Installed the Oct 29 build on an Intel NUC 4k model NUC5CPYH, While testing and setting up on a 720p TV monitor everything worked well. When I connected it to my 4k display the unit became very sluggish and laggy. Video playback was jerky. Can send logs if you like if someone can tell me how to extract them.
@ bobsilver1
See first post, you will find exact steps on how to get debug logs.
(2016-10-29, 01:39)smf007 Wrote: [ -> ] (2016-10-28, 20:42)lrusak Wrote: [ -> ] (2016-10-28, 04:03)gujal Wrote: [ -> ]Can someone please advise how I get my Hauppauge IR Receiver recognised under libreelec
Thanks very much
Make a forum post on the LibreELEC forum and I will help you out.
The answer is already in this thread. You need to go back a couple months of posts.
Sent from my SGH-I337M (typie typie)
I could find only discussions about usb ir rececivers and mce remotes.
My question is specific to ir receivers built on Hauppauge Cards and their remotes, which are not MCE standard. If there is something around that, I am unable to find in this thread, please help
Anyone else having problems with video database clean up & file playback in #1029?
#1029 Same behavior like #1028. No hd Audio passthrough. Log was given before. Hope it is the right One now.
I will Check Database behavior within the next hour
Quote:23:11:29 77.591179 T:140427118364416 INFO: CAESinkALSA::Initialize - Opened device "hdmi:CARD=PCH,DEV=0,AES0=0x06,AES1=0x82,AES2=0x00,AES3=0x09"
23:11:29 77.591438 T:140427118364416 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 9600, bufferSize 38400
23:11:29 77.592583 T:140427155331136 DEBUG: GL: Pixel Shader compilation log:
23:11:29 77.592606 T:140427155331136 DEBUG: GL: Fragment Shader compiled successfully
23:11:29 77.600075 T:140427118364416 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 9600, bufferSize 38400
23:11:29 77.600121 T:140427118364416 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 200 ms
23:11:29 77.601486 T:140427118364416 DEBUG: CAESinkALSA::GetChannelLayout - Input Channel Count: 8 Output Channel Count: 8
23:11:29 77.601501 T:140427118364416 DEBUG: CAESinkALSA::GetChannelLayout - Requested Layout: RAW,RAW,RAW,RAW,RAW,RAW,RAW,RAW
23:11:29 77.601509 T:140427118364416 DEBUG: CAESinkALSA::GetChannelLayout - Got Layout: RAW,RAW,RAW,RAW,RAW,RAW,RAW,RAW (ALSA: none)
23:11:29 77.601524 T:140427118364416 DEBUG: CActiveAESink::OpenSink - ALSA Initialized:
23:11:29 77.601532 T:140427118364416 DEBUG: Output Device : HDA Intel PCH
23:11:29 77.601540 T:140427118364416 DEBUG: Sample Rate : 192000
23:11:29 77.601555 T:140427118364416 DEBUG: Sample Format : AE_FMT_S16NE
23:11:29 77.601562 T:140427118364416 DEBUG: Channel Count : 8
23:11:29 77.601570 T:140427118364416 DEBUG: Channel Layout: RAW,RAW,RAW,RAW,RAW,RAW,RAW,RAW
23:11:29 77.601578 T:140427118364416 DEBUG: Frames : 9600
23:11:29 77.601593 T:140427118364416 DEBUG: Frame Size : 16
From kodi side everything is perfectly fine. Most likely "yet another kernel bug" with that new hardware.
If you want - try the HDMI port instead and not the display port
(2016-10-30, 07:48)gujal Wrote: [ -> ] (2016-10-29, 01:39)smf007 Wrote: [ -> ] (2016-10-28, 20:42)lrusak Wrote: [ -> ]Make a forum post on the LibreELEC forum and I will help you out.
Sorry, forgot we changed threads.
It was in the previous thread.
Testing all audio devices is what i did First.
Updating the libary and cleaning the Library Works without Problems
(2016-10-30, 16:25)smf007 Wrote: [ -> ]Sorry, forgot we changed threads.
Thanks for pointing me to the thread.
So following your advice I created a /storage/.config/autostart.sh file with these two lines
modprobe rc_hauppauge
modprobe ir-kbd-i2c
so lsmod now shows this
Module Size Used by
si2157 4461 2
si2168 6196 2
i2c_mux 2422 1 si2168
drbg 12823 1
ctr 3519 3
ccm 7087 3
ir_kbd_i2c 4931 0
rc_hauppauge 2358 0
rc_core 14638 2 rc_hauppauge,ir_kbd_i2c
ath9k 71896 0
ath9k_common 19308 1 ath9k
ath9k_hw 377393 2 ath9k_common,ath9k
ath 16471 3 ath9k_common,ath9k,ath9k_hw
mac80211 276017 1 ath9k
fuse 65074 7
wl 6356280 0
snd_hda_codec_hdmi 31862 1
intel_powerclamp 6919 0
intel_rapl 8800 0
iosf_mbi 2778 1 intel_rapl
snd_hda_codec_realtek 51436 1
snd_hda_codec_generic 43541 1 snd_hda_codec_realtek
btusb 25197 0
btrtl 3488 1 btusb
btbcm 5471 1 btusb
btintel 5560 1 btusb
bluetooth 237339 5 btbcm,btrtl,btusb,btintel
saa7164 92989 0
snd_hda_intel 20100 0
tveeprom 13177 1 saa7164
snd_hda_codec 70076 4 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_intel
dvb_core 72343 1 saa7164
snd_hda_core 28290 5 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel
snd_hwdep 4819 1 snd_hda_codec
videodev 100149 1 saa7164
cfg80211 208985 5 wl,ath,ath9k_common,ath9k,mac80211
But still there is no response to the remote. I tried running irw and pressed the buttons but no response on screen.
I also tried running the ir-keytable command but I keep getting
Couldn't find any node at /sys/class/rc/rc*.
Please advise what steps I am missing.
Thanks for your support.
New LibreELEC.tv Krypton build #1030:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.8.4 #1 SMP Sun Oct 30 22:27:07 GMT 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161030222550-#1030-gae704a7 [Build #1030]
# Kodi version
Kodi (17.0-BETA6 Git:a08a5e3). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (ae704a71,
changelog) and tip of
XBMC master (a08a5e3f,
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (f6fdd650, ahead +54)
- Includes latest libnfs master (2edbd147)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.mpd (4c8013f6), inputstream.rtmp (48742bc1), inputstream.smoothstream (081c6c43), peripheral.joystick (ae86732f), pvr.argustv (87cb6780), pvr.demo (01c68c88), pvr.dvblink (043aa892), pvr.dvbviewer (f72c62ff), pvr.filmon (675c2b4e), pvr.hdhomerun (eef1bd15), pvr.hts (c091da30), pvr.iptvsimple (adee8a7f), pvr.mediaportal.tvserver (aa02879b, +2), pvr.mythtv (2f3dfcdc), pvr.nextpvr (6a2128d8), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (810994a2), pvr.vdr.vnsi (5b47bd06), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Exclude [env] libcec-PR208.patch: merged upstream (libcec)
- Include [env] ed1576d2: RBP: ARCH_MULTIPLATFORM changes (see PR:1699)
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: ffmpeg: update to 3.1.5-Krypton-Beta5-1
- Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] patch: i965: Add some APL and KBL SKU strings (mesa)
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:10370: Add settings to control notification rumble duration and strength
- Include [pkg] PR:10739: Fixed OnPlayBackResumed not getting fired anymore.
- Include [pkg] PR:10775: bump to libCEC 4.0.0 + some rebased PRs
- Include [pkg] PR:10785: add privacy policy
- Include [pkg] PR:10819: fix hash checking in addon installer
Build Highlights:
- PR:10819: fix hash checking in addon installer
- MemoryAlignment: Fixes
Build Details:
- LibreELEC.tv:
- i.MX6 4.4 kernel: update the patches set to all known in the wild (PR:883, 1 commit, 22 files changed)
- XBMC:
- FIX: [amc] Multiple fixes (PR:10779, 5 commits, 2 files changed)
- Coverity: Initialize videoinfotag rating and uniqueid ids (PR:10812, 1 commit, 1 file changed)
- [cmake] Debug binary-addon packaging issues on android (PR:10803, 2 commits, 2 files changed)
- deprecate autotools (PR:10797, 1 commit, 1 file changed)
- Bunch of SPMC jni backports (PR:10808, 26 commits, 76 files changed)
- MemoryAlignment: Fixes (PR:10810, 4 commits, 5 files changed)
- [skins] seeknumeric - use hh:mm:ss format (PR:10816, 1 commit, 2 files changed)
- FFmpeg: Bump to 3.1.5-Krypton-Beta5-1 (PR:10746, 1 commit, 1 file changed)
- allow settings.xml.in (PR:10815, 1 commit, 1 file changed)
- Fixed: RTMP swfvfy also accepts 1 instead of just true (PR:10820, 1 commit, 1 file changed)
- Added: [pkg] PR:10819: fix hash checking in addon installer
Just installed in the latest update #1030 from the beta 3 on my Meegopad T03 computer stick with Cherry Trail. My network adaptor has failed to be recognized with this update. Sound and video are working fine in this update. Also will not read SD cards larger then 32gb tried my 128gb and my 200gb and they no longer work as they did under windows. This is just a test stick for me so I am willing to load it up with any updates for testing and report as needed. I also have an intel compute stick gen 2 with cherry trail but is my main box for now so want it to stay stable or get the meegopad stable before using it to test with.
Beta 3? 200GB SD cards?
Can't help without logs/details. Boot into the last version with working network then:
dmesg | pastebinit
lsusb | pastebinit
lsusb -t | pastebinit
lsusb -v | pastebinit
lspci | pastebinit
lspci -v | pastebinit
lsmod | pastebinit
and paste the results.
(2016-10-29, 20:39)fritsch Wrote: [ -> ] (2016-10-29, 17:10)_Spook_ Wrote: [ -> ]@fritsch when next gen NUC is released in january I can donate one with i3 to you
Thanks much. Not needed - will buy one myself after it is available.
And what about some beer ?
