(2016-11-29, 07:34)Milhouse Wrote: [ -> ] (2016-11-29, 05:28)_matt_ Wrote: [ -> ]Sorry, Milhouse. Here it is (hopefully): http://sprunge.us/AZXe
Thanks. What version of the screensaver.shadertoy add-on are you using? I suspect the version in the repo may be incompatible, and the last version I uploaded on 1 April certainly is, so it could just be crashing due to some binary incompatibility.
I've uploaded a new version of screensaver.shadertoy here - please install this new #1128 version and see if it works any better.
If it continues to crash, install this debug-enabled build #1128y as this will provide a more informative crashlog.
If you also plan on using visualization.shadertoy be aware that this add-on crashes (crashlog) quite regularly and as there's no way to report issues to the developer my advice is just don't use it.
Looks like I had v1.0.10 installed. I tried the new version and it triggers the same instant crashes.
I don't have plans to actually use this screensaver, especially given your advice, but after I get that debug build downloaded I'll post a crashlog and whatever else I can to help.
Can anyone else confirm if the "Install from zip file" widget/submenu feature is not working?
Clicking does nothing on the latest nightly.
"Install from repo" widget/sub menu works fine
EDIT:
"Install from zip" works fine from inside the Add-ons menu.
docwra Can confirm, the home screen "Install from zip file" button in the categories submenu does nothing here.
(2016-11-29, 21:21)_matt_ Wrote: [ -> ]@docwra Can confirm, the home screen "Install from zip file" button in the categories submenu does nothing here.
It's a known issue with the latest skin.
New LibreELEC.tv Krypton build #1129:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.8.11 #1 SMP Tue Nov 29 21:10:15 GMT 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20161129210859-#1129-ga26112d [Build #1129]
# Kodi version
(17.0-BETA6 Git:17.0-beta5-e92818a). Platform: Linux x86 64-bit
Based on tip of
LibreELEC.tv master (a26112df,
changelog) and tip of
XBMC master (068add48,
- Includes latest kodi-platform master (c8188d82)
- Includes latest kodi-theme-Estuary-next master (c0d1c274)
- Includes latest libcec master (209884d6, ahead +60)
- Includes latest libnfs master (a2b37349, ahead +2)
- Includes latest p8-platform master (2d90f986, ahead +9)
- Includes latest addons: inputstream.adaptive (7f57246b), inputstream.rtmp (55437ac7, +2), peripheral.joystick (d09e0c60, +26), pvr.argustv (7d3bdba7, +2), pvr.demo (9ebc62c6, +2), pvr.dvblink (42207a03, +2), pvr.dvbviewer (2449df9a, +2), pvr.filmon (ca709b90, +3), pvr.hdhomerun (ef45d3f7, +5), pvr.hts (4f406f4c, +6), pvr.iptvsimple (d69778ea, +3), pvr.mediaportal.tvserver (8ba6a797, +18), pvr.mythtv (b22cfa0e, +10), pvr.nextpvr (fe85f2a3, +2), pvr.njoy (3a322763, +2), pvr.octonet (8549a31c), pvr.pctv (e829beb1, +2), pvr.stalker (fd800fdb, +2), pvr.vbox (3dc55507, +32), pvr.vdr.vnsi (4b06d83e, +4), pvr.vuplus (d2c54427, +2), pvr.wmc (bffb41d4, +2)
- Exclude [env] kodi-999.01-build-lirc-for-rpi.patch: merged upstream
- Exclude [env] libcec-PR208.patch: merged upstream (libcec)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: ffmpeg: update to 3.1.6-Krypton-Beta6
- Include [env] patch: fix LE PR:768 after Kodi PR:10973
- Include [env] patch: kodi-binary-addons: pvr.octonet initial package
- Include [env] patch: linux: use in-tree rtl8192cu for RPi/RPi2
- Include [env] patch: visualization.shadertoy: update to 1.1.4
- Include [env] patch: merged upstream
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] PR:768: kodi use cmake
- Include [env] PR:805: merge /usr like it's 2012
- Include [env] PR:968: busybox: add getedid script
- Include [env] PR:994: kodi-binary-addons: inputstream.adaptive replaces inputstream.mpd and inputstream.smoothstream
- Include [env] PR:997: xorg-server: add Synaptics driver if using evdev
- Include [env] PR:1001: alsa-lib: add HiFiBerry config
- Include [pkg] patch: i965: Add some APL and KBL SKU strings (mesa)
- Include [pkg] PR:39: use prettyname_regex to show shortname in update menu (service.libreelec.settings)
- Include [pkg] PR:249: Fix ass_set_cache_limits() to work with composite cache (libass)
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
Build Highlights:
- kodi-theme-Estuary: updated default background colour (and other changes)
Build Details:
- LibreELEC.tv:
- samba: fix allocation/size on disk issues reported by Windows 8.x+ (PR:951, 1 commit, 1 file changed)
- XBMC:
- Controller fixes (PR:10630, 12 commits, 27 files changed)
- aml: Support for 4K H264 on S905X (PR:10944, 2 commits, 4 files changed)
- rbp: Don't close the display here it should be closed by the opener (PR:11006, 1 commit, 1 file changed)
- fixed: tighten vcd .dat file checks to avoid unwanted filtering (PR:11004, 1 commit, 1 file changed)
- remove unused variables / members (PR:10980, 1 commit, 14 files changed)
- Tweaked backgrounds (PR:137, 1 commit, 19 files changed)
- videoinfo: increase helperlabel width (3813fc0c)
- settingscategory levels button (3ac2bfd2)
- streamline playlist window (1120f02f)
- videoinfo grouping (27528adc)
- eventlog tweaks (b8d69931)
- eventlog work (9e82c6bb)
- tweak fav animations to be consistent with rest (c0d1c274)
- pvr.filmon:
- Fix EPG after API change (PR:59, 1 commit, 3 files changed)
- Added: [env] PR:1001: alsa-lib: add HiFiBerry config
(2016-11-22, 01:34)valdi74 Wrote: [ -> ] (2016-11-22, 01:22)lrusak Wrote: [ -> ]Ah, because we don't include the synaptics driver
Why? :-)
or
Maybe there is another way to handle touchpad without synaptics?
valdi74 can you confirm your Synaptics touchpad is now working as expected since build #1128? Thanks.
(2016-11-27, 12:33)MacUsers Wrote: [ -> ] (2016-11-27, 00:34)Milhouse Wrote: [ -> ]New LibreELEC.tv Krypton build #1126: Generic
Any improvement/fix was added for FTDI FT232R based IR receiver?
(Doesn't look like form the change log but just wanted to confirm)
why are you using the mplay2 driver instead of the ftdi driver?
(2016-11-30, 00:25)Milhouse Wrote: [ -> ]Build Highlights:
<shudder> hope that's not the final selection, the previous background color/color scheme was much, much better
(2016-11-29, 17:23)_matt_ Wrote: [ -> ]ShaderToy crashlog from #1128y: http://sprunge.us/djcB
Thanks, I'll see what we can do - it may need a new source for the add-on.
(2016-11-30, 01:53)lrusak Wrote: [ -> ]why are you using the mplay2 driver instead of the ftdi driver?
In OpenELEC, it works only with mplay2, so was using the same. I did try ftdi driver as well but the same result. Do you need logs using ftdi ?
-San
(2016-11-30, 08:28)MacUsers Wrote: [ -> ] (2016-11-30, 01:53)lrusak Wrote: [ -> ]why are you using the mplay2 driver instead of the ftdi driver?
Here is the log with ftdi driver:
https://www.dropbox.com/s/1h46wyrvc3vnxw...i.zip?dl=0
One thing to mention: when I run the command (as part of the "autostart.sh") I get this warning:
htpc:~ # /usr/sbin/lircd -H ftdi -d /dev/ttyUSB0 -u -o /run/lirc/lircd -P /run/lirc/lircd.pid /storage/.config/ft232_remote.conf
Warning: cannot open /etc/lirc/lirc_options.conf
The very same warning I get using "mplay2" driver as well.
-S
(2016-12-01, 01:00)MacUsers Wrote: [ -> ]One thing to mention: when I run the command (as part of the "autostart.sh") I get this warning:
Upload the content of /storage/.config/ft232_remote.conf with the following:
cat /storage/.config/ft232_remote.conf | pastebinit
and paste the link.
(2016-12-01, 01:51)Milhouse Wrote: [ -> ]Upload the content of /storage/.config/ft232_remote.conf with the following:
http://sprunge.us/RKKC
It's exactly the same one from OpenELEC
-S
