Full Version: Intel Apollo Lake
Also crucial 1866. Not sure if it is perfectly stable too. But it is listed on the ram List from asrock. It was Prime stable for several hours in win10. Since my Htpc gets heated by my AVR below, i have One 120mm Ventilator hanging above the cpu cooler and so the temps are way lower. Level 1, Target temp 50°, it never Turns loud while whatching movies, you never hear it
Gesendet von meinem ONEPLUS A3003 mit Tapatalk
And when I say hanging, I mean hanging :-) temps way lower on 100% load
Top of the case is Open, you dont See it, you dont hear it
(2016-11-11, 09:23)flyingernst Wrote: [ -> ]https://youtu.be/_KOgVdbIKLw proof of hd Audio on Win 10 mvc build
https://youtu.be/J-SyBM8aqUQ proof of Hardware based mvc Playback from mkv and iso.
On my Beamer I Can Show the Informationen "framepacking", my tv Just Shows 3D but it only switches automaticly to 3d when framepacking Signals are coming. SBS-3D you need to activate manually on my tv.
3d Works in KODi and Driver Base settings, There is No need to Set anything. Hd Audio you need to activate. No need to Set anything in the drivers, only in KODi
Setting Intel Driver - https://www.youtube.com/watch?v=SpOSuXDHdkM
Play in Kodi - https://www.youtube.com/watch?v=SWr1ZC94cFo
(2016-11-13, 14:14)flyingernst Wrote: [ -> ]Also crucial 1866. Not sure if it is perfectly stable too. But it is listed on the ram List from asrock. It was Prime stable for several hours in win10. Since my Htpc gets heated by my AVR below, i have One 120mm Ventilator hanging above the cpu cooler and so the temps are way lower. Level 1, Target temp 50°, it never Turns loud while whatching movies, you never hear it
Thank you very much for your help! So, I suppose your memory sticks are the Crucial CT51264BF186DJ listed? This motherboard is very sensitive because for example, the 1600Mhz version of your sticks, CT51264BF160BJ, are not compatible in dual channel as stated by Stephan in this german review of the J4205-itx.
Mine is mounted in an Apple G4 Cube case, with a modified SFX power supply (put a 92mm bequiet fan instead of the 80mm loud one), it's near silent!
CT51264BF186DJ yes, german Amazon. It is the only ddr1866 with 4gb available if I remember correctly. Have it in dual channel Mode. When I disconnect it from energy and boot it the First time it reboots twice to BIOS Screen before booting into the OS. After that Moment it always Works normal and stable. But that started my doubts.
Yes, my setup does the same when I unplug the power supply. I've just ordered 2x4G of those CT51264BF186DJ, thanks to your feedback, hope it will work flawlessly like yours Smile
I Hope or think There will come a BIOS Update so that this behavior will Change. Well since I usually dont unplug it, it is not a Problem for me, because as Said After that First moment: Every Reboot or wakeup Works normally.
I hope so too, because my entire htpc setup is unplugged when not in use.
I finally setup my new HTPC with the GTX 1050 and silverstone ML08B case. Because of lack of driver support on Linux I ended up using Windows 10 for now and Kodi 17. I plan to go back to a linux distro when a stable driver is released. But I have test 4k HVEC content and it plays smooth. I can output full 4k 60Hz 10-bit 4:2:2 and 8-bit 4:4:4 without issues. I setup the system with HDMI 2.0 connected directly to the TV and the displayport connection to my Pioneer AVR. I did find there is no way to disable the video to displayport since I am only using audio to my Pioneer AVR, but this does not effect the performance in Kod.
Also I found the 1050 to run very cool and silent even though there was not much breathing room in my TV cabinet.
@raidflex this thread is about Intel Kaby Lake. Not GTX 1050 Smile
I know that I posted in this thread before I was just giving an update with my findings.
(2016-11-14, 21:21)sunnyfunny Wrote: [ -> ]@raidflex this thread is about Intel Kaby Lake. Not GTX 1050 Smile
No, this thread is about Intel Apollo LakeSmile
(2016-11-14, 21:47)movie78 Wrote: [ -> ]
Hah this true.
ASRock J4205-ITX All the same I can't force to work 3D framepacking in any way. Help.
TV LG 49UB850V - passive 3D polarizable
Why all the same?!
With https://drive.google.com/open?id=0BwxFVk...UpsSXdWLWM this Release on Win10 MVC MKV and 3D ISO works perfectly without any effort. NOT with the normal beta.
(2016-11-15, 11:35)flyingernst Wrote: [ -> ]Why all the same?!
I can't achieve normal 3D. You use a HDMI? What technology at you of TV, the active or passive?
