(2016-07-09, 22:04)Milhouse Wrote: [ -> ] (2016-07-09, 21:45)pyrodex Wrote: [ -> ] (2016-07-08, 23:53)Milhouse Wrote: [ -> ]New LibreELEC.tv Krypton build #0708: Generic- Revert "vdpau: refcount decoder with surfaces given to ffmpeg, align with vaa…" (PR:10092, 1 commit, 2 files changed)
Milhouse,
I noticed with builds after #703, seems to not exhibit this issue, that with an AMD APU (A6-3500) I noticed over time when watching shows there is tremendous LAG or stutter down the road. I saw this commit was reverted mentioned in the quote hoping it would fix the issue since #703 but no luck. I will try to get a debug log once the wife is done watching her shows but wanted to know if anyone else here experience the issue.
My RPI2/RPI3's aren't affected by the same issue and are running #708 perfectly fine.
I'm trying to parse your comment... are you saying you have a problem with builds after #0703 (ie. the problem starts with build #0704)? Or does the problem start with #0703?
PR10092 is reverting PR10075 which first appeared in build #0707 - the latter PR introduced a significant memory leak, which should now no longer be present. Since you say (if I'm reading your post correctly) that the lag/stutter problem started with #0704 (or maybe #0703) then I'm not sure I see any connection between the two PRs (PR10075 and PR10092), unless I've misunderstood your post.
The obvious change in #0704 is the switch to kernel 4.7-rc6. If however you're saying the problem started with #0703, then the obvious change is ffmpeg 3.1.1.
Can you state the issue clearly, and when it first started. A debug log would be very useful.
Sorry #703 is stable for me, I jumped from #703 to #707 and then noticed the issue. I can try going up in builds if you want or is there a specific number before 707 you want me to test?
(2016-07-09, 22:22)pyrodex Wrote: [ -> ]Sorry #703 is stable for me, I jumped from #703 to #707 and then noticed the issue. I can try going up in builds if you want or is there a specific number before 707 you want me to test?
In that case #0708 should be good again, as that reverts the change added in #0707 (assuming the problem starts with #0707, and is due to PR10075, which would now seem unlikely if you continue to have this problem in #0708).
What you also have is a new kernel in #0704, so trying #0704, #0705 and #0706 in turn until you reproduce the problem will help focus attention on the first build that has this lag/stutter problem.
Once we know the first build when the lag/stutter starts it should be possible to start making more educated guesses. A debug log from the latest build #0708 may also help shed some light on what is causing the lag/stutter.
New LibreELEC.tv Krypton build #0709:
Generic
(Supercedes previous build)
# uname -a
Linux LibreELEC 4.7.0-rc6 #1 SMP Sat Jul 9 21:13:04 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160709211042-#0709-gf78c95e [Build #0709]
Based on tip of
LibreELEC.tv master (f78c95ef,
changelog) and tip of
XBMC master (8bd8cf48,
- Includes FernetMenta "VideoPlayer" patches
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (fac3a954, ahead +34)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: adsp.basic (2ae604e5), adsp.biquad.filters (5849a194, +7), adsp.freesurround (34f50406), asplib (da66f517), inputstream.mpd (aad30ba0, +13), inputstream.rtmp (7bf2298e), inputstream.smoothstream (8dbe3ba4, +2), peripheral.joystick (2db8029e), pvr.argustv (e536f32e), pvr.demo (01c68c88), pvr.dvblink (0bf16840, +1), pvr.dvbviewer (35902f5d), pvr.filmon (efd379b8), pvr.hdhomerun (a71e816d), pvr.hts (856e72a4, +1), pvr.iptvsimple (1ea1f36e), pvr.mediaportal.tvserver (3ba23b7b, +1), pvr.mythtv (02fa50d5, +1), pvr.nextpvr (ecbd6e5c, +1), pvr.njoy (b5d65655), pvr.pctv (12d8baf1), pvr.stalker (415aa54b, +3), pvr.vbox (36d3717b, +1), pvr.vdr.vnsi (d7bc89eb, +5), pvr.vuplus (d7f5685a, +1), pvr.wmc (1f3240da, +1)
- Includes commits from xbmc/master, ahead +7 (FernetMenta)
- Includes commits from xbmc/AudioDSP/V2/usability_core_fixes, ahead +33 (AchimTuran)
- Include [env] e7cbe9cb: xf86-video-intel: Explicitely disable TearFree and TripleBuffer
- Include [env] ed774729: Intel: Implement Passthrough-Range
- Include [env] 98c65e6a: Kodi: Use Limited Range by default
- Include [env] patch: Enable other binary addons
- Include [env] patch: Enable pvr and adsp addons
- Include [env] patch: Install libbrcmEGL/libbrcmGLESv2 shared libraries, with sym links for backward compatability
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] patch: ffmpeg: bump 3.1.1
- Include [env] PR:481: linux: Update to 4.7 (WIP)
- Include [env] PR:526: Cpu temperature readings for devices with aml_thermal interface
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: drm/i915: Extend Fake HDMI live status to Valley View (linux)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:9803: [PeripheralCecAdapter] fix playback stopping on screensaver deactivated
Build Highlights:
- Bump mesa 12.0.1
- Update Intel CPU firmware
Build Details:
- LibreELEC.tv:
- update mesa to 12.0.1 (PR:527, 1 commit, 1 file changed)
- update cpu-firmware to latest release (PR:528, 1 commit, 1 file changed)
- XBMC:
- [cmake/android] Install librtmp (PR:10094, 1 commit, 1 file changed)
- fix test suite by declaring a deleter for CDataCacheCore (PR:10090, 1 commit, 3 files changed)
- Freebsd cmake (PR:10087, 7 commits, 8 files changed)
- Added: [env] PR:526: Cpu temperature readings for devices with aml_thermal interface
Millhouse, thank you, it looks and runs good.
(2016-07-10, 05:21)piotrasd Wrote: [ -> ]@MadMeddler here my latest build https://mega.nz/#!55wyhQyT!xZ8Sc1PO9KZYl...aOxFKp9tqs (based on great Milhouse work and with changes for CherryTrail )
piotrasd
It looks like your build has broken the LAN adapter (though the audio over HDMI has worked a treat). I haven't tried the 0709 Milhouse build as yet for comparison.
"it looks like" is not an error description ;-)
Please post logs or it will get insanely hard for piotrasd to keep his builds up and running.
MadMeddler please send me dmsg, lsusb i lspci from working buid.
I disabled most device in kernel, most z8300 miniPC has no PCI, so example i disabled whole tree of tuners DVB on PCIE, and many other stuff.
Let me know on PM what do you need (with logs)
@piotrasd: If you plan to get that stuff back in upstream, you should have as minimal changes as possible.
fritsch i just made version for my devices so i have very minimal kernel etc.
but now when i see Milhouse go into kernel 4.7 i will prepare second one for users with BT/CHT devices with default kernel config from LE
UPDATE:
here latest version with default LE linux config
https://mega.nz/#!E85HARaC!1kaed31FR4Otw...SX3LKRpNBg
PS. default password "le"
fritsch - Apologies, you're quite right - poor reporting on my part. I will do better.
piotrasd - Any idea how I can get your update onto my box, given no LAN connectivity and the WiFi dongle I have isn't being recognised either. I've tried using a USB stick and using FileManager to copy the file to .update without success (no sign of the USB stick being recognised). Is there a mechanism for dropping to a command prompt to try an manually mount the USB stick?
Once I can do any of that I can try and provide some logs etc, also I'd like to be able to copy my Kodi config off the box - just in case I need to revert back to the original LE image.
copy on USB connect to BOX and from SSH copy to /storage/.update
or from FileManager in kodi - but in setting you must Enable show hiden files
Ah, but I can't SSH because I have no network :-)
I can add the destination (/storage/.update), but I can't add the source - it doesn't seem to recognise any USB sticks I present to the box.
Don't worry, I'll wipe and start again - not the end of the world.
New LibreELEC.tv Krypton build #0710:
Generic
# uname -a
Linux LibreELEC 4.7.0-rc6 #1 SMP Sun Jul 10 21:59:53 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160710215831-#0710-g1cfefd3 [Build #0710]
Based on tip of
LibreELEC.tv master (1cfefd35,
XBMC master (a6a8c5bb,
- Includes commits from xbmc/master, ahead +5 (FernetMenta)
Build Highlights:
- Minors
Build Details:
- LibreELEC.tv:
- libssh: change url (PR:531, 1 commit, 1 file changed)
- projects/imx6: update Linux kernel, libcec and Kodi Krypton (PR:533, 1 commit, 16 files changed)
- distro-tool: Change default target after server move from web01 to web03 (PR:532, 1 commit, 1 file changed)
- amremote update to latest d4f6458 (PR:529, 1 commit, 1 file changed)
- XBMC:
- [depends] build curl without librtmp support (PR:10086, 1 commit, 1 file changed)
- VideoPlayer: update selectionstreams when stream parameters changes (PR:10097, 1 commit, 1 file changed)
- Duplicate include removed (PR:10099, 2 commits, 1 file changed)
- xbmc/master (FernetMenta):
- Commits no longer in build:
- VideoPlayer: fix setting pixel format for ffmpeg (7fc748e1)
- change gui info from Player_Process.xxx to Player.Process(%s) (af42298b)
(2016-07-10, 17:46)piotrasd Wrote: [ -> ]...
UPDATE:
piotrasd
Thanks for the update. I've finally gotten around to updating from the Milhouse #0703 to your Dev build from yesterday and everything seems to be working fine. I have audio, Ethernet and USB sticks all showing up as I'd hoped.
