New LibreELEC.tv Krypton build #1124:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.8.10 #1 SMP Thu Nov 24 21:08:47 GMT 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161124210732-#1124-g405c39f [Build #1124]
# Kodi version
(17.0-BETA6 Git:17.0-beta5-e92818a). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (405c39f6,
changelog) and tip of
XBMC master (30d4d28b,
- Includes latest kodi-platform master (c8188d82)
- Includes latest kodi-theme-Estuary-next master (1f0b5215)
- Includes latest libcec master (209884d6, ahead +60)
- Includes latest libnfs master (a2b37349, ahead +2)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.mpd (4c8013f6), inputstream.rtmp (76c90411), inputstream.smoothstream (081c6c43), peripheral.joystick (d09e0c60, +26), pvr.argustv (87cb6780), pvr.demo (01c68c88), pvr.dvblink (043aa892), pvr.dvbviewer (f72c62ff), pvr.filmon (e4f99002), pvr.hdhomerun (2c73804a, +3), pvr.hts (195deeeb, +3), pvr.iptvsimple (b4dfddee, +1), pvr.mediaportal.tvserver (47b9ade8, +16), pvr.mythtv (038cee07, +6), pvr.nextpvr (6a2128d8), pvr.njoy (b5d65655), pvr.pctv (d6d969fe), pvr.stalker (168e35f7), pvr.vbox (e4183831, +30), pvr.vdr.vnsi (56322c56, +2), pvr.vuplus (7ab30d34), pvr.wmc (d9eac84f)
- Exclude [env] kodi-999.01-build-lirc-for-rpi.patch: merged upstream
- Exclude [env] libcec-PR208.patch: merged upstream (libcec)
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: ffmpeg: update to 3.1.5-Krypton-Beta5-1
- Include [env] patch: fix LE PR:768 after Kodi PR:10973
- Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: visualization.shadertoy: update to 1.1.4
- Include [env] PR:768: kodi use cmake
- Include [env] PR:951: samba: fix allocation/size on disk issues reported by Windows 8.x+
- Include [env] PR:958: Python: update to 2.7.12
- Include [env] PR:968: busybox: add getedid script
- Include [env] PR:980: systemd: update to 232
- Include [pkg] patch: i965: Add some APL and KBL SKU strings (mesa)
- Include [pkg] PR:39: use prettyname_regex to show shortname in update menu (service.libreelec.settings)
- Include [pkg] PR:249: Fix ass_set_cache_limits() to work with composite cache (libass)
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:10982: [PVR] fix recordings window subfolder listings
Build Highlights:
- Bump systemd 232
- Bump Python 2.7.12
Build Details:
- LibreELEC.tv:
- timezone-data: convert to new tzdata and tzcode packages (PR:940, 1 commit, 3 files changed)
- repository.kodinerds: fix icons (PR:984, 1 commit, 3 files changed)
- libopenmpt: fix leftover from version bump (PR:983, 1 commit, 1 file changed)
- scripts/create_addon: copy fanart to buildfolder too (PR:985, 1 commit, 1 file changed)
- XBMC:
- fixed: use correct type for time parameter in UPnPPlayer (PR:10977, 1 commit, 2 files changed)
- Speed up startup time for movies in split rar archives. (PR:9925, 1 commit, 1 file changed)
- use debug logging for missing textures (PR:10547, 1 commit, 1 file changed)
- kodi-theme-Estuary:
- pvr.iptvsimple:
- Increase logging, parse M3U files lacking EXTM3U marker. (PR:83, 1 commit, 2 files changed)
- Added: [env] PR:958: Python: update to 2.7.12
- Added: [env] PR:980: systemd: update to 232
- Added: [pkg] PR:10982: [PVR] fix recordings window subfolder listings
Hi There.
New to this forum. Great project on Libreelec!
I've updated Libreelec to the last nightly build, running on a Z8300 Cherry Trail box (Intel) (Was WIndows 10). Video is fine via HDMI and I get picture and sound. Issue I have is no sound output from MP3's / Spotify streams etc. The sound starts quickly, for a few seconds, stops, locks Kodi and causes a restart of Kodi, every time. The ALSA driver is in play and HDMI is connected to a Yamaha amp. Only other sound driver referenced is Blue Tooth, not in use.
Personally I'd expect video issues, not simple MP3/AAC sound problems. Is there anything I can do, log, to try and resolve this. Ive tried disable pass through/enable, video output changes all to no avail. No settings within Kodi change the outcome of the Kodi restart in Libreelec.
Apart from this I have Spotify working, plex kodi connect, chrome browser working, and its fine most of the time, except no sound from any form of music, including Radio tuners...
Any help appreciated, and happy to sacrifice current setup and overwrite as needed.
(2016-11-25, 00:28)gazzauk71 Wrote: [ -> ]Hi There.
Upload your crashlog (see note #4, first post), then post your link.
Thanks Milhouse.
You pointed me in the direction of the logs, so I had a look at the stacks upwards and found reference to a thread each time for waveforhue, which is a visualiser for audio, that was set! I removed it and set to none. Surprise Music now plays through to the amp! I'll try a few other things to check, but I guess that that addon is no good in Kodi 17 or something and crashes the audio player!
Thanks again, any further issues as I'm going to use the box with your builds on as 'live', I'll let you know. I'll continue to update daily as much as possible. Cheers!
(2016-11-24, 09:16)Diodato Wrote: [ -> ] (2016-11-24, 01:53)Milhouse Wrote: [ -> ] (2016-11-23, 22:27)Diodato Wrote: [ -> ]Recent builds have this problem:
HW VAAPI decoding of PAL MPEG2 using software deinterlacing (Deinterlace/Bob) gives black screen during FF.
Doesn't happen on NTSC material.
Can you identify the first build with this issue?
This morning before heading for work did some tests. And I was too hasty to say "recent". I tried all the way up to build #1013 and I still get a black screen when FastForwarding, but not Rewinding. This evening I'll try with the 7.0.2 Jarvis or continue going backwards with the Krypton builds.
I use the Chromebox (CN60) so it's an Intel Celeron 2955U. No dual boot, HDMI output. My Kodi GUI is set to 1920x1080@50p with VAAPI HW decoding for all compressions alongside Yadif deinterlacing. The playback PAL files are just simple European Satellite MPEG2 captures (no recompression whatsoever) so just pure Transport streams. Happens as well with Program streams (VOB files) from DVD rips. Like I wrote before using one of the hardware VAAPI deinterlace methods doesn't cause the black screen when FF-ing, only one of the software ones. And only PAL 50i files. I'll also post a log file from the most recent build just in case.
I'm curios if anybody can reproduce what I'm experiencing. I believe I have narrowed down the conditions of when its happening.
I'm giving up. Tested up to build #0815 and the problem is always present. Guess I was always using different deinterlacing and was convinced I was using Yadif. Also I stand corrected the problem is present in NTSC files as well.
So HW VAAPI MPEG2 decoding with software deinterlacing (Interlaced/Bob) during FF gives black screen. At least in my case.
Tested the 7.0.2 Jarvis with the same files and the problem is
not present. Guess it's Krypton.
hi there,
Switched to LibreELEC (Krypton) v7.90.008 ALPHA two days ago and found FTDI FT232R based IR remote (e.g. MonCaso 312/320 case) is not working anymore. It used to work just fine with OpenElec.I followed this WiKi:
http://wiki.openelec.tv/index.php/MonCas...TDI_FT232R (actually written by me), which worked every time in OpenELEC but LibreELEC. Any one has any idea? Really appreciate any help.
The full system-log here:
http://sprunge.us/UNJR
-San
New LibreELEC.tv Krypton build #1125:
Generic
# uname -a
Linux NUC 4.8.10 #1 SMP Fri Nov 25 21:05:43 GMT 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161125210425-#1125-gf7dc40c [Build #1125]
# Kodi version
Based on tip of
LibreELEC.tv master (f7dc40c2,
XBMC master (c7bf547a,
- Includes latest kodi-theme-Estuary-next master (cbcee29a)
- Include [env] PR:805: merge /usr like it's 2012
Build Highlights:
- Merge /usr
- Official LE setttings icon Estuary skin support (known issue: currently two icons)
Build Details:
- LibreELEC.tv:
- systemd: update to 232 (PR:980, 2 commits, 8 files changed)
- Python: update to 2.7.12 (PR:958, 1 commit, 1 file changed)
- XBMC:
- Fix digital buttons with analog actions only sending one action (PR:10968, 1 commit, 2 files changed)
- Controller dialog: Fix Kodi actions sent after mapping final analog stick (PR:10966, 1 commit, 6 files changed)
- Fix inotify (PR:10978, 2 commits, 3 files changed)
- [PVR] Guide window: Fix crash (accessed grid index out of bounds). (PR:10984, 1 commit, 1 file changed)
- [listprovider] whitelist mediatypes which may get opened in VideoInfo… (PR:10949, 1 commit, 1 file changed)
- Fixed missing binary addons (PR:10967, 1 commit, 1 file changed)
- [PVR] fix recordings window subfolder listings (PR:10982, 2 commits, 2 files changed)
- move imagewidget out of grouplists (3daa9851)
- fix imagewidget pos for addonlauncher (9d300b9a)
- livetv main menu vis fix (8714393e)
- add weather to top bar (#120) (30e92481)
- cleanup (9da3ea38)
- move time sublabel out of grouplist (08309135)
- time sublabel alignment (b6ee0ff4)
- another imagewidget pos fix (a87503ae)
- dont show breadcrumbs sublabel for PVRGuide (edb26b4f)
- radiobutton for playlist shuffle button (c3874a19)
- width for eventlog grouplist (56daaa95)
- settings: add support for conditional LibreELEC settings icon (cbcee29a)
- Added: [env] PR:805: merge /usr like it's 2012
(2016-11-26, 00:14)MacUsers Wrote: [ -> ]hi there,
Switched to LibreELEC (Krypton) v7.90.008 ALPHA two days ago and found FTDI FT232R based IR remote (e.g. MonCaso 312/320 case) is not working anymore. It used to work just fine with OpenElec.I followed this WiKi: http://wiki.openelec.tv/index.php/MonCas...TDI_FT232R (actually written by me), which worked every time in OpenELEC but LibreELEC. Any one has any idea? Really appreciate any help.
The full system-log here: http://sprunge.us/UNJR
-San
The driver appears to be loading correctly. Can you post the output from "lsmod | sort" when run on OpenELEC and LibreELEC.
There have been several kernel updates since your OpenELEC version so please check nothing has changed there which may mean your guide is no longer accurate. In addition, LibreELEC is based on LIRC 0.9.4 while OpenELEC uses an older version. Are you able to confirm if input is being received on /dev/ttyUSB0?
It appears to be similar, apart from the size. Two outputs are pasted below:
=== LibreELEC ===============
LibreELEC (community) Version: 7.90.008
htpc:~ # lsmod|sort
Module Size Used by
8021q 17663 0
asus_atk0110 9217 0
bluetooth 288417 5 btrtl,btintel,btbcm,btusb
btbcm 5983 1 btusb
btintel 6584 1 btusb
btrtl 4128 1 btusb
btusb 27833 0
ftdi_sio 37732 1
snd_hda_codec 80804 2 snd_hda_intel,snd_hda_codec_hdmi
snd_hda_codec_hdmi 32481 1
snd_hda_core 42313 3 snd_hda_intel,snd_hda_codec,snd_hda_codec_hdmi
snd_hda_intel 21933 1
snd_hwdep 5354 1 snd_hda_codec
usbserial 20761 3 ftdi_sio
htpc:~ # lsusb|grep FT232
Bus 003 Device 002: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
=== OpenELEC ================
OpenELEC (official) Version: 6.95.3
htpc:~ # lsmod|sort
Module Size Used by
8021q 15457 0
asus_atk0110 8506 0
bluetooth 237339 5 btbcm,btrtl,btusb,btintel
btbcm 5471 1 btusb
btintel 5560 1 btusb
btrtl 3488 1 btusb
btusb 25197 0
ftdi_sio 35761 1
snd_hda_codec 70140 2 snd_hda_codec_hdmi,snd_hda_intel
snd_hda_codec_hdmi 31862 1
snd_hda_core 28290 3 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel
snd_hda_intel 20100 3
snd_hwdep 4819 1 snd_hda_codec
usbserial 18801 4 ftdi_sio
What else I can check to confirm if the input is being received on /dev/ttyUSB0 ??
-San
(2016-11-26, 01:34)MacUsers Wrote: [ -> ]What else I can check to confirm if the input is being received on /dev/ttyUSB0 ??
You can try build #1125x which has CONFIG_USB_MON=m enabled:
Generic
With build #1125x you can enable usbmon and see what data is coming from the FTDI USB device:
modprobe usbmon
cat /sys/kernel/debug/usb/usbmon/3u | grep ":002:"
where 3 is the bus, and 002 is the device (check the current FTDI bus/device using lsusb)
Then press some buttons on the remote and see what appears - it might be gibberish, but this is the best I can suggest (there might be better options from other people).
This page may be helpful:
https://www.kernel.org/doc/Documentation/usb/usbmon.txt
I updated to #1125 and the option to enable Bluetooth was missing in the LibreELEC settings. My Harmony remote, connected through Bluetooth, would not work. I went back to #1124 and the option was present and remote working again.
(2016-11-26, 08:02)cableant Wrote: [ -> ]I updated to #1125 and the option to enable Bluetooth was missing in the LibreELEC settings. My Harmony remote, connected through Bluetooth, would not work. I went back to #1124 and the option was present and remote working again.
Thanks, Bluetooth also seems to be non-functional on RPi3 too. Best guess right now would be something wonky with the /usr
PR:805 - will try and get fixed for the next build.
(2016-11-26, 08:30)Milhouse Wrote: [ -> ] (2016-11-26, 08:02)cableant Wrote: [ -> ]I updated to #1125 and the option to enable Bluetooth was missing in the LibreELEC settings. My Harmony remote, connected through Bluetooth, would not work. I went back to #1124 and the option was present and remote working again.
Thanks, Bluetooth also seems to be non-functional on RPi3 too. Best guess right now would be something wonky with the /usr PR:805 - will try and get fixed for the next build.
Could have something to do with the settings add-on, I'll have a look
Edit: sorted it. Will be fixed in the next build
(2016-11-26, 03:23)Milhouse Wrote: [ -> ]You can try build #1125x which has CONFIG_USB_MON=m enabled: Generic
With #1125x installed, I get this sort of scrolling output, with or without pressing any key:
htpc:~ # modprobe usbmon
htpc:~ # cat /sys/kernel/debug/usb/usbmon/3u|grep ":002:"
ffff88012a208600 1918750569 C Bi:3:002:1 0 2 = 0160
ffff88012a208600 1918750579 S Bi:3:002:1 -115 512 <
ffff88012a208540 1918751572 C Bi:3:002:1 0 2 = 0160
ffff88012a208540 1918751585 S Bi:3:002:1 -115 512 <
ffff88012a208600 1918752567 C Bi:3:002:1 0 2 = 0160
ffff88012a208600 1918752572 S Bi:3:002:1 -115 512 <
ffff88012a208540 1918753568 C Bi:3:002:1 0 2 = 0160
irw still cannot capture anything but It is telling us anything good?
-S
New LibreELEC.tv Krypton build #1126:
Generic
# uname -a
Linux NUC 4.8.10 #1 SMP Sat Nov 26 21:08:13 GMT 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161126210614-#1126-g1a9b633 [Build #1126]
# Kodi version
Based on tip of
LibreELEC.tv master (1a9b6336,
XBMC master (3067efc4,
- Includes latest kodi-theme-Estuary-next master (74fe9df5)
- Includes latest addons: inputstream.mpd (2d8ddb6f, +1), inputstream.rtmp (55437ac7, +2), inputstream.smoothstream (b15e6e60, +1), peripheral.joystick (d09e0c60, +26), pvr.argustv (7d3bdba7, +2), pvr.demo (9ebc62c6, +2), pvr.dvblink (42207a03, +2), pvr.dvbviewer (2449df9a, +2), pvr.filmon (f3c57b88, +2), pvr.hdhomerun (ef45d3f7, +5), pvr.hts (c171114c, +5), pvr.iptvsimple (d69778ea, +3), pvr.mediaportal.tvserver (8ba6a797, +18), pvr.mythtv (f00d3ef8, +8), pvr.nextpvr (fe85f2a3, +2), pvr.njoy (3a322763, +2), pvr.pctv (e829beb1, +2), pvr.stalker (fd800fdb, +2), pvr.vbox (3dc55507, +32), pvr.vdr.vnsi (4b06d83e, +4), pvr.vuplus (d2c54427, +2), pvr.wmc (bffb41d4, +2)
- Include [env] patch: ffmpeg: update to 3.1.5-Krypton-Beta6
- Include [env] patch: Generic: enable USB_MON=m
- Include [env] patch: merged upstream
Build Highlights:
- VideoPlayer: change time parameter of SeekTime from int to double
- ffmpeg: update to 3.1.5-Krypton-Beta6
Build Details:
- LibreELEC.tv:
- docker: update to 1.12.3 (PR:981, 1 commit, 4 files changed)
- system-tools: add nmon (PR:979, 2 commits, 3 files changed)
- script.config.vdr: update to 100 (PR:986, 1 commit, 4 files changed)
- XBMC:
- [PVR]Small fixes and optimizations (PR:10986, 2 commits, 6 files changed)
- VideoPlayer: change time parameter of SeekTime from int to double (PR:10985, 3 commits, 29 files changed)
- inputstream.mpd:
- inputstream.rtmp:
- inputstream.smoothstream:
- inputstream api version bump to 1.0.6 (b15e6e60)
- pvr.argustv:
- pvr.demo:
- pvr.dvblink:
- pvr.dvbviewer:
- pvr.filmon:
- pvr.hdhomerun:
- pvr.hts:
- pvr.iptvsimple:
- pvr.mediaportal.tvserver:
- pvr.mythtv:
- pvr.nextpvr:
- pvr.njoy:
- pvr.pctv:
- pvr.stalker:
- pvr.vbox:
- pvr.vdr.vnsi:
- pvr.vuplus:
- pvr.wmc:
- Added: [env] patch: ffmpeg: update to 3.1.5-Krypton-Beta6
- Added: [env] patch: Generic: enable USB_MON=m
- Added: [env] patch: merged upstream
