Milhouse, is there any chance to have an updated build for us Braswell owners (who have had lockups and therefore have to use builds with the older kernel versions (505x)) with the below mentioned patch included?
PR:9778: fix PluginDirectory - fix for YouTube, Quasar and TuneIn add-on hangs
(2016-05-08, 22:05)Milhouse Wrote: [ -> ]This is probably not a Kodi issue, but instead a kernel and/or GPU driver issue - others have seen it, and I believe it's been reported upstream as a bug.
When you get the blank screen, try running the following commands and paste the output:
dmesg | pastebinit
journalctl -a | pastebinit
cat /storage/.kodi/temp/kodi.log | pastebinit
vainfo | pastebinit
cat /var/log/Xorg.0.log | pastebinit
Hi Milhouse,
Please find the output below (it is performed in blank screen state):
LibreELEC (community) Version: devel-20160506005756-#0505x-ga066054
LibreELEC git: a066054ab61f194dd53a846750f11f24eab498af
LibreELEC:~ # dmesg | pastebinit
http://sprunge.us/fiVX
LibreELEC:~ # journalctl -a | pastebinit
http://sprunge.us/IaBL
LibreELEC:~ # cat /storage/.kodi/temp/kodi.log | pastebinit
http://sprunge.us/MOiH
LibreELEC:~ # vainfo | pastebinit
libva info: VA-API version 0.39.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/va/i965_drv_video.so
libva info: Found init function __vaDriverInit_0_39
libva info: va_openDriver() returns 0
http://sprunge.us/HIUa
LibreELEC:~ # cat /var/log/Xorg.0.log | pastebinit
http://sprunge.us/fiha
Thanks for your help!
Milhouse did you see my crash log switching audio profile ?
have no sound on my HTPC with AMD Athlon 5350 and Build #0508.
Is there a solution for?
this ok?
15:27:21 47.125256 T:140526655182592 NOTICE: Creating audio stream (codec id: 86019, channels: 2, sample rate: 48000, no pass-through)
15:27:21 47.125290 T:140526655182592 ERROR: Process - failed to create audio renderer
No not okay ... it tells absolutely nothing ... we need a complete
Debug Log
Sehe gerade du kommst Deutschland dann können wir ja in deutsch schreiben.
Reicht es wenn ich nur Debug logging aktiviere oder muss ich auch Komponentenspezifisch aktivieren?
Habe schon raus gefunden das es nur mit Audio über HDMI auftritt nicht aber über SPDIF.
Hier im Forum wird englisch gesprochen
(2016-05-09, 09:07)Raitsa Wrote: [ -> ]Milhouse, is there any chance to have an updated build for us Braswell owners (who have had lockups and therefore have to use builds with the older kernel versions (505x)) with the below mentioned patch included?
I'll publish an #0509x tonight as PR9778 has been updated to fix remaining add-on issues, but this will be the final build based on the 4.4.7 kernel.
(2016-05-09, 13:05)Roby77 Wrote: [ -> ]@Milhouse did you see my crash log switching audio profile ?
If you mean
this post that's not a crash log.
As you're using an addon to change profiles I would advise testing again with tonight's #0509(x) build now that PR9778 has been updated and hopefully fixed any remaining deadlock-type issues, which could be what you are experiencing.
(2016-05-09, 20:03)Milhouse Wrote: [ -> ] (2016-05-09, 09:07)Raitsa Wrote: [ -> ]Milhouse, is there any chance to have an updated build for us Braswell owners (who have had lockups and therefore have to use builds with the older kernel versions (505x)) with the below mentioned patch included?
So hope that rc 7 or next solve gpu freeze
Edit: let's try 509x to check audio switch problem
Thank you
unfortunatly librelec master has problem with loading shared lib "libencvorbis" or similar , but in dmesg i could also seen an kernel panic with rc7 on braswell
(2016-05-09, 21:49)the-dreamer Wrote: [ -> ]unfortunatly librelec master has problem with loading shared lib "libencvorbis" or similar
Could you provide more details, such as a debug log, and how to reproduce?
New LibreELEC.tv Krypton build #0509:
Generic
(Supercedes previous build)
# uname -a
Linux LibreELEC 4.6.0-rc7 #1 SMP Mon May 9 21:07:21 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160509210600-#0509-g796a577 [Build #0509]
Based on tip of
LibreELEC.tv master (796a5777,
changelog) and tip of
XBMC master (ab6ece74,
- Includes FernetMenta "VideoPlayer" patches
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest kodi-platform master (92583ef9, ahead +2)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (b3c41060, ahead +15)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: adsp.basic (5cf12e83), adsp.biquad.filters (af575f3d), adsp.freesurround (6dc533be), asplib (da66f517), inputstream.mpd (2cb2eab2), inputstream.smoothstream (352b14eb), peripheral.joystick (76b7c40a), pvr.argustv (3a4eccd4), pvr.demo (f4950d3d), pvr.dvblink (fd6f92d2, +1), pvr.dvbviewer (77771ddc), pvr.filmon (0b906770), pvr.hdhomerun (9b511856), pvr.hts (8929c220), pvr.iptvsimple (373b525d), pvr.mediaportal.tvserver (4723f6de), pvr.mythtv (11b70a50), pvr.nextpvr (fa13c7d0), pvr.njoy (aea0b8ab), pvr.pctv (fc80e0f7), pvr.stalker (c1d8ee73), pvr.vbox (31748578), pvr.vdr.vnsi (5e83dd8e, +3), pvr.vuplus (ec652b92), pvr.wmc (b1d7a40a)
- Includes commits from xbmc/master, ahead +5 (FernetMenta)
- Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
- Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: xf86-video-intel: bump to 3fafabe
- Include [env] patch: Fix SIGTERM patch after PR9748
- Include [env] patch: Add extra headers needed by 3D BD MVC
- Include [env] patch: Bump libbluray - include MVC support
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Enable other binary addons
- Include [env] PR:325: linux: update to 4.6-rc7
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] dd81c2f1: [librtmp] Update to 15-Dec-2015 from http://stream-recorder.com/forum/customi...16103.html (kodi)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9576: [network] improvements to the webserver implementation
- Include [pkg] PR:9778: fix PluginDirectory
Build Highlights:
- NOTE: DVD playback remains temporarily disabled
- New 4.6.0-rc7 kernel
- Updated PR9778, should fix remaining add-on issues
Build Details:
- LibreELEC.tv:
- systemd: fix machine-id uniqueness (PR:276, 1 commit, 2 files changed)
- kodi: update appliance.xml after settings reshuffle. (PR:326, 1 commit, 1 file changed)
- XBMC:
- fix frameMoveGuard intruduced here by 82218b570c8d5e7d2ace70cbe71f24e… (PR:9782, 1 commit, 1 file changed)
- Added: [env] PR:325: linux: update to 4.6-rc7
