2016-04-18, 00:22
My youtube add-on now crashes instantly I select 'New Search.'
I have successfully implemented the changes posted by jdf76 on the keys for the Google project. I am running YouTube video plugin 5.1.20.6.
These chages to YouTube went without error. It hen decided to install the forum browser. During this installation it asked to install a extended kyboard and I said yes to this.
After this installation the youTube add on now crashes instantly the 'New Search ' is clicked.
I have uninstalled the forum browser and the YouTube add on still crashes.
It looks like it is crashing when accessing the keyboard template.
The build info is :-
18:40:40 67615.812500 T:1957118896 NOTICE: Starting Kodi (16.1-RC3). Platform: Linux ARM (Thumb) 32-bit
18:40:40 67615.812500 T:1957118896 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
18:40:40 67615.812500 T:1957118896 NOTICE: Kodi compiled Apr 3 2016 by GCC 4.9.2 for Linux ARM (Thumb) 32-bit version 3.16.7 (200711)
18:40:40 67615.812500 T:1957118896 NOTICE: Running on Open Source Media Center 2016.04-2, kernel: Linux ARM 32-bit version 4.4.6-3-osmc
18:40:40 67615.812500 T:1957118896 NOTICE: FFmpeg statically linked, version: 2.8.6-kodi-2.8.6-Jarvis-16.0
18:40:40 67615.812500 T:1957118896 NOTICE: Host CPU: ARMv7 Processor rev 5 (v7l), 4 cores available
18:40:40 67615.812500 T:1957118896 NOTICE: ARM Features: Neon disabled
18:40:40 67615.812500 T:1957118896 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
18:40:40 67615.812500 T:1957118896 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
18:40:40 67615.812500 T:1957118896 NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
18:40:40 67615.812500 T:1957118896 NOTICE: special://home/ is mapped to: /home/osmc/.kodi
18:40:40 67615.812500 T:1957118896 NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp
18:40:40 67615.812500 T:1957118896 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
18:40:40 67615.812500 T:1957118896 NOTICE: Local hostname: osmc
18:40:40 67615.812500 T:1957118896 NOTICE: Log File is located: /home/osmc/.kodi/temp/kodi.log
I have turned on de-bugging and this is the final lines in the log before reboot.
8:40:12 67587.742188 T:1730999280 DEBUG: [plugin.video.youtube] Path: "/kodion/search/list/
18:40:12 67587.742188 T:1730999280 DEBUG: [plugin.video.youtube] Params: "{}"
18:40:12 67587.773438 T:1730999280 DEBUG: POParser: loaded 100 strings from file /home/osmc/.kodi/addons/plugin.video.youtube-master/resources/language/English/strings.po
18:40:12 67587.796875 T:1701901296 DEBUG: WaitOnScriptResult- plugin returned successfully
18:40:12 67587.796875 T:1730999280 DEBUG: [plugin.video.youtube] Override view mode to "50"
18:40:12 67587.796875 T:1730999280 DEBUG: [plugin.video.youtube] Shutdown of Kodion
18:40:12 67587.796875 T:1730999280 INFO: CPythonInvoker(10, /home/osmc/.kodi/addons/plugin.video.youtube-master/default.py): script successfully run
18:40:12 67587.812500 T:1730999280 INFO: Python script stopped
18:40:12 67587.812500 T:1730999280 DEBUG: Thread LanguageInvoker 1730999280 terminating
18:40:12 67587.812500 T:1684009968 DEBUG: Thread BackgroundLoader start, auto delete: false
18:40:12 67587.843750 T:1684009968 DEBUG: Thread BackgroundLoader 1684009968 terminating
18:40:12 67587.960938 T:1956623280 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
18:40:15 67590.929688 T:1956623280 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
18:40:15 67590.929688 T:1956623280 DEBUG: OnKey: down (0xf081) pressed, action is Down
18:40:15 67590.937500 T:1623192560 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321 m_handle 0x74058b00
18:40:15 67590.945312 T:1623192560 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(2), nBufferSize(81920), nBufferAlignmen(16)
18:40:15 67590.953125 T:1623192560 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.egl_render input port 220 output port 221 m_handle 0x7404c658
18:40:15 67590.953125 T:1623192560 DEBUG: COMXCoreComponent::UseEGLImage component(OMX.broadcom.egl_render) - port(221), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(15360) nBufferAlignmen(16)
18:40:15 67590.968750 T:1623192560 DEBUG: COMXCoreComponent:einitialize : OMX.broadcom.image_decode handle 0x74058b00
18:40:15 67590.968750 T:1623192560 DEBUG: COMXCoreComponent:einitialize : OMX.broadcom.egl_render handle 0x7404c658
18:40:15 67590.968750 T:1623192560 DEBUG: DecodeJpegToTexture: decoded special://masterprofile/Thumbnails/f/f1837e1e.jpg 256x256
18:40:26 67602.070312 T:1956623280 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
18:40:26 67602.335938 T:1956623280 DEBUG: OnKey: return (0xf00d) pressed, action is Select
18:40:26 67602.335938 T:1956623280 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.youtube/kodion/search/input/)
18:40:26 67602.335938 T:1956623280 DEBUG: ParentPath = [plugin://plugin.video.youtube/kodion/search/list/]
18:40:26 67602.335938 T:1701901296 DEBUG: StartScript - calling plugin YouTube('plugin://plugin.video.youtube/kodion/search/input/','3','')
18:40:26 67602.335938 T:1684009968 DEBUG: Thread LanguageInvoker start, auto delete: false
18:40:26 67602.335938 T:1701901296 DEBUG: WaitOnScriptResult - waiting on the YouTube (id=11) plugin...
18:40:26 67602.335938 T:1684009968 INFO: initializing python engine.
18:40:26 67602.335938 T:1684009968 DEBUG: CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.youtube-master/default.py): start processing
18:40:26 67602.406250 T:1684009968 DEBUG: -->Python Interpreter Initialized<--
18:40:26 67602.406250 T:1684009968 DEBUG: CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.youtube-master/default.py): the source file to load is "/home/osmc/.kodi/addons/plugin.video.youtube-master/default.py"
18:40:26 67602.406250 T:1684009968 DEBUG: CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.youtube-master/default.py): setting the Python path to /home/osmc/.kodi/addons/plugin.video.youtube-master:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat:/usr/lib/python2.7/dist-packages/gtk-2.0
18:40:26 67602.406250 T:1684009968 DEBUG: CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.youtube-master/default.py): entering source directory /home/osmc/.kodi/addons/plugin.video.youtube-master
18:40:26 67602.406250 T:1684009968 DEBUG: CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.youtube-master/default.py): instantiating addon using automatically obtained id of "plugin.video.youtube" dependent on version 2.1.0 of the xbmc.python api
18:40:27 67602.835938 T:1956623280 DEBUG: ------ Window Init (DialogBusy.xml) ------
18:40:27 67603.390625 T:1684009968 DEBUG: [plugin.video.youtube] Starting Kodion framework by bromix...
18:40:27 67603.507812 T:1684009968 NOTICE: [plugin.video.youtube] Running: YouTube (5.1.18e) on Jarvis (16.1) with Python 2.7.9
18:40:27 67603.507812 T:1684009968 DEBUG: [plugin.video.youtube] Path: "/kodion/search/input/
18:40:27 67603.507812 T:1684009968 DEBUG: [plugin.video.youtube] Params: "{}"
18:40:27 67603.539062 T:1684009968 DEBUG: POParser: loaded 100 strings from file /home/osmc/.kodi/addons/plugin.video.youtube-master/resources/language/English/strings.po
18:40:28 67603.570312 T:1956623280 INFO: Loading skin file: DialogKeyboard.xml, load type: KEEP_IN_MEMORY
18:40:28 67603.671875 T:1956623280 DEBUG: ------ Window Init (DialogKeyboard.xml) ------
Can anyone help me solve this problem ?
Very best regards
In hope......
Graxam.
Very best regards
In hope......
Graxam.
