(2016-06-06, 23:57)Milhouse Wrote: [ -> ]Build Highlights:
- Reinstate DVD support - thanks @TheUlpio and @stefansaraev
Wahhh great...finally....thank you very much guys for your efforts +1 !!
(2016-06-07, 18:46)Tequilla9 Wrote: [ -> ]Here you are:
(Hope I have done it correctly)
Part 1 (Kodi and Sytem log): http://pastebin.com/hz7NUf9a
Part 2 (Audio, Journal log): http://pastebin.com/mnSgnbN7
Hope it helps to identify the problem. Please let me know when I should try something
thx
Volker
Thanks, please turn on debuglogging and play the file for longer (10 minutes), please., don't open the codec info screen, but press a remote button every time you see the stutter. Also disable ffmpeg's component logging that is spamming us like hell. Then please only post the kodi.log - the rest is not relevant for now.
(2016-06-05, 14:45)_Spook_ Wrote: [ -> ] (2016-06-05, 14:10)fritsch Wrote: [ -> ] (2016-06-05, 12:41)_Spook_ Wrote: [ -> ]Ok. I did not know that obviosly.
EDIT: I updated with new test and changed the title. 7.1 gives me sound in all channels in test
See: Kernel Bug - as assumed :-). Happy testing with new hardware. If you buy the next gen in three days - don't forget to donate the old HW
I can donate a NUC6i5SYK if you need. Just give me info
Donate time - that's what is needed.
@Robby77: Do:
touch /storage/.config/forcedisplay
And reboot. Display comes up?
Watson question:
Will try but if i reboot how i understand (and report) if the problem disappear cause no handshake problem or thanks to your trick ?
Just to resume
Forced edid but on boot i can have
A)Black screen after syslinux text and need almost 2/3 reboot to have kodi gui (maybe this is the best scenario to test that trick)
B) black screen after lbreelec logo...wait 15 sec ~ 2 minuts for kodi gui
And also
Random black screen when movie stop wait 15 sec ~ 2 minuts for kodi gui
Tried also with dr hdmi solution...same problem
For WAF i mapped reboot command to remote
your B) issue is your personal issue and we won't and can't fix that.
The random movie stopped issue is filed upstream - nothing we can do - we wait for upstream.
If you care for WAF -> sell all your hardware and get an Android TV and use the netflix app only :-)
As your wife won't see the difference between 23.976 hz and 60 hz, just disable Adjust Refreshrate to match video.
Between 24p and wife i prefer the first seriously
(Also prefer pc architecture* for picture quality and audio hd and love oe/libreelec kodi standalone)
Maybe not relevant but i have this error in log several reported
Got external EDID base block and 1 extension from
"edid/edid.bin" for connector "HDMI-A-1"
And this in last 2/3 builds
had: snd_intelhad_open: HDMI cable plugged-out
Thank you
New LibreELEC.tv Krypton build #0607:
Generic
(Supercedes previous build)
# uname -a
Linux LibreELEC 4.6.1 #1 SMP Tue Jun 7 21:16:35 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160607211513-#0607-gf59ff67 [Build #0607]
Based on tip of
LibreELEC.tv master (f59ff67c,
changelog) and tip of
XBMC master (d1a52d1e,
- Includes FernetMenta "VideoPlayer" patches
- Includes latest kodi-platform master (c8188d82, ahead +4)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (cdd1643c, ahead +28)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: adsp.basic (2ae604e5, +8), adsp.biquad.filters (01236bbe, +7), adsp.freesurround (34f50406, +7), asplib (da66f517), inputstream.mpd (3ac19c39, +11), inputstream.smoothstream (32275717, +2), peripheral.joystick (2db8029e, +32), pvr.argustv (5f48dcec, +4), pvr.demo (0fa9e1d0, +4), pvr.dvblink (a92f1264, +5), pvr.dvbviewer (3d0bea9a, +4), pvr.filmon (8743511d, +4), pvr.hdhomerun (b5ce9309, +4), pvr.hts (acd1a6ac, +5), pvr.iptvsimple (7a5a43f8, +4), pvr.mediaportal.tvserver (172a273c, +4), pvr.mythtv (e2b60252, +8), pvr.nextpvr (150698b7, +4), pvr.njoy (b5d65655, +4), pvr.pctv (feed5990, +4), pvr.stalker (fb24eda2, +13), pvr.vbox (c6594819, +4), pvr.vdr.vnsi (5498a8c1, +7), pvr.vuplus (ea3b33f6, +4), pvr.wmc (77af8daf, +4)
- Includes commits from xbmc/master, ahead +5 (FernetMenta)
- Exclude [env] kodi-999.10-aarch64-support.patch: Merged upstream
- Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: xf86-video-intel: bump to 3fafabe
- Include [env] patch: Fix SIGTERM patch after PR9748
- Include [env] patch: Fix cmake after PR9750
- Include [env] patch: Add extra headers needed by 3D BD MVC
- Include [env] patch: mesa: update to 12.0.0-rc1
- Include [env] patch: Bump libbluray - include MVC support
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Enable other binary addons
- Include [env] PR:408: Fix digital audio crackling when playing music on non Kodi based setups.
- Include [env] PR:412: splash: Stop blanking splash too early in RPi boot sequence
- Include [env] PR:417: linux: Atom Baytrail and CherryTrail audio HDMI support
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] dd81c2f1: [librtmp] Update to 15-Dec-2015 from http://stream-recorder.com/forum/customi...16103.html (kodi)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
- Include [pkg] patch: drm/i915/psr: Try to program link training times correctly (HSW fix) (linux)
- Include [pkg] patch: CSC: Remove average logic when saving NV12 surface on IVB+ (VAAPI fix) (libva-intel-driver)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
- Include [pkg] PR:9931: VideoPlayer: switch back to Kodi method of counting CPUs
- Include [pkg] PR:9932: VideoPlayer: keep value of m_vSyncAdjust on Discontinuity
Build Highlights:
- VideoPlayer: switch back to Kodi method of counting CPUs
- VideoPlayer: keep value of m_vSyncAdjust on Discontinuity
Build Details:
- XBMC:
- Default Scale for HQ scaling above (PR:9915, 2 commits, 2 files changed)
- [skin.estouchy] update (PR:9928, 1 commit, 239 files changed)
- Added: [pkg] PR:9931: VideoPlayer: switch back to Kodi method of counting CPUs
- Added: [pkg] PR:9932: VideoPlayer: keep value of m_vSyncAdjust on Discontinuity
(2016-06-07, 21:13)fritsch Wrote: [ -> ] (2016-06-07, 18:46)Tequilla9 Wrote: [ -> ]Here you are:
thx
Volker
OK, I will upload new logs in the evening.
Please with the new build Milhouse just posted.
Is there is reason caused by Kodi that after i boot a client all drives of the NAS gets busy? Is kodi by default set to scan some sort of file metadate or something?
(2016-06-08, 12:54)john.cord Wrote: [ -> ]Is there is reason caused by Kodi that after i boot a client all drives of the NAS gets busy? Is kodi by default set to scan some sort of file metadate or something?
Try with a "clean" .kodi ("mv .kodi .kodi.bak" and restart Kodi). This well ensure you have no additional add-ons, and using default settings. If problem guess away it's either a third-party add-on (watchdog?) or a setting (scan/clean library on startup?)
Windows only ... the updater - not sure what they are thinking ...
(2016-06-08, 13:47)fritsch Wrote: [ -> ]Windows only ... the updater - not sure what they are thinking ...
I know. Will have to make a windows drive for these kind of updates...
EDIT: Oh yeah! That firmware did it! Works like a charm now. Except passthrough, but that's not a big deal for me
EDIT2: Spoke to soon. Works fine in Kodi. But linux speakertest no go. But oh well. Seems like a firmware and kernel issue. Not a Kodi issue. Passthrough works on AC3 and DTS. Not DTS-HD, TrueHD and so on.
EDIT3: This is the same issue as I had with the Club3D miniDP->HDMI2.0 adapter with the Paradetech PS176 chip. So it's a firmware issue. The NUC6i7KYK has the PS175 chip, basically the same chip with same firmware.
https://communities.intel.com/thread/102165 explains the same thing.
