Full Version: The service is not connected
I have just installed Xlink. The first time I tried it it worked fine, and I could connect to a game of Halo2.
The next time I came to try it, I received the above error.
I have searched through the forums for this problem, but none of the solutions seem to help. I am on a wired network, and I have rebooted the PC and Xbox and tried again.
The settings on the Xbox are correct, ie username and password etc, and the PC is showing "Engine running".
I've even tried disabling my firewall.
Can anyone help?
I switched to DHCP, then back to static. It's fine now!
Does it still work correctly after a power cycle or is that a repetative resolution that has to be done each time?
No it still works fine.
