Full Version: Intel Apollo Lake
thanks a lot!
(2017-11-24, 13:23)chrisk2305 Wrote: [ -> ]thanks a lot!
 MECOOL M8S PRO L YouTube 4K Streaming 3GB/32GB Android 7.1 Amlogic S912 KODI 17.3 TV BOXI buyed this from a Geek for 50€ from german stock, few hours ago. I think that is a good offer.
from a Geek? Where exactly did you buy it for that price? Smile thx
Edit: Ah got it: https://www.geekbuying.com/item/MECOOL-M...86124.html
But this seems to be 100Mbit Lan though
It is not allowed to make that links I think, thats why I made only a hint.
100mbit is enough for streaming from homeserver. No 4K Bluray I know has more than 100mbit, mostly 50-70mbit maximum I think.
Streaming 4k UHD over wireless AC about 30cm to my shield tv resulted in stuttering. Until i wen gig ethernet it had problems.
Be warned.
i would use lan, not wlan. that means real 100mbit in that case. still faster then bad 5ghz connections. I dont worry
alright, so would would be the other options for 1gbe lan then. Different sites state different speeds for the same product.
Would someone please test my uploaded file with any device or at least Apollo lake?!
Gesendet von meinem ONEPLUS A3003 mit Tapatalk
@fritsch
Because you gave me a good advice on my last board (ASRock N3150-itx), I just wanted to ask, if you would (still) recommend an ASRock J3455-itx, if I want to do an upgrade?
My TV can play 4K @ 60HZ now, so I ordered a J3455-itx to replace my old board.
Are there any known bugs using Libreelec Milhouse with this board (except HDR not working under Linux)?
I'm asking because I had some trouble setting up the board.
Deinterlacing settings weren't saved for all media, which makes playback unusable.
Curious thing about this - when I delete my advancedsettings.xml, the settings get saved.
Only part in my advancedsettings.xml is the mysql section, so that should not be a problem (actually).
So if you say, the board is not worth a try anymore, I would send it back and get another one instead (or later).
Any idea?
Could someone with Apollo Lake play that entire sample here:
http://youplala.net/~nico/kodi18-4khevc1...-HD.MA.mkv
Does it work without artefacts?
(2017-12-07, 20:30)sw4y Wrote: [ -> ]@fritsch
 I would wait for Gemini Lake in Q1 2018. My own Apollo Lake will replace J1900 in my 24/7 Server as soon as possible, because I am disappointed very much from LSPCON, Aspect Ratio and HD Audio Bugs. Actually I wonder why no-one complains about the aspect ratio bug since LSPCON 1.66 on Apollo Lake Mainboards.
(2017-12-12, 12:34)flyingernst Wrote: [ -> ]
+1 to that. Though HD Audio is fully working for me: X1300W + drm-intel-nightly since some months. I use LSPCON 1.72 which made different issues for others.
(2017-12-12, 10:50)fritsch Wrote: [ -> ]Could someone with Apollo Lake play that entire sample here:
 J4205-ITX - AVR Denon X6200W - Sharp LC-60UQ10 work fine, without artifacts. Build Generic.
