modified devupdate again, this should now work as normal + libreelec support, after a manual update to a libreelec devupdate will get milhouse libreelec sources
& created a PR to get this into devupdate
Post
(2016-04-18, 14:09)Milhouse Wrote: [ -> ] (2016-04-18, 08:41)cypher242 Wrote: [ -> ]I made an update from 0417b to 0417 build, now there is another error. I can provide a full debug log this evening.
Quote:08:34:22 14.734685 T:140153834170112 ERROR: ADDON: Dll ARGUS TV client, throws an exception 'basic_string::_S_construct null not valid' during m_pDll->Create. Contact developer 'Fred Hoogduin, Marcel Groothuis' with bug reports
08:34:22 14.734757 T:140153834170112 ERROR: UpdateAddons - failed to create add-on ARGUS TV client, status = 4
Thanks. PR9645 has been dropped and PR:50 updated - can you (or @smiffy1989) re-test with build #0417x and see if that's any better?
ArgusTV is running again on build 0417x, thx.
Edit: But Channel Logos for Radio and TV are missing.
Quote:17:39:37 15.812150 T:140345555801856 WARNING: GetAddonProperties - Addon ARGUS TV (argustv):http://argustv:49943/ does not support timer types. It will work, but not benefit from the timer features introduced with PVR Addon API 2.0.0
17:39:37 15.878889 T:140344364627712 ERROR: CCurlFile::Exists - Failed: Failure when receiving data from the peer(56) for http://argustv:49943/ArgusTV/Scheduler/C...1970-01-01
17:39:37 15.886827 T:140344364627712 ERROR: CCurlFile::Exists - Failed: Failure when receiving data from the peer(56) for http://argustv:49943/ArgusTV/Scheduler/C...1970-01-01
17:39:37 15.893683 T:140344364627712 ERROR: CCurlFile::Exists - Failed: Failure when receiving data from the peer(56) for http://argustv:49943/ArgusTV/Scheduler/C...1970-01-01
I saw in your modifications following. Have not been so persecuted.
- Add extra headers needed by 3D BD MVC
- Bump libbluray - include MVC support
can be played mvc mkv under linux or "only" full 3D iso ?
(2016-04-17, 16:49)Milhouse Wrote: [ -> ] (2016-04-17, 13:10)smiffy1989 Wrote: [ -> ]Here you go: http://sprunge.us/efUa
EDIT: and just in case it helps, here's a debug log after downgrading back to the 14/04 build: http://sprunge.us/OJEh
@smiffy1989: Can you try test build #0417b it's the same as #0416 but has PR9621 reverted.
(2016-04-18, 17:45)cypher242 Wrote: [ -> ] (2016-04-18, 14:09)Milhouse Wrote: [ -> ] (2016-04-18, 08:41)cypher242 Wrote: [ -> ]I made an update from 0417b to 0417 build, now there is another error. I can provide a full debug log this evening.
Same here, here's a debug log:
http://sprunge.us/KMbU
(2016-04-18, 17:52)Eisi2005 Wrote: [ -> ]Hi,
No, that was a change added for the Raspberry Pi - apologies for being misleading, the same patches are used by both platforms but only the RPi has built-in 3D BD ISO support. Maybe one day 3D BD ISO support will come to Linux x86.
(2016-04-18, 17:58)smiffy1989 Wrote: [ -> ]Same here, here's a debug log: http://sprunge.us/KMbU
Could you upload another debug log, this time with "LibcURL" component logging enabled?
(2016-04-18, 17:11)neox387 Wrote: [ -> ]modified devupdate again, this should now work as normal + libreelec support, after a manual update to a libreelec devupdate will get milhouse libreelec sources
Post
Please i'm a newbie
Tried on new install with no addon
1)unziped and renamed it in download folder
2)launched ssh client and used
cp -r ./downloads/script.openelec.devupdate/ ./.kodi/addons/
But no addon installed
Where is my fault ?
Edit: strange i found it in .kodi/addons devupdate folder
(2016-04-18, 19:45)Roby77 Wrote: [ -> ] (2016-04-18, 17:11)neox387 Wrote: [ -> ]modified devupdate again, this should now work as normal + libreelec support, after a manual update to a libreelec devupdate will get milhouse libreelec sources
Post
Please i'm a newbie
Where is my fault ?
first install the devupdate the normal way:
Dev update website
So first the repo & then from the addons menu install dev update from leopold's repo.
when this is working & you have the addon installed & you can see it in addons menu, then do my steps.
So when devupdate get's officialy updated my modified version will get overwritten
(2016-04-18, 01:18)wesk05 Wrote: [ -> ] (2016-04-17, 22:55)Roby77 Wrote: [ -> ]Yes i have enabled it too and i assume that this is the correct setting (only from fritsch mod) ....plasma set in auto and checked with xrandr if 16-235 passthrough is enabled
Final test using avshd basic test to check B/W correct level and greyramp
Sorry for ot
It works as intended as can be seen in the YouTube clip. 0-16 and 236-255 are passed. In the clip, you can see RGB pixel values being read using a DVDO AVLab TPG. The test pattern has 2-25 and 230-253 patches, background is 1 and 254 for the top and bottom halves resp.
True, let use also grayramp test to check banding
New LibreELEC.tv Krypton build #0418:
Generic
(Supercedes previous build)
# uname -a
Linux LibreELEC 4.4.7 #1 SMP Mon Apr 18 21:05:35 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160418210418-#0418-gca62a87 [Build #0418]
Based on tip of
LibreELEC.tv master (ca62a87b,
changelog) and tip of
XBMC master (2c578562,
- Includes FernetMenta "VideoPlayer" patches
- Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
- Disabled "Total Duration" in Confluence (see build #0221 for details)
- Includes latest kodi-platform master (92583ef9, ahead +2)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (3c26ce1e, ahead +13)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: adsp.basic (5cf12e83), adsp.biquad.filters (af575f3d), adsp.freesurround (6dc533be), asplib (da66f517), inputstream.mpd (4323ce68), inputstream.smoothstream (1813bbb4), peripheral.joystick (76b7c40a), pvr.argustv (531dae9c, +2), pvr.demo (e74822f2), pvr.dvblink (82c7b4d5), pvr.dvbviewer (6ab861fa), pvr.filmon (0d8dd5bd), pvr.hdhomerun (fd9daf4a), pvr.hts (0f88a357), pvr.iptvsimple (b741cac7), pvr.mediaportal.tvserver (96f415e3), pvr.mythtv (f8d25fda), pvr.nextpvr (d445c5ad), pvr.njoy (b9b0ae43), pvr.pctv (f1880484), pvr.stalker (14a7c70d), pvr.vbox (e70146d8), pvr.vdr.vnsi (12364058), pvr.vuplus (d8c6f9ba), pvr.wmc (898e2dad)
- Includes commits from xbmc/master, ahead +6 (FernetMenta)
- Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
- Include [env] e7cbe9cb: xf86-video-intel: explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: xf86-video-intel: bump to 3fafabe
- Include [env] patch: Drop repo hack (not needed after PR9642)
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*
- Include [env] patch: Add extra headers needed by 3D BD MVC
- Include [env] patch: Bump libbluray - include MVC support
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Enable other binary addons
- Include [env] PR:174: Set default volume steps to 20
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] dd81c2f1: [librtmp] Update to 15-Dec-2015 from http://stream-recorder.com/forum/customi...16103.html (kodi)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: kodi: use 2 buffers by default - matches disabled triple buffers
- Include [pkg] PR:51: More CURL Post (pvr.argustv)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9538: [Peripherals] m_bNeedsPolling broken for busses where it is set outsiā¦
- Include [pkg] PR:9636: [PVR] EPG data import performance tuning.
- Include [pkg] PR:9643: [addons] ask for version on install
Build Highlights:
- NOTE: DVD playback remains temporarily disabled
- LibreELEC master opens for Kodi 17
- Another go at fixing pvr.argustv - please test & report
- Drop repo database hack (not needed after PR9642)
- [addons] ask for version on install (PR9643 - superceeds PR9642)
Build Details:
- LibreELEC.tv:
- Kodi 17 (redo) (PR:98, 22 commits, 101 files changed)
- ffmpeg: Update to ffmpeg 3.0.1 and Kodi upstream (PR:77, 2 commits, 14 files changed)
- rebrand: one more leftover (PR:170, 1 commit, 1 file changed)
- tinyxml2: really disable shared (PR:177, 1 commit, 1 file changed)
- kodi: Add repository.kodi.game (PR:176, 1 commit, 3 files changed)
- tools/repo-tool: make it actually usable (PR:159, 1 commit, 1 file changed)
- xf86-video-nvidia-legacy: Change driver from 304.x to 340.x (PR:178, 1 commit, 1 file changed)
- inputstream.mpd: fix build (PR:171, 1 commit, 1 file changed)
- tools: improve distro-tool performance (PR:180, 1 commit, 1 file changed)
- XBMC:
- Format numbers with localized separators (PR:9550, 2 commits, 7 files changed)
- ffmpeg: reduce log spam (PR:9646, 1 commit, 1 file changed)
- pvr.argustv:
- send postdata using CURLADDOPTION (PR:50, 2 commits, 3 files changed)
- Added: [env] patch: Drop repo hack (not needed after PR9642)
- Added: [env] PR:174: Set default volume steps to 20
- Added: [pkg] PR:51: More CURL Post (pvr.argustv)
- Added: [pkg] PR:9643: [addons] ask for version on install
(2016-04-18, 19:44)Milhouse Wrote: [ -> ] (2016-04-18, 17:58)smiffy1989 Wrote: [ -> ]Same here, here's a debug log: http://sprunge.us/KMbU
This is with 418 (same issue):
http://sprunge.us/fbKi
(2016-04-19, 07:46)smiffy1989 Wrote: [ -> ] (2016-04-18, 19:44)Milhouse Wrote: [ -> ] (2016-04-18, 17:58)smiffy1989 Wrote: [ -> ]Same here, here's a debug log: http://sprunge.us/KMbU
This is with 418 (same issue): http://sprunge.us/fbKi
Could you pls. describe the problem more in detail maybe with poining to the line in log where you see a problem?
For me it looks all fine from log?
Unfortuantely I don't use ArgusTV (so I have no clue what is really expected)
Edit: what really could help in this situation:
Make 2 logs with curl enabled, one with an old version wich is running, one with the current version.
If you're able to provide this, pls make sure to make the same steps in kodi for both logs to be compareable.
My setup is an update from OE and for the past few updates I cannot connect to the Libreelec repo. Before shouting at me
I have read elsewhere that the solution would be to delete addon##.db (23) iirc but anyway I make sure no addon##.db files reside in the userdata/database/ folder.
Still no access... is it working or will due to be in a later build?
