2016-06-27, 15:08
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187
2016-06-27, 15:48
(2016-06-27, 12:05)menno Wrote: [ -> ]When I connect a USB cd/dvd/Blu-ray player I cannot access it anywhere. The GUI doesnt add a DISC icon nor can I find the device through File Manager. Is this normal?This is not supported. Connect it while powered off and boot after it is plugged in.
2016-06-27, 15:58
OK and where should it appear than? In the Main Menus or in File Manager only? Ill check dmesg cause even pre powering it up I cannot see it anywhere. So ill test some more stuff,anyway I am curious where it should pop-up
2016-06-27, 19:04
This looks kinda bad hehe
I dont see any reference, this drive works perfectly under latest stable OpenElec
//edit
Ah gettig some feedback
// Last not least 2nd edit.
I cannot see it anywhere in the New Skin, nor through file manager. Cannot add is as a source either :S
LibreELECw:~ # dmesg | grep usb
[ 0.000000] Kernel command line: root=/dev/ram0 rdinit=/init usbcore.autosuspend=-1 BOOT_IMAGE=/KERNEL boot=UUID=e2d05cb3-52a7-4c13-811c-ff9918556efe disk=UUID=13b65e6b-74a7-4a65-910f-49359823f7b3 quiet
[ 0.592626] usbcore: registered new interface driver usbfs
[ 0.592639] usbcore: registered new interface driver hub
[ 0.592654] usbcore: registered new device driver usb
[ 0.745668] usbcore: registered new interface driver rtsx_usb
[ 0.758303] usbcore: registered new interface driver uas
[ 0.758330] usbcore: registered new interface driver usb-storage
[ 0.789318] usbcore: registered new interface driver usbhid
[ 0.789324] usbhid: USB HID core driver
[ 1.114939] usb 1-4: new full-speed USB device number 2 using xhci_hcd
[ 1.246126] usb 1-4: string descriptor 0 read error: -22
[ 1.524888] usb 1-5: new high-speed USB device number 3 using xhci_hcd
[ 1.699548] usb-storage 1-5:1.0: USB Mass Storage device detected
[ 1.699661] scsi host2: usb-storage 1-5:1.0
[ 3.281104] usbcore: registered new interface driver ath3k
[ 3.281579] usb 1-4: USB disconnect, device number 2
[ 3.284714] usbcore: registered new interface driver btusb
[ 3.591476] usb 1-4: new full-speed USB device number 4 using xhci_hcd
[ 3.766957] usb 1-4: string descriptor 0 read error: -22
[ 18.606984] input: BD Remote Control as /devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.0/bluetooth/hci0/hci0:21/0005:054C:0306.0001/input/input14
LibreELECw:~ # lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 13fd:084c Initio Corporation
Bus 001 Device 004: ID 13d3:3393 IMC Networks
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
//edit
scsi host2: usb-storage 1-6:1.0
[13782.135792] scsi 2:0:0:0: CD-ROM TSSTcorp DVDWBD SE-406AB TS00 PQ: 0 ANSI: 0
[13782.142033] sr 2:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[13782.142512] sr 2:0:0:0: Attached scsi CD-ROM sr0
[13782.143150] sr 2:0:0:0: Attached scsi generic sg1 type 5
2016-06-27, 23:48
New LibreELEC.tv Krypton build #0627: Generic
(Supercedes previous build)
Based on tip of LibreELEC.tv master (df3c36b5, changelog) and tip of XBMC master (1f9e2a2c, changelog) with the following modifications:
# uname -a
Linux LibreELEC 4.6.2 #1 SMP Mon Jun 27 22:06:15 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160627220448-#0627-gdf3c36b [Build #0627]
- Includes FernetMenta "VideoPlayer" patches
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (d9e75d56, ahead +31)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: adsp.basic (2ae604e5), adsp.biquad.filters (5849a194, +7), adsp.freesurround (34f50406), asplib (da66f517), inputstream.mpd (b171dffe), inputstream.rtmp (8cebd150), inputstream.smoothstream (a38d40a2), peripheral.joystick (2db8029e), pvr.argustv (e536f32e), pvr.demo (01c68c88), pvr.dvblink (5f9872ca), pvr.dvbviewer (35902f5d), pvr.filmon (efd379b8), pvr.hdhomerun (a71e816d), pvr.hts (343ca980, +3), pvr.iptvsimple (1ea1f36e), pvr.mediaportal.tvserver (369b0189), pvr.mythtv (9141c6fc), pvr.nextpvr (7ed3111c), pvr.njoy (b5d65655), pvr.pctv (12d8baf1), pvr.stalker (ad1f7d67), pvr.vbox (b24c3cac), pvr.vdr.vnsi (5d5bb64e), pvr.vuplus (c988f849), pvr.wmc (ef4cf3b1)
- Includes commits from xbmc/master, ahead +5 (FernetMenta)
- Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: Enable other binary addons
- Include [env] patch: Add extra headers needed by 3D BD MVC
- Include [env] patch: Enable pvr and adsp addons, disable pvr/adsp updates
- Include [env] patch: Bump libbluray - include MVC support
- Include [env] patch: ffmpeg: update to ffmpeg 3.1, minimal Kodi specific commits
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] PR:477: ffmpeg: rework
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] dd81c2f1: [librtmp] Update to 15-Dec-2015 from http://stream-recorder.com/forum/customi...16103.html (kodi)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
- Include [pkg] PR:9976: VideoPlayer: expose stream player info to GUI
- Include [pkg] PR:10036: [PVR] Guide window: Fix timer icon issues (trac #16621)
- PR:10036: [PVR] Guide window: Fix timer icon issues (trac #16621)
- LibreELEC.tv:
- XBMC:
- ZeroconfMDNS.cpp: add header to fix compile with gcc 4.9 & uClibc (PR:10035, 1 commit, 1 file changed)
- pvr.hts:
- Fix setting channel type & setting epg uid (PR:232, 3 commits, 3 files changed)
- pvr.stalker:
- [debian] disable LTO (PR:66, 1 commit, 1 file changed)
- Added: [pkg] PR:10036: [PVR] Guide window: Fix timer icon issues (trac #16621)
2016-06-28, 00:45
Hi, would it be possible to have a choice of the 4.7 kernel again for the latest build(s)? It seemed to be much less prone to blank screens/wrong resolution output on my haswell nuc.
2016-06-28, 00:55
Blank screen when ? At boot ?
2016-06-28, 01:51
(2016-06-28, 00:45)csutcliff Wrote: [ -> ]Hi, would it be possible to have a choice of the 4.7 kernel again for the latest build(s)? It seemed to be much less prone to blank screens/wrong resolution output on my haswell nuc.
No. 4.7 will come in it's own time, the previous builds were one-off "toes in the water".
2016-06-28, 02:12
What about 4.6.3?
2016-06-28, 04:32
Be sure and let us know when "PR:9731: [WIP] 3dlut and simple ICC linking support for color correction" returns. Also waiting for passthru to work correctly again. That said, thanks for your work on this.
2016-06-28, 07:45
What's Happened To The Changelog Display ?
I've been keeping up with the bleeding edge of Krypton development pretty religiously (including #0625), and last night discovered I cannot display the Changelog text of ANY addon. How curious .
So I went back through time - restoring previous builds - until the text was successfully displayed... and found myself back at #0611. This is the debug log from #0611 where I am able to see the Changelog info displayed for the CBC video addon.
By way of contrast, here is the debug log of the same operations (ie: attempt to see CBC Changelog info) running the latest #0626 build. No luck... Nuthin' to See Here .
BTW, any/every build I tried > #0611 gave the same result - no Changelog text displayed.
Am I the only one to experience this loss of functionality ?
...and YES - I'm using the Krypton version of Xonfluence skin. I attempted to get results with Estuary, but could not even find a way to trigger a Changelog text display.
There are those who love Estuary... and I'm with the other group .
2016-06-28, 08:23
(2016-06-28, 07:45)gjwAudio Wrote: [ -> ]So I went back through time - restoring previous builds - until the text was successfully displayed... and found myself back at #0611. This is the debug log from #0611 where I am able to see the Changelog info displayed for the CBC video addon.
Thanks for identifying the last working build. The change in behaviour is due to the following change in #0612:
(2016-06-13, 00:24)Milhouse Wrote: [ -> ]
- Build Details:
- [addons] move changelog to addon.xml (PR:9351, 1 commit, 9 files changed)
Krypton compatible add-ons should now be using the <news> tag in addon.xml for changelog details. The changelog.txt file is no longer supported in Krypton (after PR9351).
As this change is not backwards compatible add-ons that do not support the <news> tag will not be able to display any changelog details in the latest Krypton builds. Very few addons have updated to support the new tag, and it may take some time before they do.
2016-06-28, 23:08
New LibreELEC.tv Krypton build #0628: Generic
Based on tip of LibreELEC.tv master (c0082832, changelog) and tip of XBMC master (c6f500ac, changelog) with the following modifications:
# uname -a
Linux LibreELEC 4.6.3 #1 SMP Tue Jun 28 21:06:43 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160628210522-#0628-gc008283 [Build #0628]
- Includes latest addons: adsp.basic (2ae604e5), adsp.biquad.filters (5849a194, +7), adsp.freesurround (34f50406), asplib (da66f517), inputstream.mpd (b171dffe), inputstream.rtmp (8cebd150), inputstream.smoothstream (a38d40a2), peripheral.joystick (2db8029e), pvr.argustv (e536f32e), pvr.demo (01c68c88), pvr.dvblink (5f9872ca), pvr.dvbviewer (35902f5d), pvr.filmon (efd379b8), pvr.hdhomerun (a71e816d), pvr.hts (343ca980), pvr.iptvsimple (1ea1f36e), pvr.mediaportal.tvserver (369b0189), pvr.mythtv (9141c6fc), pvr.nextpvr (7ed3111c), pvr.njoy (b5d65655), pvr.pctv (12d8baf1), pvr.stalker (ad1f7d67), pvr.vbox (b24c3cac), pvr.vdr.vnsi (5d5bb64e), pvr.vuplus (c988f849), pvr.wmc (ef4cf3b1)
- Includes commits from xbmc/AudioDSP/V2/usability_core_fixes, ahead +30 (AchimTuran)
- New 4.6.3 kernel
2016-06-29, 00:15
New kernel works fine for me
