2016-04-20, 14:41
(2016-04-20, 10:49)_Spook_ Wrote: [ -> ]2. Stop using xf86-video-intel driver, switch to xf86 modesetting driver instead. Intel users: please report regressions!
Why?
Quite often the associated PR contains all the answers.
Why?
(2016-04-20, 13:58)diddle Wrote: [ -> ]Using Build #0418.
This may also be a tvheadend or pvr.hts issue... but since I'm using this build and all the Gurus are following this thread, I post here for clarification.
The following happened, see also Kodi debug log here: http://paste.ubuntu.com/15946112/
21:44:53
switched to live TV channel "Das Erste", watched football. Not a single issue until:
22:46:25
end of the show, stream seems to be changing (guess the audi channels). Playback suddenly freezes, stutters, Audio dead, silience. Some seconds later Audio resumes, however the stream gets unwatchable from now on. Lots of block artifacts, stuttering. Does not recover from this...
22:47:03
I tried to skip forward (which helped sometimes). Stuttering remained. Same issue.
22:47:14
I stopped the stream. Afterwards I played again "Das Erste"... and all is fine again. Problem disappeared.
Any idea what happened here at 22:46:25? Seeing such symptoms quite frequently.
Thx
Diddle.
(2016-04-20, 14:41)Milhouse Wrote: [ -> ](2016-04-20, 10:49)_Spook_ Wrote: [ -> ]2. Stop using xf86-video-intel driver, switch to xf86 modesetting driver instead. Intel users: please report regressions!
Why?
# uname -a
Linux LibreELEC 4.4.7 #1 SMP Thu Apr 21 04:09:42 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160421040821-#0420-gfee76be [Build #0420]
(2016-04-20, 14:45)fritsch Wrote: [ -> ](2016-04-20, 13:58)diddle Wrote: [ -> ]Using Build #0418.
21:44:53
22:46:25
22:47:03
22:47:14
Thx
Diddle.
Please head over to the tvheadend part of the PVR forum and post your Debug Log there.
(2016-04-19, 20:20)Milhouse Wrote: [ -> ]We continue to ship the "os.openelec.tv" addon as part of LE7, and also these initial LE8 builds, for reasons of backward compatibility.
Longer term it will be dropped, and probably won't be in LE8 official releases, so addons should not depend on "os.openelec.tv" being available and should use "os.libreelec.tv" instead. As I'm not an add-on developer I don't know what the best solution for this is, from an add-on developers point of view - perhaps make both add-ons optional, and then decide which is available at run-time?
16:59:50 80373.945312 T:140280563066624 ERROR: CAddonInstallJob[script.openelec.devupdate]: The dependency on os.openelec.tv version 4.0 could not be satisfied.
(2016-04-20, 15:51)mule1 Wrote: [ -> ]I just switched from fritsch build to milhouse build and after some skips in .ts-files I'm getting extreme playback hiccups (distortion, frame repeating, pausing etc.). This behaviour is reproducable every time I do some skipping. The kodi log is being flooded with "VAAPI" warnings/erros. I tried the latest milhouse build and many different older ones (even back to #0214). All l tried builds show the same behaviour on my Intel NUC 34010. Only switching back to a fritsch build (older or newer ones) solves this issue.
Kodi log: http://pastebin.com/Y9PHC3kR
(2016-04-20, 15:51)mule1 Wrote: [ -> ]I just switched from fritsch build to milhouse build and after some skips in .ts-files I'm getting extreme playback hiccups (distortion, frame repeating, pausing etc.). This behaviour is reproducable every time I do some skipping. The kodi log is being flooded with "VAAPI" warnings/erros. I tried the latest milhouse build and many different older ones (even back to #0214). All l tried builds show the same behaviour on my Intel NUC 34010. Only switching back to a fritsch build (older or newer ones) solves this issue.With the latest build #0420 .ts-files are unwatchable because the hiccups begin right after the start of the playback. With builds #0419 and before the hiccups first start after some skipping as described above.
(2016-04-21, 17:03)michi_jl Wrote: [ -> ]So why could the addon be missing here?Run the following command and paste the output:
Code:16:59:50 80373.945312 T:140280563066624 ERROR: CAddonInstallJob[script.openelec.devupdate]: The dependency on os.openelec.tv version 4.0 could not be satisfied.
sqlite3 /storage/.kodi/userdata/Database/Addons23.db "select * from installed where addonID like 'os.%'"
(2016-04-21, 20:23)michi_jl Wrote: [ -> ]I also got another problem which i haven't had bevore on any other kodi version:
On some (most) videos the borders of the screen are cut off.
In the gui everything is fine, but as soon as a video plays its cut off. What can i do to solve this?
