSC=10
B: LED=7
I: Bus=0000 Vendor=0000 Product=0000 Version=0000
N: Name="HDA Intel PCH Front Mic"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1f.3/sound/card0/input9
U: Uniq=
H: Handlers=event5
B: PROP=0
B: EV=21
B: SW=10
N: Name="HDA Intel PCH Rear Mic"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1f.3/sound/card0/input10
U: Uniq=
H: Handlers=event6
B: PROP=0
B: EV=21
B: SW=10
N: Name="HDA Intel PCH Line"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1f.3/sound/card0/input11
U: Uniq=
H: Handlers=event7
B: PROP=0
B: EV=21
B: SW=2000
N: Name="HDA Intel PCH Line Out"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1f.3/sound/card0/input12
U: Uniq=
H: Handlers=event8
B: PROP=0
B: EV=21
B: SW=40
N: Name="HDA Intel PCH Front Headphone"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1f.3/sound/card0/input13
U: Uniq=
H: Handlers=event9
B: PROP=0
B: EV=21
B: SW=4
N: Name="HDA Intel PCH HDMI/DP,pcm=3"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1f.3/sound/card0/input14
U: Uniq=
H: Handlers=event10
B: PROP=0
B: EV=21
B: SW=140
N: Name="HDA Intel PCH HDMI/DP,pcm=7"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1f.3/sound/card0/input15
U: Uniq=
H: Handlers=event11
B: PROP=0
B: EV=21
B: SW=140
N: Name="HDA Intel PCH HDMI/DP,pcm=8"
P: Phys=ALSA
S: Sysfs=/devices/pci0000:00/0000:00:1f.3/sound/card0/input16
U: Uniq=
H: Handlers=event12
B: PROP=0
B: EV=21
B: SW=140
Can someone please advise how I get my Hauppauge IR Receiver recognised under libreelec
Thanks very much
Build #1027 works
Since people had problems to install/update:
I installed 1026 through
1) configurate a USB boot stick with Libreelec tool and Alpha 7
2) before starting the installation replace the system and kernel files on the usb stick through files from the 1026(or later) download
Update to 1027
copy sytem and kernel files from download into the updatefolder and reboot
The files in this threat are no images, so you need to copy the files from the target folder.
In 1026/1027 I have long buffering times for files from my OMV (MindiDLNA) Server. Buffering problem not tested with samba. After buffering: Files up to 4K 8bit do work with HW decoding, only 4K 29,97Hz stutters and also all 4K 10bit files.
HD Audio didnt work von 1026, did not yet test it on 1027, I only had 5 minutes for testing.
Dear All,
Just one message to say thanks you for your hard work to have stable libreelec build.
It's a pleasure to use this fantastic media soft.
Thanks to all communities.
(2016-10-28, 11:45)polarrys Wrote: [ -> ]Dear All,
+1! Thank you.
(2016-10-28, 00:56)lrusak Wrote: [ -> ]
Thanks for your reply.
I created an usb stick with LibreELEC.USB-SD.Creator.Win32 with version 7.90.007 but the result is the same:
The pc boots from the stick until the prompt: boot, it looks like it want to start the install for a few seconds (a few blank lines are added) and then the pc reboots.
Get no error message or nothing,
Created an usb stick with LibreELEC.USB-SD.Creator.Win32 and manually selecting OpenELEC-Generic.x86_64-6.0.3.img.Booted the pc from it, and the process of installing continues and I can install it oke.
Tryed win32DiskImager with the same results.
Tryed another usb stick with the same results.
Reseted all bios settings to default with legacy boot enabled but that doesn't help either..
Sorry for hijeck here. Maybe I should post somewhere else?
Seems that Video DB Cleanup is broken in V17. I had to disable "Wake Server on Access" to get is working and even then Kodi reported a Share as missing that was online and accessable. Idea?
(2016-10-28, 04:03)gujal Wrote: [ -> ]Can someone please advise how I get my Hauppauge IR Receiver recognised under libreelec
Thanks very much
Make a forum post on the LibreELEC forum and I will help you out.
