I updated and now mythtv seems to be missing? The HDHomerun app still display channels, but I do not have a guide, tv listings, or recordings. However I can go in and find recordings by adding them as a source. Do I need to change a setting or update anything, or is anyone else having any issue?
EDIT: Went to grab logs, and when it restarted the PVR, Guide, and Recordings all showed back up!
No help possible without the related
Debug Log
(2016-06-15, 14:14)fritsch Wrote: [ -> ]No help possible without the related Debug Log
I checked log last time but it didn't contain any useful information, should i enable specific modules for debugging this since dmesg says this:
[81487.406197] Out of memory: Kill process 13130 (kodi.bin) score 813 or sacrifice child
[81487.406303] Killed process 13130 (kodi.bin) total-vm:4218636kB, anon-rss:2927112kB, file-rss:0kB, shmem-rss:0kB
[81488.105047] oom_reaper: reaped process 13130 (kodi.bin), now anon-rss:0kB, file-rss:24kB, shmem-rss:0kB
(2016-06-15, 10:11)schumi2004 Wrote: [ -> ]Did anyone looked in my issue already?
http://forum.kodi.tv/showthread.php?tid=...pid2355921
I updated to build #613 and the issue is still present.
What kind of logging should i provide to get more specific information regarding this?
Something (maybe an add-on) is using up a lot of memory, resulting in Kodi (or some component of Kodi) being killed. A
debug log (wiki) might shed some light on any unusual Kodi behaviour.
I'd suggest trying a clean kodi without any third party add-ons (ie. "systemctl stop kodi; mv .kodi .kodi.bak; reboot"), and see if you can reproduce.
If you cannot reproduce the issue then it's a third-party add-on that is causing the problem - start adding back your add-ons until the problem is reproduced, and the last add-on is likely to be the cause.
You could also identify the first build that has this out-of-memory issue, as that might help narrow down a potential cause.
This is unlikely, but it may also be worth running memtest86+ to ensure you've no hardware (RAM) issues.
Okay, thanks for your feedback.
Going to enable full debug first, then i'll do a clean install after issues returns again and follow your steps.
I'll get back to you if something is found.
note: I needed to revert back to #612 since my MCE remote stopt functioning for the first time running your builds but will check that out later.
(2016-06-15, 15:10)schumi2004 Wrote: [ -> ]Okay, thanks for your feedback.
A quick question if i may , did your MCE remote rely on remote entry being seen as a keyboard ?
I hope I understand your question correctly but i didn't configured it as keyboard. If it was detected as keyboard in build #613 i don't know, need to check.
I only had a brief look at dmesg.
If you like i can upgrade again and perform some actions if wanted?
(2016-05-06, 03:33)SmallwoodDR82 Wrote: [ -> ] (2016-04-29, 17:23)SmallwoodDR82 Wrote: [ -> ] (2016-04-29, 07:14)fritsch Wrote: [ -> ]Kernel bug with your hardware. Post your Xorg.0.log please.
Here is Xorg.0.log - http://pastebin.com/thaAyeCg
Please let me know if you need anything else!
Still seeing this Kernel bug in latest build #0505
I'm having the exact same issue (with Intel i3-3225 CPU and Denon 1612 AVR, but Sharp LED TV).
It happens on LE 7.0.1 and LE 7.90.002 ALPHA and Milhouse' latest build #0614.
If I switch back to OE 6.0.3, everything is fine again.
SmallwoodDR82 Should we resurrect your bug report opened at freedesktop.org?
Can we provide anything else besides what you already delivered?
@Milhouse: Before I invest time in pulling OE 6.0.3 sources from Github and try to build it myself: Will this work to run OE 6.0.3 with the 4.6 kernel? And how dependent are all the components in the latest build (#0614) on this kernel, could we swap it out with 4.1.x?
My MCE remote has also stopped working with #0614, everything works ok with #0613 (I have no add-ons installed at all).
(2016-06-15, 19:21)D-an-W Wrote: [ -> ]My MCE remote has also stopped working with #0614, everything works ok with #0613 (I have no add-ons installed at all).
Same issue. Harmony remote setup as MCE remote, no buttons work with 0614.
Log from 0614:
http://sprunge.us/cSLH
libreelec channel updates are working, but milhouse is listing but not downloading... my end or issue with server?
(2016-06-15, 23:36)C-Quel Wrote: [ -> ]libreelec channel updates are working, but milhouse is listing but not downloading... my end or issue with server?
Should be fixed in #0614 - can you post your #0614
debug log (wiki)?
My MCE Remote has stopped wroking with #614
Its a Philips RC6
New LibreELEC.tv Krypton build #0615:
Generic
(Supercedes previous build)
# uname -a
Linux LibreELEC 4.6.2 #1 SMP Wed Jun 15 22:30:06 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160615222808-#0615-g820ca7d [Build #0615]
Based on tip of
LibreELEC.tv master (820ca7d8,
changelog) and tip of
XBMC master (12219485,
- Includes FernetMenta "VideoPlayer" patches
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (cdd1643c, ahead +28)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: adsp.basic (2ae604e5), adsp.biquad.filters (01236bbe), adsp.freesurround (34f50406), asplib (da66f517), inputstream.mpd (3ac19c39, +15), inputstream.smoothstream (32275717), peripheral.joystick (2db8029e), pvr.argustv (5f48dcec), pvr.demo (0fa9e1d0), pvr.dvblink (a92f1264), pvr.dvbviewer (3d0bea9a), pvr.filmon (8743511d), pvr.hdhomerun (b5ce9309), pvr.hts (acd1a6ac), pvr.iptvsimple (7a5a43f8), pvr.mediaportal.tvserver (172a273c), pvr.mythtv (e2b60252), pvr.nextpvr (150698b7), pvr.njoy (b5d65655), pvr.pctv (feed5990), pvr.stalker (fb24eda2), pvr.vbox (c6594819), pvr.vdr.vnsi (5498a8c1), pvr.vuplus (ea3b33f6), pvr.wmc (77af8daf)
- Includes commits from xbmc/master, ahead +5 (FernetMenta)
- Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: binary-addon: inputstream.rtmp
- Include [env] patch: Add extra headers needed by 3D BD MVC
- Include [env] patch: Bump libbluray - include MVC support
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] patch: Enable pvr addons, disable pvr updates
- Include [env] patch: Enable other binary addons
- Include [env] PR:432: build: start using .libreelec-unpack
- Include [env] PR:433: libreelec: use build project directory for ccache
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] dd81c2f1: [librtmp] Update to 15-Dec-2015 from http://stream-recorder.com/forum/customi...16103.html (kodi)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] patch: CSC: Remove average logic when saving NV12 surface on IVB+ (VAAPI fix) (libva-intel-driver)
- Include [pkg] PR:26: fix save button in network config (service.libreelec.settings)
- Include [pkg] PR:27: allow using custom update channels (service.libreelec.settings)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9731: [WIP] 3dlut and simple ICC linking support for color correction
- Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
Build Highlights:
- Drop lirc bump added in #0614
Build Details:
- LibreELEC.tv:
- wlan-firmware: bump to 0.0.32 (PR:448, 1 commit, 1 file changed)
- osmc_rf: fix context menu button (PR:450, 1 commit, 1 file changed)
- RPi: Refresh default config.txt, add licence and warning to distroconfig.txt (PR:442, 1 commit, 2 files changed)
- splash: Stop blanking splash too early in RPi boot sequence (RFC) (PR:412, 1 commit, 3 files changed)
- Package updates (PR:428, 31 commits, 36 files changed)
- elfutils: update to 0.165
- libftdi1: update to 1.3
- swig: update to 3.0.9
- giflib: update to 5.1.4
- libjpeg-turbo: update to 1.5.0
- fuse-exfat: update to 1.2.4
- bluez: update to 5.40
- libnftnl: update to 1.0.6
- libgpg-error: update to 1.22
- dbus: update to 1.11.2
- libpng: update to 1.6.22
- libevdev: update to 1.5.1
- libusb-compat: update to 0.1.5
- pciutils: update to 3.5.1
- libxml2: update to 2.9.4
- xf86-input-libinput: update to 0.19.0
- libinput: update to 1.3.1
- curl: update to 7.49.1
- libmicrohttpd: update to 0.9.50
- xkeyboard-config: update to 2.18
- xf86-input-evdev: update to 2.10.3
- libxslt: update to 1.1.29
- libXfixes: update to 5.0.2
- xcb-proto: update to 1.12
- xproto: update to 7.0.29
- mesa: update to 12.0.0-rc2
- xf86-video-intel: update to b617f80
- libirman: update to 0.5.2
- libxcb: update to 1.12
- libressl: update to 2.3.5
- xf86-video-nvidia: update to 367.27
- Revert "Merge pull request #136 from lrusak/modesetting" (PR:431, 1 commit, 3 files changed)
- lirc: remove circular dependency on libirman (PR:454, 1 commit, 1 file changed)
- XBMC:
- call SetVideoResolution before streams are Enabled (PR:9944, 1 commit, 1 file changed)
- Fix tests (PR:9980, 3 commits, 3 files changed)
- [upnp] fix TransportPlaySpeed state variable in CUPnPRenderer (PR:9927, 2 commits, 1 file changed)
- [cmake] Allow building with Ninja generator (PR:9954, 1 commit, 5 files changed)
- drop unused aml header (PR:9982, 2 commits, 2 files changed)
