2016-06-29, 02:27
(2016-06-29, 00:15)_Spook_ Wrote: [ -> ]New kernel works fine for me
Could you pleaae post your log ?
# journalctl -a | pastebinit
(2016-06-29, 05:11)vbat99 Wrote: [ -> ]What about remote repeat? That working in this new kernel?
(2016-06-29, 03:27)EricSol Wrote: [ -> ]So far so good on new kernel
http://sprunge.us/cXeO
Hdmi Plugged out error
(2016-06-29, 02:27)Roby77 Wrote: [ -> ]http://sprunge.us/eBAY(2016-06-29, 00:15)_Spook_ Wrote: [ -> ]New kernel works fine for me
(2016-06-29, 21:27)Cyr0wned Wrote: [ -> ]ive tested the 28.6 version, but still SPDIF with hifiberry is acting weird, on amazon prime app it does switchs my receiver to dolby or dts,but on apps like Radio, or xStream it doesnt switch to dolby at all.
(2016-06-29, 21:27)Cyr0wned Wrote: [ -> ]and a Question about the TV, possible to add iptv simple client to the skin?
(2016-06-29, 21:49)Kung-Foo-Kamel Wrote: [ -> ]Hi guys,
Have a weird one here, I have two Identical cherry trail machines, both have fresh installs of Libreelec with the same Milhouse 628 build, one consistently errors when trying to load the WMC PVR add-on and the other does not?? the add on will work but after a reboot it fails to load, I have wiped the system several times and installed builds from 610 and up, all of them do this, the only difference between the systems is one is using HDMI audio out and the other is using USB BOSE audio.
At first I thought it might have been the Test build of the Amber Skin, but even a fresh install with no add ons still results in the PVR add-on failing to load after a reboot.
I have log files from both units here, if you need me to post other logs just let me know what you need, also the 5.1 sound channels are still mixed up with Kernel 4.6.3.
https://1drv.ms/u/s!AmWyHDdgPG0ngZJw2oAuHuihF_kZMg
https://1drv.ms/u/s!AmWyHDdgPG0ngZJxOJE-P2ppJv04_w
Cheers
KFK
16:56:57 351.204620 T:140334486448192 ERROR: unable to load:/storage/.kodi/addons/skin.amber/1080i/DialogConfirm.xml, Line 0
Failed to open file
16:56:57 351.503998 T:140334486448192 ERROR: unable to load:/storage/.kodi/addons/skin.amber/1080i/DialogNotification.xml, Line 0
Failed to open file
16:57:39 393.494446 T:140334486448192 WARNING: CSkinInfo: failed to load skin settings
etc.
16:51:05 12.130283 T:140333753034496 ERROR: CCurlFile::FillBuffer - Failed: Couldn't resolve host name(6)
16:51:06 13.148792 T:140333081945856 ERROR: Exception in thread Thread-1:
File "/usr/lib/python2.7/threading.py", line 801, in __bootstrap_inner
File "/usr/lib/python2.7/threading.py", line 754, in run
File "/storage/.kodi/addons/plugin.video.plexbmc-Krypton/resources/lib/plex/plexgdm.py", line 268, in run_discovery_loop
self.discover()
File "/storage/.kodi/addons/plugin.video.plexbmc-Krypton/resources/lib/plex/plexgdm.py", line 178, in discover
sent = sock.sendto(self.discover_message, self.discover_group)
error: [Errno 101] Network is unreachable
16:51:06 13.150862 T:140333073553152 ERROR: Exception in thread Thread-2:
File "/storage/.kodi/addons/plugin.video.plexbmc-Krypton/resources/lib/plex/plexgdm.py", line 89, in client_update
update_sock.setsockopt(socket.IPPROTO_IP, socket.IP_ADD_MEMBERSHIP, socket.inet_aton(self._multicast_address) + socket.inet_aton('0.0.0.0'))
File "/usr/lib/python2.7/socket.py", line 228, in meth
error: [Errno 19] No such device
# uname -a
Linux LibreELEC 4.6.3 #1 SMP Wed Jun 29 21:05:43 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160629210400-#0629-gc008283 [Build #0629]
(2016-06-29, 23:08)Roby77 Wrote: [ -> ]Sorry @Milhouse but ir doesn't work
http://sprunge.us/bHWZ
