(2016-07-31, 21:59)Hitcher Wrote: [ -> ]It's actually 'PlayerProcessInfo' and I'm guessing Aeon Nox 5 hasn't been updated to reflect the changes yet. If you're using nightlies that involve changes to the skinning engine you should stick to using Estuary.
Milhouse wrote :
[quote name="Milhouse"]
Sorry, there was a mistake in the changelog - "CodecInfo" is renamed to "PlayerDebug" (not "ProcessDebug" - posts have been corrected).
[/quote]
I think >PlayerProcessInfo< is the new dialog and the old one is still available with the renamed value >PlayerDebug<
Gesendet von meinem E5823 mit Tapatalk
PlayerDebug (new name for CodecInfo) is available on all platforms, just as it's always been, but is no longer mapped to any buttons or keys by default (this is now PlayerProcessInfo).
However the usefulness of the PlayerDebug (formerly CodecInfo) overlay will vary from platform to platform - the Raspberry Pi builds include additional information that are not in upstream Kodi.
(2016-07-31, 19:53)Milhouse Wrote: [ -> ]Arghh... I blame it on the late hour.
OK in build #0423 there's a mesa bump and a major kerenl bump, so it looks like a bug in either of those (most likely the kernel). It's hard to say what is causing the problem without clearer logs.
If it's a problem that occurs at shutdown then you could add "debugging" to /flash/EFI/BOOT/syslinux.cfg (UEFI) or /flash/extlinux.conf (legacy BIOS) and that should preserve your system log across reboots. Then trigger the problem, restart the system and upload your journal with "journalctl -a | pastebinit" - it may include a clue as to what is happening (no promises on a fix though).
Edit: Also, just to be clear on the actual problem - you said:
Quote:I have a Zotac Zbox CI520, which was running the #0419 build. After I installed the #0503 something is f'ed up with the power and or IR-settings. After a shutdown it won't power up with the remote, I have to do it manually.
With #0419 were you powering off the box, or putting it into standby? From the #0510 log you sent me, it looks like you're shutting down Kodi (which crashed due to nfs which you say isn't an issue) and thus powering off the box. Whenever I power off my boxes, they don't come back on with a remote control - never have, never will... they only wake from standby.
If you intended to put your box into standby on shutdown, check you still have the "Suspend" option selected as the "Shutdown function" in Kodi Settings > System > Power Saving.
I always shutdown the devices, and "Shutdown" is the selected Shutdown function.
The log can be found here:
http://sprunge.us/SSeE
For comparison, the working build (#418):
http://sprunge.us/bgFW
Hope it helps to find the problem
New LibreELEC.tv Krypton build #0731:
Generic
(Supercedes previous build)
# uname -a
Linux NUC 4.7.0 #1 SMP Sun Jul 31 21:55:05 BST 2016 x86_64 GNU/Linux
# lsb_release
LibreELEC (Milhouse) - Version: devel-20160731215307-#0731-ge36a73e [Build #0731]
Based on tip of
LibreELEC.tv master (e36a73e7,
changelog) and tip of
XBMC master (d0d1790e,
- Includes FernetMenta "VideoPlayer" patches
- Includes latest kodi-platform master (c8188d82)
- Includes latest libcec master (6d68d212)
- Includes latest libnfs master (fac3a954, ahead +34)
- Includes latest p8-platform master (041a8c6c, ahead +1)
- Includes latest addons: inputstream.mpd (51271e1a, +23), inputstream.rtmp (7bf2298e), inputstream.smoothstream (99e77711, +4), peripheral.joystick (6090a90e, +1), pvr.argustv (e536f32e), pvr.demo (01c68c88), pvr.dvblink (20e1ccb4, +2), pvr.dvbviewer (7a7ead36, +1), pvr.filmon (efd379b8), pvr.hdhomerun (a71e816d), pvr.hts (66dcb89f, +2), pvr.iptvsimple (21e91a5f, +1), pvr.mediaportal.tvserver (72452b9d, +2), pvr.mythtv (d10d210b, +8), pvr.nextpvr (32b3c2ff, +2), pvr.njoy (b5d65655), pvr.pctv (12d8baf1), pvr.stalker (b6cb9b87, +9), pvr.vbox (f38f82f0, +2), pvr.vdr.vnsi (8515b4bf, +6), pvr.vuplus (4f2ad621, +2), pvr.wmc (979c37db, +2)
- Includes commits from xbmc/master, ahead +8 (FernetMenta)
- Include [env] patch: Add kodi binary addons (pvr, adsp, other)
- Include [env] patch: Don't build ADSP addons
- Include [env] patch: kodi-theme-Estuary: No more png in root
- Include [env] patch: kodi: Revert cache clearing - replaced by PR9225
- Include [env] patch: HACK: Disable multiple PVR addons during migration. Always enable inputstream.*, os.* and peripheral.*
- Include [env] patch: ffmpeg: bump 3.1.1
- Include [env] PR:535: init: Add upgrade check to avoid incompatible upgrades [RFC,WIP]
- Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
- Include [pkg] 441217d8: logging: Add microsecond timer to log messages (kodi)
- Include [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
- Include [pkg] PR:171: fix seeklabel (kodi-theme-Estuary)
- Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
- Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
- Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
- Include [pkg] PR:10157: [WIP] Double the backslash in mysql in case we're in 'LIKE'
- Include [pkg] PR:10206: [xbmc/fix/filesystem] Add a recursive version of CDirectory::Remove (kodi)
Build Highlights:
- Kodi 17 Beta 1
- Reorganise Library Settings (now called Media Settings)
- Fix removal of cached files in archive_cache (PR10206)
- Drop Intel tear-free, triple buffer, passhtrough and limited-range commits (see PR:573 for details)
Build Details:
- LibreELEC.tv:
- linux: Update to 4.7 (WIP) (PR:481, 9 commits, 46 files changed)
- Generic: Add support for SIL680 PCI/ATA controller (PR:583, 1 commit, 1 file changed)
- u-boot: Fix update.sh script for imx6 (PR:586, 1 commit, 1 file changed)
- docker: support for imx6 project (PR:587, 1 commit, 1 file changed)
- webgrabplus: update to 56.28pre-20160729 (PR:584, 1 commit, 2 files changed)
- docker: include docker-proxy (PR:589, 1 commit, 2 files changed)
- XBMC:
- [PVR] Timers: Fix changing timer type after creation. (PR:10198, 1 commit, 5 files changed)
- [addons] fix event handling (PR:10156, 4 commits, 28 files changed)
- [osx] fix media key control for next and previous track (PR:10182, 1 commit, 1 file changed)
- remove win32 win10sdk dependency (PR:10197, 1 commit, 1 file changed)
- [cmake/win32] Mirror system/python/* into the build-tree (PR:10193, 1 commit, 1 file changed)
- [SETTINGS] Add Source settings to call source selection windows... (PR:10199, 5 commits, 12 files changed)
- rework to ACTION_PLAYER_PROCESS_INFO (PR:10192, 5 commits, 12 files changed)
- VideoPlayer: drop deinterlace mode (PR:10149, 1 commit, 39 files changed)
- bump to 17 beta 1 (PR:10183, 1 commit, 3 files changed)
- Added: [pkg] PR:10206: [xbmc/fix/filesystem] Add a recursive version of CDirectory::Remove (kodi)
- Updated: [pkg] patch: [skin.estuary] Hide watched items on home (kodi-theme-Estuary)
(2016-07-31, 23:21)tinzarian Wrote: [ -> ]I always shutdown the devices, and "Shutdown" is the selected Shutdown function.
The log can be found here: http://sprunge.us/SSeE
For comparison, the working build (#418): http://sprunge.us/bgFW
Kodi segfaulting due to NFS everytime it is shutdown is not good. I'm seeing that here too - will try and work out when that started.
As for your two logs, both systems (one with 4.7.0 kernel, other with 4.4.7) appear to complete the shutdown more or less normally.
Presumably with 4.4.7, the machine is left in a state where it can be woken up (from power off) on receipt of an IR signal, and this isn't happening since 4.6-rc4. This would look like a kernel (and/or BIOS) bug of some sort. Since the machine has been "powered off", I guess you are resuming from the S5 sleep state, which is no longer working since 4.6-rc4.
(2016-08-01, 00:16)Milhouse Wrote: [ -> ]New LibreELEC.tv Krypton build #0731: Generic
# uname -a
# lsb_release
Based on tip of LibreELEC.tv master (e36a73e7, changelog) and tip of XBMC master (d0d1790e, changelog) with the following modifications:- Includes FernetMenta "VideoPlayer" patches
Build Highlights:
- Kodi 17 Beta 1
Build Details:
- LibreELEC.tv:
- XBMC:
Milhouse thank you for adding SIL680 support. Now what if I have some sort of issue with this build. I report the issue here but If I want to downgrade is that possible? Would I be able to retain SIL680 support somehow?
UPDATE: I tried it and sure enough a xorg problem. failed to start xorg server. Dependencies not met for fluxbox. Is legacy driver 304.xx included? See:
http://www.nvidia.com/Download/driverRes...0399/en-us This has to be because my graphics card is aging but still awesome at playing 1080p h264 video in libreElec 7.0.2. I have a Geforce 7900 GTX with 512mb DDR3 ram. Its a bad ass graphics card I dont care who says its old and past its prime, this thing rocks.
Update 2: It seems linux nvidia driver 304.131 is included. I have no idea what the issue is than.
(2016-08-01, 01:27)madhits Wrote: [ -> ]Milhouse thank you for adding SIL680 support. Now what if I have some sort of issue with this build. I report the issue here but If I want to downgrade is that possible? Would I be able to retain SIL680 support somehow?
You can downgrade, but you won't retain SIL680 support.
(2016-08-01, 01:27)madhits Wrote: [ -> ]UPDATE: I tried it and sure enough a xorg problem. failed to start xorg server. Dependencies not met for fluxbox. This has to be because my graphics card is aging but still awesome at playing 1080p h264 video in libreElec 7.0.2. I have a Geforce 7900 GTX with 512mb DDR3 ram. Its a bad ass graphics card I dont care who says its old and past its prime, this thing rocks.
Seriously? You hadn't even tried this build before asking for a new config option for your hardware? Since you're likely the only potential user for SIL680 I'll revert that change. Unfortunately your hardware isn't supported by these builds, nor any future builds. It's time to upgrade.
(2016-08-01, 01:27)madhits Wrote: [ -> ]UPDATE: I tried it and sure enough a xorg problem. failed to start xorg server. Dependencies not met for fluxbox. Is legacy driver 304.xx included? See: http://www.nvidia.com/Download/driverRes...0399/en-us This has to be because my graphics card is aging but still awesome at playing 1080p h264 video in libreElec 7.0.2. I have a Geforce 7900 GTX with 512mb DDR3 ram. Its a bad ass graphics card I dont care who says its old and past its prime, this thing rocks.
Nope, Nvidia Legacy uses the 340.96 driver. Current Nvidia hardware (non-legacy) uses 367.35. Neither support GeForce 7900 GTX.
We switched from 304.131 to 340.96 in April at the request of other nvidia users that considered the 340 driver to be superior in terms of image quality to the 304 driver.
You can still find the 304.131 driver in LibreELEC 7.0.x, but in LibreELEC 8.x (and these test builds) the legacy driver will be 340.96.
I'm afraid you're out of luck on the GPU driver front as far as these builds and LibreELEC 8.x+ is concerned.
(2016-08-01, 01:54)Milhouse Wrote: [ -> ] (2016-08-01, 01:27)madhits Wrote: [ -> ]Milhouse thank you for adding SIL680 support. Now what if I have some sort of issue with this build. I report the issue here but If I want to downgrade is that possible? Would I be able to retain SIL680 support somehow?
Ohh No.. I did not know I needed to request a config. Is there anyway I can submit one now? The process is really new to me. So Sorry.. Please Milhouse Sil680 and my geforce 7900 work great. I did try to mismatch kernal and system from 7.0.2 and sure enough no luck getting it to boot.
Please dont drop SIL680 its only a few KB kernal edit and really will make my system complete. Even if I have to stay on this build forever its fine.
(2016-08-01, 02:13)madhits Wrote: [ -> ]Ohh No.. I did not know I needed to request a config. Is there anyway I can submit one now?
I meant the config for SIL680, which I added for you, only to discover tonight that your graphics card is too old which means there was really no point in me adding the SIL680 support.
(2016-08-01, 02:13)madhits Wrote: [ -> ]Please Milhouse Sil680 and my geforce 7900 work great.
I'm sure they do but we don't support the 7900 and there's no way that we can support it without downgrading the existing driver, which then affects all the users of more recent hardware.
Your best option is a custom (self) build of LibreELEC 8, where you can downgrade the nvidia-legacy driver to whatever version you require (ie. 304.131). And if you're self building you can easily add the SIL680 config option too, killing two birds with one stone.
Alternatively, replace your ageing hardware with a Raspberry Pi3...
(2016-08-01, 02:13)madhits Wrote: [ -> ]I did try to mismatch kernal and system from 7.0.2 and sure enough no luck getting it to boot.
Yep, that won't work.
(2016-08-01, 02:13)madhits Wrote: [ -> ]Please dont drop SIL680 its only a few KB kernal edit and really will make my system complete. Even if I have to stay on this build forever its fine.
But the build doesn't work because of your graphics card... what point is there in retaining support for the SIL680 when you (the only person that needed it) can't use it? Or am I missing something here?
Since Fritsch's Intel improvements have been dropped whats the easiest way to add them back?
(2016-08-01, 00:59)Milhouse Wrote: [ -> ]Kodi segfaulting due to NFS everytime it is shutdown is not good. I'm seeing that here too - will try and work out when that started.
Turns out it's not a new issue, nor is is LibreELEC specific:
http://trac.kodi.tv/ticket/16425#comment:1
May possibly be x86_64 specific, as it's not reproducible on RPi/RPi2.
(2016-08-01, 02:44)EricSol Wrote: [ -> ]Since Fritsch's Intel improvements have been dropped whats the easiest way to add them back?
Read the pull request. You should be able to add the xrandr commands to your autostart.sh.
