(2016-08-01, 07:39)atoulmin Wrote: [ -> ]Understand, but why fix something for Nvidia users by screwing over Intel users in the process?
It's not so much fixing anything for Nvidia users, the simple fact is that these Intel patches (in their current form) are not going to be merged so why continue using them in these test builds?
The purpose of these builds is to test changes that *will* be committed upstream. By including commits that are only in these builds and are never merged upstream I could be introducing problems that are not seen in official releases. Or worse, I could be masking problems that are then only seen in official releases once it affects tens of thousands of users.
Yes, I/we realise it sucks to drop these Intel commits. Patches welcome.
(2016-08-01, 08:45)Milhouse Wrote: [ -> ] (2016-08-01, 07:39)atoulmin Wrote: [ -> ]Understand, but why fix something for Nvidia users by screwing over Intel users in the process?
Fair enough an understandable.
According to the discussions it seems adding the appropriate commands to the autostart.sh file will fix the issue for intel users anyway?
(2016-08-01, 09:05)atoulmin Wrote: [ -> ]According to the discussions it seems adding the appropriate commands to the autostart.sh file will fix the issue for intel users anyway?
Yes it should do. It's not ideal, but for those willing to edit autostart.sh then that is the solution. Hopefully longer term a solution will emerge that makes editing autostart.sh unnecessary.
So can someone confirm this is what's needed in the autostart.sh to patch intel?
OUTPUT=`xrandr -display :0 -q | sed '/ connected/!d;s/ .*//;q'`
xrandr -display :0 --output $OUTPUT --set "Broadcast RGB" "Full"
No ... just look at the dropped patch ... it's all in there.
Thx for dropping the intel drivers! Instead of a movie I can watch a green screen now :/
@Fritsch: Can you provide more info or post the script how to patch it? I'm a noob in that
(2016-08-01, 18:12)Tequilla9 Wrote: [ -> ]Thx for dropping the intel drivers! Instead of a movie I can watch a green screen now :/
Not related, but another commits most likely Updates deint settings in a non compatible way. Try changing these while playing a video.
Hi all
thanks for you great work with this project
i have a ?
i used to use the #0604 with intel cherry audio support, and i have sound, then ive updated to the latest version #0730 , and now i have no sound ?
any ideas ?
im using Tronsmart ara x5
/ Stainlessdk
intel cherry audio is _not_ supported. It lives somewhere out of tree and it will eventually come back if it properly fits into the patchset. This is when the upstream author merges it mainline or when he rebases on kernel 3.7
For the green screen:
https://github.com/xbmc/xbmc/pull/10211 <- this will fix it.
Yes. Don't copy the #!/bin/sh twice.
Use it in combination with kodi's "Use Limited Range" setting.
