Still freezing on Braswell....
Gesendet von meinem LG-D855 mit Tapatalk
All of you - bump the bug reports, post new logs ... it needs more traffic on freedesktop or 4.6 will suck :-)
Build #0509x:
Generic
Same as #0509 but with 4.4.7 kernel.
I got this weird issue were during playback at random points the video gets choppy and a lot of frames are dropped. Pause and Unpause one or two times and the playback is normal. I tried to get a log but any attempt to reproduce it with log level enabled failed. Both on my chromebox and the 2820 NUC.
Try harder :-) without a log we cannot help
It's somewhere bug in this thread. I did not subscribe, so don't know it out of my head. File a new one if in doubt - it needs fixing upstream. If you have too much time: #intel-gfx is a place to directly post the issue after filing it. As 4.6 is unusable on SKL / BSW and so on - it should be high priority.
(2016-05-10, 00:43)john.cord Wrote: [ -> ]I got this weird issue were during playback at random points the video gets choppy and a lot of frames are dropped. Pause and Unpause one or two times and the playback is normal. I tried to get a log but any attempt to reproduce it with log level enabled failed. Both on my chromebox and the 2820 NUC.
Same here with chromebox (2955U) and kernel 4.6. No issues with kernel 4.4.7 build.
I'll provide logs in the evening when I'm back at home.
(2016-05-10, 08:19)the-dreamer Wrote: [ -> ]@milhouse: here is the log with git master from this morning: http://sprunge.us/POBT
kodi even don't start and therefore there is no kodi.log. last week i did a clean build with 4.6. kernel and new libreelec logo and saw first time the gpu freezes. kodi was starting.
i am using some of your patches for addons http://nmacleod.com/public/oebuild/patch...t_adsp.txt and http://nmacleod.com/public/oebuild/patch...addons.txt
here my git status: http://sprunge.us/dXcM
As this is your own custom build not mine, and nobody knows how it's been built other than yourself, the LE forum would be a better place to ask for support as it's 100% OT for this thread.
However as you've asked... run the following:
ldd /usr/bin/pulseaudio | pastebinit
ldd /usr/lib/kodi/kodi.bin | pastebinit
If either binary lists libvorbisenc.so.2 then my guess is you've not done a clean build for a while, certainly not since libvorbis switched to being built statically after
PR:286. You probably have libvorbisenc.so lying around in your toolchain, but not in your image.
If a clean build doesn't fix your problem, please start a new thread (the LE forum would be the best place).
@milhouse: PR:286 would fit to my problem. both bins has libvorbisenc. indeed my clean build was before this PR. sorry for that noise. rebuild is started. will start tomorrow a new thread if problem persist. thx.
509x is an awesome build for Braswell owners, it fixed all remaining add-on issues atleast in my setup.
BIG thanks to Milhouse once again for all the help & effort
#0509x seemed unusually in English input,Type or delete a letter,shows busy spinning。
(2016-05-10, 08:51)wwessel Wrote: [ -> ] (2016-05-10, 00:43)john.cord Wrote: [ -> ]I got this weird issue were during playback at random points the video gets choppy and a lot of frames are dropped. Pause and Unpause one or two times and the playback is normal. I tried to get a log but any attempt to reproduce it with log level enabled failed. Both on my chromebox and the 2820 NUC.
OK, had time to test it earlier:
http://sprunge.us/DPUI
The behaviour occurs between 11:59:51 and 12:00:27
Latest build is OK on SkyLake NUC. So 4.6 kernel seems OK for SkyLake. But I know there is lot's planned for 4.7 kernel. So let's see
