2016-04-17, 18:40
Hello, could you please help?
I have Kodi installed on a fresh Ubuntu 16.04. Using the Ubuntu repository I can run VDR and VNSI with a DVBT-stick. This works fine, but I dont like the old version. So I installed Kodi 16 from the team-xbmc/trusty ppa. I am trying to setup live-tv with no success. I tried several ppa's with vdr and vdr-plugin-vnsiserver all giving the same error. Now I followed the Receipt "How to compile vdr + vnsiserver from source" which seemed to work. At least vdr runs from the terminal without error message. Of course vdr is not yet finally configured witch channels.conf etc. But when I try to activate TV I get the same error again as before in kodi.log:
I have absolutely no idea what to do now. This is the complete kodi.log:
Please give advice, how to go on, thanks.
ERROR: ADDON: Could not locate pvr.vdr.vnsi.so
18:53:09 T:140544584116544 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:53:09 T:140544584116544 NOTICE: -----------------------------------------------------------------------
18:53:09 T:140544584116544 NOTICE: Starting Kodi (16.0 Git:a5f3a99). Platform: Linux x86 64-bit
18:53:09 T:140544584116544 NOTICE: Using Release Kodi x64 build
18:53:09 T:140544584116544 NOTICE: Kodi compiled Feb 28 2016 by GCC 5.3.1 for Linux x86 64-bit version 4.4.2 (263170)
18:53:09 T:140544584116544 NOTICE: Running on Ubuntu 16.04 LTS, kernel: Linux x86 64-bit version 4.4.0-18-generic
18:53:09 T:140544584116544 NOTICE: FFmpeg statically linked, version: 2.8.6-kodi-2.8.6-Jarvis-16.0
18:53:09 T:140544584116544 NOTICE: Host CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz, 4 cores available
18:53:09 T:140544584116544 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
18:53:09 T:140544584116544 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
18:53:09 T:140544584116544 NOTICE: special://masterprofile/ is mapped to: /home/mike/.kodi/userdata
18:53:09 T:140544584116544 NOTICE: special://home/ is mapped to: /home/mike/.kodi
18:53:09 T:140544584116544 NOTICE: special://temp/ is mapped to: /home/mike/.kodi/temp
18:53:09 T:140544584116544 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
18:53:09 T:140544584116544 NOTICE: Local hostname: ubuntix
18:53:09 T:140544584116544 NOTICE: Log File is located: /home/mike/.kodi/temp/kodi.log
18:53:09 T:140544584116544 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - Keine derartige Eigenschaft »OnLowBattery«
18:53:09 T:140544584116544 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - Keine derartige Eigenschaft »CanSuspend«
18:53:09 T:140544584116544 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - Keine derartige Eigenschaft »CanHibernate«
18:53:09 T:140544584116544 NOTICE: load settings...
18:53:09 T:140544584116544 NOTICE: Found 1 Lists of Devices
18:53:09 T:140544584116544 NOTICE: Enumerated PULSE devices:
18:53:09 T:140544584116544 NOTICE: Device 1
18:53:09 T:140544584116544 NOTICE: m_deviceName : Default
18:53:09 T:140544584116544 NOTICE: m_displayName : Default
18:53:09 T:140544584116544 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO)
18:53:09 T:140544584116544 NOTICE: m_deviceType : AE_DEVTYPE_PCM
18:53:09 T:140544584116544 NOTICE: m_channels : FL,FR
18:53:09 T:140544584116544 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
18:53:09 T:140544584116544 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
18:53:09 T:140544584116544 NOTICE: Device 2
18:53:09 T:140544584116544 NOTICE: m_deviceName : alsa_output.pci-0000_00_1b.0.analog-stereo
18:53:09 T:140544584116544 NOTICE: m_displayName : Internes Audio Analog Stereo
18:53:09 T:140544584116544 NOTICE: m_displayNameExtra: Line-Ausgang (PULSEAUDIO)
18:53:09 T:140544584116544 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
18:53:09 T:140544584116544 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
18:53:09 T:140544584116544 NOTICE: Default DVD Player: dvdplayer
18:53:09 T:140544584116544 NOTICE: Default Video Player: dvdplayer
18:53:09 T:140544584116544 NOTICE: Default Audio Player: paplayer
18:53:09 T:140544584116544 NOTICE: Disabled debug logging due to GUI setting. Level 0.
18:53:09 T:140544584116544 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
18:53:09 T:140544584116544 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
18:53:09 T:140544584116544 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:53:09 T:140544584116544 NOTICE: Loaded playercorefactory configuration
18:53:09 T:140544584116544 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:53:09 T:140544584116544 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:53:09 T:140544096491264 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
18:53:09 T:140544584116544 NOTICE: Running database version Addons20
18:53:09 T:140544584116544 NOTICE: ADDONS: Using repository repository.xbmc.org
18:53:09 T:140544584116544 NOTICE: Setup SDL
18:53:10 T:140544584116544 NOTICE: Checking resolution 15
18:53:10 T:140544584116544 NOTICE: Using visual 0x20
18:53:10 T:140544584116544 NOTICE: GL_VENDOR = Intel Open Source Technology Center
18:53:10 T:140544584116544 NOTICE: GL_RENDERER = Mesa DRI Intel(R) Sandybridge Desktop
18:53:10 T:140544584116544 NOTICE: GL_VERSION = 3.0 Mesa 11.2.0
18:53:10 T:140544584116544 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
18:53:10 T:140544584116544 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_AMD_performance_monitor GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_draw_buffers_blend GL_AMD_seamless_cubemap_per_texture GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_cube_map_array GL_ARB_texture_gather GL_ARB_texture_multisample GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_NV_texture_barrier GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_timer_query GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_compressed_texture_pixel_storage GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_shader_trinary_minmax GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_clear_buffer_object GL_ARB_copy_image GL_ARB_explicit_uniform_location GL_ARB_invalidate_subdata GL_ARB_program_interface_query GL_ARB_texture_query_levels GL_ARB_texture_storage_multisample GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_buffer_storage GL_ARB_clear_texture GL_ARB_multi_bind GL_ARB_seamless_cubemap_per_texture GL_ARB_shader_draw_parameters GL_ARB_texture_mirror_clamp_to_edge GL_ARB_vertex_type_10f_11f_11f_rev GL_EXT_shader_integer_mix GL_INTEL_performance_query GL_ARB_clip_control GL_ARB_conditional_render_inverted GL_ARB_get_texture_sub_image GL_ARB_pipeline_statistics_query GL_ARB_texture_barrier GL_EXT_polygon_offset_clamp GL_KHR_context_flush_control
18:53:10 T:140544584116544 NOTICE: Running database version Addons20
18:53:10 T:140544584116544 NOTICE: Running database version ViewModes6
18:53:10 T:140544584116544 NOTICE: Running database version Textures13
18:53:10 T:140544584116544 NOTICE: Running database version MyMusic56
18:53:10 T:140544584116544 NOTICE: Running database version MyVideos99
18:53:10 T:140544584116544 NOTICE: Running database version TV29
18:53:10 T:140544584116544 NOTICE: Running database version Epg11
18:53:10 T:140544584116544 NOTICE: start dvd mediatype detection
18:53:10 T:140544584116544 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
18:53:10 T:140544584116544 NOTICE: ActiveAE DSP - starting
18:53:10 T:140544584116544 NOTICE: initialize done
18:53:10 T:140544584116544 NOTICE: Running the application...
18:53:10 T:140544584116544 NOTICE: starting upnp client
18:53:10 T:140543224944384 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
18:53:10 T:140543224944384 NOTICE: UDP: Listening on port 9777
18:53:29 T:140543266907904 NOTICE: PVRManager - starting up
18:53:29 T:140542528710400 ERROR: ADDON: Could not locate pvr.vdr.vnsi.so
18:53:29 T:140542528710400 WARNING: UpdateAndInitialiseClients - failed to create add-on VDR VNSI Client, status = 6
18:53:29 T:140542528710400 WARNING: UpdateAndInitialiseClients - failed to load the dll for add-on VDR VNSI Client, disabling it
18:55:43 T:140544584116544 NOTICE: Storing total System Uptime
18:55:43 T:140544584116544 NOTICE: Saving settings
18:55:43 T:140544584116544 NOTICE: stop all
18:55:43 T:140544584116544 NOTICE: stop player
18:55:43 T:140544584116544 NOTICE: PVRManager - stopping
18:55:43 T:140544584116544 NOTICE: ES: Stopping event server
18:55:43 T:140544584116544 NOTICE: stopping upnp
18:55:43 T:140543224944384 NOTICE: ES: UDP Event server stopped
18:55:43 T:140544584116544 NOTICE: stop dvd detect media
18:55:43 T:140544584116544 NOTICE: stop sap announcement listener
18:55:43 T:140544584116544 NOTICE: clean cached files!
18:55:43 T:140544584116544 NOTICE: unload skin
18:55:43 T:140544584116544 NOTICE: stopped
18:55:43 T:140544584116544 NOTICE: destroy
18:55:43 T:140544584116544 NOTICE: closing down remote control service
18:55:43 T:140544584116544 NOTICE: unload sections
18:55:43 T:140544584116544 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:55:44 T:140544584116544 NOTICE: destroy
18:55:44 T:140544584116544 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
18:55:44 T:140544584116544 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
18:55:44 T:140544584116544 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
18:55:44 T:140544584116544 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
18:55:44 T:140544584116544 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
18:55:44 T:140544584116544 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
18:55:44 T:140544584116544 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
18:55:44 T:140544584116544 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
18:55:44 T:140544584116544 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
18:55:44 T:140544584116544 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
18:55:44 T:140544584116544 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
18:55:44 T:140544584116544 NOTICE: closing down remote control service
18:55:44 T:140544584116544 NOTICE: unload sections
18:55:44 T:140544584116544 NOTICE: application stopped...
