(2016-05-24, 07:23)nuc-LE Wrote: [ -> ] (2016-05-24, 07:00)fritsch Wrote: [ -> ] (2016-05-24, 03:13)Milhouse Wrote: [ -> ]Misquoting Chew: "Don't know, I don't know such stuff. I just do builds, ju-, ju-, just builds."
Maybe @fritsch or @FernetMenta will be kind enough to take a look and give their (way more informed) opinion.
Please disable passthrough and play from local disk. Choose the very same file.
First of all thank you for looking into it fritsch!
passthrough: Disabled
media played back from local usb drive. (same video) playback has same issues with frames being dropped
Build #0523 : debug log
Please additionally enable "Sync Playback to display" please. Same issue?
(2016-05-24, 13:40)fritsch Wrote: [ -> ] (2016-05-24, 07:23)nuc-LE Wrote: [ -> ] (2016-05-24, 07:00)fritsch Wrote: [ -> ]Please disable passthrough and play from local disk. Choose the very same file.
With "Sync Playback to display" it looks like a lot less frames are being dropped.
debug log
(2016-05-24, 16:07)nuc-LE Wrote: [ -> ] (2016-05-24, 13:40)fritsch Wrote: [ -> ] (2016-05-24, 07:23)nuc-LE Wrote: [ -> ]First of all thank you for looking into it fritsch!
debug log
This is what FernetMenta and I use - so it's no wonder that it works - never the less I forwarded your issue and starting next week I will have time again to look into kodi stuff.
Thank fritsch, I appreciate the work you guys do!
I will keep checking here.
p.s. long time user but never had a problem that wasn't discussed here. You guys rock!
(2016-05-24, 19:20)fritsch Wrote: [ -> ] (2016-05-24, 16:07)nuc-LE Wrote: [ -> ] (2016-05-24, 13:40)fritsch Wrote: [ -> ]Please additionally enable "Sync Playback to display" please. Same issue?
debug log
It does not work on both of my systems. I have passthrough disabled and sync playback to display enabled.
log -->
http://forum.kodi.tv/showthread.php?tid=...pid2341515
Milhouse tried #0523b no more luck
BUT
I captured an advanced log when the problem occurs :
http://xbmclogs.com/pegmk9eed
About at line #4421 i stopped file and i get black screen for about 15 seconds
Did you see please anything relevant ? Consider that i'm using hardware edid solution but no change
Nb: i found out that if i use often seek function problem occurs often
Thank you
New LibreELEC.tv Krypton build #0524:
Generic
(Supercedes previous build)
# uname -a
Linux LibreELEC 4.6.0 #1 SMP Tue May 24 21:07:07 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160524210458-#0524-g1647950 [Build #0524]
Based on tip of
LibreELEC.tv master (16479507,
changelog) and tip of
XBMC master (d534e45e,
- Includes FernetMenta "VideoPlayer" patches
- Includes latest kodi-platform master (c8188d82, ahead +4)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (00d9ba15, ahead +19)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: adsp.basic (2ae604e5, +8), adsp.biquad.filters (29bfe9d8, +3), adsp.freesurround (34f50406, +7), asplib (da66f517), inputstream.mpd (3ac19c39, +11), inputstream.smoothstream (32275717, +2), peripheral.joystick (83371862, +30), pvr.argustv (5f48dcec, +4), pvr.demo (0fa9e1d0, +4), pvr.dvblink (a92f1264, +5), pvr.dvbviewer (3d0bea9a, +4), pvr.filmon (8743511d, +4), pvr.hdhomerun (b5ce9309, +4), pvr.hts (acd1a6ac, +5), pvr.iptvsimple (7a5a43f8, +4), pvr.mediaportal.tvserver (172a273c, +4), pvr.mythtv (e2b60252, +8), pvr.nextpvr (150698b7, +4), pvr.njoy (b5d65655, +4), pvr.pctv (feed5990, +4), pvr.stalker (4244220f, +12), pvr.vbox (c6594819, +4), pvr.vdr.vnsi (5498a8c1, +7), pvr.vuplus (ea3b33f6, +4), pvr.wmc (77af8daf, +4)
- Includes commits from xbmc/master, ahead +5 (FernetMenta)
- Exclude [env] kodi-999.10-aarch64-support.patch: Merged upstream
- Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: xf86-video-intel: bump to 3fafabe
- Include [env] patch: Fix SIGTERM patch after PR9748
- Include [env] patch: Fix cmake after PR9750
- Include [env] patch: Add extra headers needed by 3D BD MVC
- Include [env] patch: Disable -werror as libnfs won't build 32-bit without it
- Include [env] patch: Bump libbluray - include MVC support
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Enable other binary addons
- Include [env] PR:353: plymouth-lite: add bilinear interpolation patch
- Include [env] PR:366: mysql: update to 5.7.12
- Include [env] PR:381: splash: Select splash image based on native resolution
- Include [env] PR:382: systemd: update to 230
- Include [env] PR:388: xf86-video-nvidia: update to xf86-video-nvidia-361.42
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] dd81c2f1: [librtmp] Update to 15-Dec-2015 from http://stream-recorder.com/forum/customi...16103.html (kodi)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
- Include [pkg] patch: drm/i915/ilk: Wait one vblank before enabling audio (link1, link2) (linux)
- Include [pkg] patch: drm/i915/psr: Try to program link training times correctly (HSW fix) (linux)
- Include [pkg] patch: Revert "drm/i915: Exit cherryview_irq_handler() after one pass" (BSW fix) (linux)
- Include [pkg] patch: CSC: Remove average logic when saving NV12 surface on IVB+ (VAAPI fix) (libva-intel-driver)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
- Include [pkg] PR:9847: [PVR] Feature: Make instant recording behavior configurable
Build Highlights:
- NOTE: DVD playback remains temporarily disabled
- Minors
Build Details:
- XBMC:
- [PVR] Remove CPVRTimerInfoTag::Has[Series]EpgInfoTag(). (PR:9871, 1 commit, 7 files changed)
- pvr.stalker:
- xmltv refactor (PR:55, 6 commits, 21 files changed)
(2016-05-24, 21:31)john.cord Wrote: [ -> ] (2016-05-24, 19:20)fritsch Wrote: [ -> ] (2016-05-24, 16:07)nuc-LE Wrote: [ -> ]With "Sync Playback to display" it looks like a lot less frames are being dropped.
debug log
log --> http://forum.kodi.tv/showthread.php?tid=...pid2341515
Your problem is different. If I would not know better I'd say the hardware is too slow to play that file. Make fully sure, that you disabled HQ scalers, e.g. you forced bilinear for that file. If possible upload a sample somewhere. Really looks like a bad demux or something. Only this release group is affected?
Milhouse
I install today LibreElec on a Pi3.... when you will bring this cool boot animation to x86?
(2016-05-25, 04:11)fritsch Wrote: [ -> ]Your problem is different. If I would not know better I'd say the hardware is too slow to play that file. Make fully sure, that you disabled HQ scalers, e.g. you forced bilinear for that file. If possible upload a sample somewhere. Really looks like a bad demux or something. Only this release group is affected?
If thats the case this should be on #420 as well a problem but with that build everything plays fine, same as with your EGL Builds. I never had performance issues with the NUC or the Chromebox even with high bitrate files and DTS demuxing etc. I set kodi to cach more of the files (100MB) to eliminate the possibility of a network related caching issue.
(2016-05-25, 14:40)sunnyfunny Wrote: [ -> ]@Milhouse
If someone writes a simple h264 video player that works with all x86 video drivers (or alternatively with only the frame buffer) then I'll add it. Don't see that happening though, so don't hold your breath.
(2016-05-23, 23:26)Milhouse Wrote: [ -> ]Yeah, sounds like it could be a hardware error if your previously stable installation is now throwing the same error.
Even so, it would be good to test the new driver once you have a stable system.
I'm back in business. Memory arrived today and I have a stable system again. Later I want to test K17 on the Nvidia system ...
besides and OT, am I too stupid to install LE (I used the 7.0.1 image) on a bootable USB stick?! Possibly yes. Did a quick test with two different 8G USB sticks and both did not boot after I installed LE on them. The install stick by itself worked and I was abel to select the traget USB stick. Both showed some warning 'don't mess with boot... going back to ... " or something during boot. In case this should work would anybody point me in the right direction (best by PM I suppose) on how to get a LE install on an bootable USB stick. No hurry please, I'm on a business trip and back on Sunday.
I cleaned the Chromebox from dust to sort possible overheating/throtteling issues out. I updated to the latest Libreelec Build and disabled HQ Scaling (now switched to Bilinear). I tested Big Buck Bunny and some TV Show Episodes and atm no issues. Weird
The Chromebox played everything fine with HQ Scaling till Build 420.
(2016-05-25, 19:16)lazyman Wrote: [ -> ]besides and OT, am I too stupid to install LE (I used the 7.0.1 image) on a bootable USB stick?! Possibly yes. Did a quick test with two different 8G USB sticks and both did not boot after I installed LE on them. The install stick by itself worked and I was abel to select the traget USB stick. Both showed some warning 'don't mess with boot... going back to ... " or something during boot. In case this should work would anybody point me in the right direction (best by PM I suppose) on how to get a LE install on an bootable USB stick. No hurry please, I'm on a business trip and back on Sunday.
I just wrote (using dd) the uncompressed LE 7.0.1 image to a 4GB USB stick, booted the 4GB stick then created the system on a second 8GB USB stick (option 1), then booted with the second USB stick without any problem (this on an AMD UEFI based system). I'd suggest trying a different memory stick (or both). If you don't resolve the issue, a new thread would be best.
New LibreELEC.tv Krypton build #0525:
Generic
# uname -a
Linux LibreELEC 4.6.0 #1 SMP Wed May 25 21:07:07 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160525210500-#0525-g1647950 [Build #0525]
Based on tip of
XBMC master (fe51c6b3,
- Includes latest addons: adsp.basic (2ae604e5, +8), adsp.biquad.filters (01236bbe, +7), adsp.freesurround (34f50406, +7), asplib (da66f517), inputstream.mpd (3ac19c39, +11), inputstream.smoothstream (32275717, +2), peripheral.joystick (83371862, +30), pvr.argustv (5f48dcec, +4), pvr.demo (0fa9e1d0, +4), pvr.dvblink (a92f1264, +5), pvr.dvbviewer (3d0bea9a, +4), pvr.filmon (8743511d, +4), pvr.hdhomerun (b5ce9309, +4), pvr.hts (acd1a6ac, +5), pvr.iptvsimple (7a5a43f8, +4), pvr.mediaportal.tvserver (172a273c, +4), pvr.mythtv (e2b60252, +8), pvr.nextpvr (150698b7, +4), pvr.njoy (b5d65655, +4), pvr.pctv (feed5990, +4), pvr.stalker (4244220f, +12), pvr.vbox (c6594819, +4), pvr.vdr.vnsi (5498a8c1, +7), pvr.vuplus (ea3b33f6, +4), pvr.wmc (77af8daf, +4)
- Include [env] PR:393: nvidia: Enable USLEEP to reduce CPU load while rendering
Build Highlights:
- Fix nvidia high CPU load while rendering (thanks @FernetMenta, @ragnaroek)
Build Details:
- XBMC:
- Player fixes (PR:9826, 8 commits, 18 files changed)
- VideoPlayer: fix audio for wmapro (and may some other codecs) (PR:9867, 2 commits, 3 files changed)
- [cmake/addons] Make relative ADDON_SRC_PREFIX relative to the build dir (PR:9813, 1 commit, 1 file changed)
- [cmake] Don't run autoreconf as UPDATE_COMMAND (PR:9854, 1 commit, 2 files changed)
- AudioDSP fixes (PR:9870, 3 commits, 3 files changed)
- [adsp] show warning if no modes are present for manager dialog (PR:9835, 3 commits, 6 files changed)
- Added: [env] PR:393: nvidia: Enable USLEEP to reduce CPU load while rendering
