Full Version: PTVL and Emby - EPG selects wrong episode
Hello,
I have a question for anyone who may be using PTVL and Emby in Windows.
When I select any episode other than the one currently playing in the EPG, PTVL always skips that episode and plays the next episode instead. Has anyone seen this and does anyone know of a fix?
Using PTVL 0.7.4g, Kodi 16.0 and Emby Version 3.0.5946.22772
Thanks,
Mark
I have seen this. Using the Emby for Kodi addon gives inaccurate playtimes to Kodi. Since PseudoTV requires accurate playtimes, it causes it to play the next item instead.
It's super annoying. If you set yourself up using Emby via UPNP, it should work, but using the Emby for Kodi addon will cause this to happen every time...
Thanks...I got the fix in the Emby forum. Seems I had to set up Native play and rescan my library. Works good now!
Glad to hear it. I may have to check that out myself!
