(2016-05-20, 22:03)ragnaroek Wrote: [ -> ]Hi,
I did some research with clean LibreElec builds, only the stock addons enabled,
the builds #0330 to #0403 are absolutely fine, no problems with my 100% CPU issue,
with #0405, I'm getting a kernel panic,
with #0406 to #0519, I have the 100% CPU issue, but only on systems with a Nvidia GPU,
no issues with the builds, on systems with a Intel IGPU, expect #0405.
Right with " DEBUG: ------ Window Init (VideoFullScreen.xml) ------ " one CPU core is fully locked at 100%,
on Nvidia systems, init a other window like DEBUG: ------ Window Init (MyVideoNav.xml) ------, immediately
drops the CPU usage to ~10% - 12%.
Was there a major change in Kodi, between f6264876 and ce28cb6, that could cause this?
I can reproduce this on all Kodi 17 installations, Arch, Suse, Ubuntu ..., from ce28cb6 on,
VideoFullScreen is causing my issue on Nvidia system, and no problems with Intel system.
I also cross checked this two of my mates, with the same result.
Or maybe I'm absolutely stupid and doing something wrong.
I found a posting on a German Kodi forum, that chap
is also digging in that issue.
Best regards
OK, I'm able to reproduce this on my Revo 3700 with ION2.
I do remember now that LE #0405 was built incorrectly using popcornmix linux and newclock5 commits on top of the normal x86 linux and kodi commits - this likely explains the kernel panic.
I've also reproduced the high-CPU load behaviour in OE:
OE #0402 is "normal", while
OE #0410 shows increased CPU loading on one CPU core.
OE #0402 watching a video, full screen:
Mem: 1074716K used, 965672K free, 206484K shrd, 68904K buff, 593148K cached
CPU0: 2.6% usr 3.0% sys 1.6% nic 92.8% idle 0.0% io 0.0% irq 0.0% sirq
CPU1: 6.4% usr 6.6% sys 0.0% nic 86.5% idle 0.0% io 0.0% irq 0.4% sirq
CPU2: 1.6% usr 0.8% sys 0.0% nic 96.9% idle 0.4% io 0.0% irq 0.2% sirq
CPU3: 8.1% usr 9.7% sys 0.0% nic 81.7% idle 0.0% io 0.0% irq 0.4% sirq
Load average: 0.79 0.46 0.18 2/189 1067
PID PPID USER STAT VSZ %VSZ CPU %CPU COMMAND
845 839 root S 2671m133.5 1 10.1 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
1065 1060 root R 7732 0.3 1 0.0 top
289 2 root SW 0 0.0 1 0.0 [kworker/1:4]
249 1 root S < 212m 10.6 1 0.0 /usr/bin/pulseaudio --system
444 442 root S 99m 4.9 1 0.0 /usr/bin/Xorg -nolisten tcp vt01 -s 0 -noreset -allowMouseOpenFail -config /storage/.config/xorg.conf -ignoreABI
468 1 root S 29148 1.4 0 0.0 /usr/bin/smbd --configfile=/run/samba/smb.conf
418 1 root S 27144 1.3 1 0.0 /usr/bin/nmbd --configfile=/run/samba/smb.conf
700 1 root S 23836 1.1 0 0.0 /usr/bin/fluxbox
471 1 root S 19604 0.9 3 0.0 /usr/bin/wpa_supplicant -u
OE #0410 watching the same video, full screen:
Mem: 1055664K used, 984724K free, 208084K shrd, 67384K buff, 600168K cached
CPU0: 26.8% usr 72.7% sys 0.0% nic 0.0% idle 0.0% io 0.0% irq 0.3% sirq
CPU1: 5.4% usr 4.6% sys 1.7% nic 87.7% idle 0.3% io 0.0% irq 0.0% sirq
CPU2: 0.8% usr 0.6% sys 0.0% nic 98.5% idle 0.0% io 0.0% irq 0.0% sirq
CPU3: 5.5% usr 2.1% sys 0.0% nic 92.3% idle 0.0% io 0.0% irq 0.0% sirq
Load average: 1.22 0.55 0.21 5/187 997
837 832 root R 2675m133.7 0 28.6 /usr/lib/kodi/kodi.bin --standalone -fs --lircdev /run/lirc/lircd
412 1 avahi S 19116 0.9 1 0.0 avahi-daemon: running [OpenELEC.local]
990 987 root R 7732 0.3 1 0.0 top
149 2 root SW 0 0.0 1 0.0 [jbd2/sda2-8]
251 1 root S < 212m 10.6 3 0.0 /usr/bin/pulseaudio --system
424 422 root S 113m 5.6 2 0.0 /usr/bin/Xorg -nolisten tcp vt01 -s 0 -noreset -allowMouseOpenFail -config /storage/.config/xorg.conf -ignoreABI
598 1 root S 29148 1.4 2 0.0 /usr/bin/smbd --configfile=/run/samba/smb.conf
419 1 root S 27144 1.3 2 0.0 /usr/bin/nmbd --configfile=/run/samba/smb.conf
684 1 root S 23836 1.1 2 0.0 /usr/bin/fluxbox
493 1 root S 19604 0.9 1 0.0 /usr/bin/wpa_supplicant -u
Build OE #0410 is also using the 340.96 nvidia driver, assuming this is even relevant.
More likely this is a fernetmenta VideoPlayer change, where an old nvidia "quirk" has been dropped which may now result in the CPU busy-waiting while rendering. The Render/Wait changes in LE #0404c and LE #0406 look likely candidates for this new behaviour - in OE #0410 this is merged as PR9542.
Since I'd already spent the time working out the changes in LE #0404c/#0405/#0406, here they are - perhaps FernetMenta can comment when he's available.
- #0404c (compared with #0403):
- LibreELEC:
- build: Include git hash in /etc/os-release for release builds too (PR:87, 1 commit, 1 file changed)
- RPi/RPi2: Linux 4.4.6 and Kodi Jarvis updates (PR:78, 2 commits, 4 files changed)
- RPi: Stop enabling serial console in devel images (PR:84, 1 commit, 2 files changed)
- console: enable cursor for textmode and RPi serial consoles (PR:85, 1 commit, 3 files changed)
- u-boot: update to u-boot-imx6-408544d for imx6 project (PR:80, 1 commit, 3 files changed)
- imx6: add second kernel 4.4 from xbian (PR:81, 1 commit, 8 files changed)
- RBP: Update firmware to be in sync with kernel (PR:92, 1 commit, 2 files changed)
- rtmpdump: cleanup download url (PR:82, 1 commit, 1 file changed)
- libbdplus: Fix download URL (PR:93, 1 commit, 1 file changed)
- imx6: add irqbalanced daemon for linux 4.4 (PR:94, 1 commit, 3 files changed)
- v86d: Fix download url (PR:95, 1 commit, 1 file changed)
- Kodi:
- [DVDVideoCodecOpenMax] update after d5f63a8 (PR:9539, 1 commit, 2 files changed)
- VideoPlayer: add method for requesting desired video resolution to de… (PR:9531, 1 commit, 12 files changed)
- [json] - add support for tvshow status (PR:9537, 1 commit, 2 files changed)
- [cmake] Add cmake parameter to BuildSetup.bat (PR:9529, 5 commits, 5 files changed)
- [python] add mediatype to setinfo for music (PR:9396, 1 commit, 4 files changed)
- [cmake] Fix android build (PR:9540, 2 commits, 1 file changed)
- [gui] - remove go-to-root context menu buttons (PR:9536, 1 commit, 6 files changed)
- [buildsystem][win32] Updated some more build files to vs2015 that was forgotten about (PR:9541, 1 commit, 4 files changed)
- [json] fix params order for SetTVShowDetails (PR:9544, 1 commit, 1 file changed)
- [adsp] rework to new system who already on PVR (PR:9483, 4 commits, 26 files changed)
- VideoPlayer: inputstream, fix cp error (e9a6d59f)
- [lang][skin.estuary] updated language files from Transifex (da74385e)
- [lang][skin.estouchy] updated language files from Transifex (02e2e021)
- FernetMenta (new additions):
- VideoPlayer: drop WaitPresentTime (6ba07493)
- Changes not merged upstream:
- PR:178: xf86-video-nvidia-legacy: Change driver from 304.x to 340.x
- #0405:
- LibreELEC:
- LibCEC patches update (PR:88, 2 commits, 4 files changed)
- projects/imx6/patches/u-boot: set delay of 1 second to speed up the boot (PR:97, 1 commit, 1 file changed)
- projects/imx6/linux: disable PCI MSI interrupts for kernel 4.4 (PR:96, 1 commit, 1 file changed)
- screensaver.shadertoy: Add package (PR:73, 1 commit, 1 file changed)
- image: BUG_REPORT_URL should reflect origin repo used for build (PR:91, 1 commit, 1 file changed)
- preset directories and paths for picons (PR:89, 2 commits, 2 files changed)
- readme: update README.md text (PR:76, 1 commit, 1 file changed)
- visualization.shadertoy: fix build for OpenGLES (PR:100, 1 commit, 1 file changed)
- Package updates (PR:103, 6 commits, 7 files changed)
- mesa: update to 11.2.0
- bluez: update to 5.38
- setuptools: update to 20.6.7
- Pillow: update to 3.2.0
- fontconfig: update to 2.11.94
- inputproto: update to 2.3.2
- libiconv: add libiconv package (PR:104, 1 commit, 3 files changed)
- addons: add OSCam (PR:99, 1 commit, 15 files changed)
- addons: version bump for LE 7.0 Beta 1 (PR:90, 1 commit, 21 files changed)
- Hyperion! (PR:39, 3 commits, 10 files changed)
- Kodi:
- Videoplayer code cleanup & race condition fix (PR:9442, 4 commits, 2 files changed)
- Cleanup dll loader / posix win32 emulation functions. (PR:8798, 13 commits, 66 files changed)
- [EGLIMX] Added category D framebuffer modes (PR:9551, 1 commit, 1 file changed)
- [guilib][fix] Fix "vector iterator not incrementable". dialog->Close … (PR:9547, 1 commit, 1 file changed)
- [Builtins/Cec] add missing registrations (PR:9535, 1 commit, 1 file changed)
- [EGLIMX] Added category D framebuffer modes (c70dfe76)
- FernetMenta:
- Not present - #0405 incorrectly built using Raspberry Pi linux and kodi (newclock5) patches
- #0406:
- LibreELEC:
- scripts/clean: allow cleaning package for all projects (PR:108, 1 commit, 1 file changed)
- scripts/clean: fixup previous commit (PR:109, 1 commit, 1 file changed)
- boblightd: bump version (PR:110, 1 commit, 1 file changed)
- hyperion: updated description and bump version (PR:111, 1 commit, 2 files changed)
- Upstream changes (PR:101, 5 commits, 5 files changed)
- Kodi:
- small syntax typo (PR:9554, 1 commit, 1 file changed)
- VideoPlayer: set speed on demuxer when speed of player is changed (PR:9555, 1 commit, 1 file changed)
- remove some unused/duplicate context menus (PR:9548, 4 commits, 8 files changed)
- videoinfotag: fix typo introduced in e6e2d0ace5cfe6191b8f7727ced1747854254ce4 (PR:9558, 1 commit, 1 file changed)
- [coverity] Some cleanup/fixes (PR:9512, 14 commits, 23 files changed)
- [Estouchy] change include syntax (PR:9562, 1 commit, 1 file changed)
- VideoPlayer: simplify video rednering (c7bb0a59)
- simplify render loop (002a4df8)
- VidoePlayer: do not block renderthread if no gui was rendered and video is separate layer (6b453df8)
- move FinishPipeline from application to gfx context (06e797f3)
- squash: fix build after WaitPresentTime (3e2e4f2a)
