(2016-05-11, 23:57)Milhouse Wrote: [ -> ] (2016-05-11, 23:25)Roby77 Wrote: [ -> ]But braswell gpu is different from Skylake gpu..or not ?
Yes they are different, although also very much the same right now in that they're both pretty much unusable with 4.6-rc.
One can only hope Intel will at least get Braswell working reliably with 4.6.
So I should just not bother until a new linux kernel?
(2016-05-12, 01:50)smitopher Wrote: [ -> ]So I should just not bother until a new linux kernel?
Or until a patch surfaces that claims to fix whatever bug is in the current 4.6-rc7 kernel.
(2016-05-11, 20:13)wwessel Wrote: [ -> ]EDIT: I forgot to mention that I've this issue only with SD material. With HD all works flawlessly. So maybe it's an upscaler issue?
ok, for me it is with HD Material but comparing the logs it is a different issue...
New LibreELEC.tv Krypton build #0512:
Generic
(Supercedes previous build)
# uname -a
Linux LibreELEC 4.6.0-rc7 #1 SMP Thu May 12 21:07:41 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160512210538-#0512-gbbc72bc [Build #0512]
Based on tip of
LibreELEC.tv master (bbc72bc8,
changelog) and tip of
XBMC master (346c3740,
- Includes FernetMenta "VideoPlayer" patches
- Includes latest kodi-platform master (92583ef9, ahead +2)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (b3c41060, ahead +15)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: adsp.basic (5cf12e83), adsp.biquad.filters (af575f3d), adsp.freesurround (6dc533be), asplib (da66f517), inputstream.mpd (2cb2eab2), inputstream.smoothstream (352b14eb), peripheral.joystick (76b7c40a), pvr.argustv (3a4eccd4), pvr.demo (f4950d3d), pvr.dvblink (fd6f92d2, +1), pvr.dvbviewer (77771ddc), pvr.filmon (0b906770), pvr.hdhomerun (9b511856), pvr.hts (8929c220), pvr.iptvsimple (373b525d), pvr.mediaportal.tvserver (4723f6de), pvr.mythtv (11b70a50), pvr.nextpvr (fa13c7d0), pvr.njoy (aea0b8ab), pvr.pctv (fc80e0f7), pvr.stalker (6b9e0952, +2), pvr.vbox (31748578), pvr.vdr.vnsi (5e83dd8e, +3), pvr.vuplus (ec652b92), pvr.wmc (b1d7a40a)
- Includes commits from xbmc/master, ahead +6 (FernetMenta)
- Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
- Exclude [env] kodi-999.10-aarch64-support.patch: Merged upstream
- Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: xf86-video-intel: bump to 3fafabe
- Include [env] patch: Fix SIGTERM patch after PR9748
- Include [env] patch: Add extra headers needed by 3D BD MVC
- Include [env] patch: Enable custom framebuffer resolution
- Include [env] patch: Bump libbluray - include MVC support
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Enable other binary addons
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] dd81c2f1: [librtmp] Update to 15-Dec-2015 from http://stream-recorder.com/forum/customi...16103.html (kodi)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9576: [network] improvements to the webserver implementation
- Include [pkg] PR:9794: Use separators from language addon
- Include [pkg] PR:9795: fixed: Caching of quasi-internet streams like webdav was broken
- Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
Build Highlights:
- NOTE: DVD playback remains temporarily disabled
- Minors
Build Details:
- LibreELEC.tv:
- Sundtek-mediatv: use ARM64 installer for aarch64 (PR:337, 1 commit, 1 file changed)
- distro-tool: Ignore text/html responses (PR:335, 1 commit, 1 file changed)
- XBMC:
- VideoPlayer: Different accurate value for omxplayer_mode has no effect (PR:9798, 1 commit, 1 file changed)
- Fix some compiler warnings (PR:9780, 3 commits, 8 files changed)
- [depends] libpng 1.6.21 (PR:9783, 1 commit, 2 files changed)
- mmalrenderer: Avoid creating presenting thread when it is not required (PR:9797, 1 commit, 1 file changed)
- [omxplayer] Some minor fixes (PR:9799, 3 commits, 3 files changed)
- rbp: Fix possible leak in rendercapture interface (PR:9800, 1 commit, 1 file changed)
- mmalcodec: Set initial aligned height explicitly to avoid multiple reconfigures in renderer (PR:9801, 1 commit, 1 file changed)
- [addon] Reworked python docs (PR:9674, 5 commits, 35 files changed)
- update codedocs generation (82a4a82b)
- pvr.stalker:
- http refactor (PR:54, 2 commits, 6 files changed)
- Added: [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
Tested latest Build. Same issue
log -->
http://pastebin.com/Fzn4YLUj
Started Playback. Plaback normal for several mins then choppy blackback and dropped frames.
Switched back to 502, no issue so far
Please disable the Joystick Addon.
New LibreELEC.tv Krypton build #0513:
Generic
# uname -a
Linux LibreELEC 4.6.0-rc7 #1 SMP Fri May 13 21:06:46 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160513210443-#0513-g642cf03 [Build #0513]
Based on tip of
LibreELEC.tv master (642cf033,
XBMC master (9c94cb94,
- Includes latest addons: adsp.basic (5cf12e83), adsp.biquad.filters (af575f3d), adsp.freesurround (6dc533be), asplib (da66f517), inputstream.mpd (2cb2eab2), inputstream.smoothstream (352b14eb), peripheral.joystick (76b7c40a), pvr.argustv (3a4eccd4), pvr.demo (f4950d3d), pvr.dvblink (fd6f92d2, +1), pvr.dvbviewer (a603c46a, +2), pvr.filmon (0b906770), pvr.hdhomerun (9b511856), pvr.hts (8929c220), pvr.iptvsimple (373b525d), pvr.mediaportal.tvserver (4723f6de), pvr.mythtv (11b70a50), pvr.nextpvr (fa13c7d0), pvr.njoy (aea0b8ab), pvr.pctv (fc80e0f7), pvr.stalker (185baf63, +4), pvr.vbox (31748578), pvr.vdr.vnsi (5e83dd8e, +3), pvr.vuplus (ec652b92), pvr.wmc (b1d7a40a)
Build Highlights:
- Minors
Build Details:
- LibreELEC.tv:
- NOOBS: PiZero Rev2 support (PR:339, 1 commit, 1 file changed)
- XBMC:
- [exif] Fix for out-of-memory errors with large numbers of jpegs (PR:9796, 1 commit, 1 file changed)
- fixed: Caching of quasi-internet streams like webdav was broken (PR:9795, 1 commit, 1 file changed)
- [cmake/linux] Add option for LIRC (PR:9805, 1 commit, 2 files changed)
- pvr.dvbviewer:
- Fix includes (PR:40, 2 commits, 8 files changed)
- pvr.stalker:
- Fix includes (PR:60, 2 commits, 5 files changed)
Using the 0513 build on my chromebox. So far so good.
ive got little problems with live tv, passthrough and dolby digital (ac3 5.1) described
here .
Does somebody have any hints for me!?
thx in advance
olli
(2016-05-13, 06:29)fritsch Wrote: [ -> ]Please disable the Joystick Addon.
i did this and will test the latest build in the evening...
(2016-05-14, 14:32)debutanker Wrote: [ -> ]ive got little problems with live tv, passthrough and dolby digital (ac3 5.1) described here .
thx in advance
olli
I don't do live tv with kodi but I seem to remember pass through not being supported currently with the latest audio changes. Maybe @
fritsch can comment or maybe I am nuts
Is AirPlay working with your build?
(2016-05-14, 21:09)dirtydesaster Wrote: [ -> ]Is AirPlay working with your build?
Don't know, as I don't use it. Maybe an iDevice user can confirm.
Just tried it, it picks it up as a device but nothing goes to the screen (9.3.2)
(2016-05-14, 22:44)porkchop999 Wrote: [ -> ]Just tried it, it picks it up as a device but nothing goes to the screen (9.3.2)
Thanks. If AirPlay or some other iDevice technology isn't working in these test builds please start a new thread or post in one of the existing threads already discussing such problems. The usual reason for breakage is the latest iOS release, and is unlikely to be specific to these test builds.
