(2016-12-26, 23:49)fritsch Wrote: [ -> ]After fiddeling with my TV's UHD settings - for me 4k@60 and 4k@50 works without any additional changes. So not sure what we fix here :-)
Out of the Box with LibreElec?
Get this not working with my config
Pioener VSX-930 with Sony KD-65X7505 UHD TV. Only 30Hz at 4K.
EDIT: Note for myself.... RTFM
Found some infos in the manual. Will test it tonight.
I have a denon avr-3300x and LG Oled B6 and not get 4k@50 hz if not add manually the modeline
On my Samsung I enabled uhd for hdmi1, rebooted and had 4k@60 and 50,24,23,30,59.94. A Denon AVR is in between. I used Standard HDMI 2.0 capable cables, cheap ones from Amazon Basic.
Sidenote:without setting the tv up correctly it did not even accept 4k 50, 60 manual set xrandr modes.
I can provide my edid to overwrite yours if needed.
I have LG oled B6 with UHD enabled in HDMI2 and the denon 3300x between, my cable is from amazon too
https://www.amazon.es/gp/product/B004BEM...UTF8&psc=1 get 4k@60hz withouts problems.
If you send me your edid i can try load in boot with your manual and send my xrandr modes
PD: I really happy you adquired one J4205! The case mtech is beatifull, i have one origenae s10v and only replace the motherboard and hdmi cables, If I did not have the originae would buy the mtech
Here the howto:
http://forum.kodi.tv/showthread.php?tid=...pid2479154
Here the edid:
https://dl.dropboxusercontent.com/u/5572...non-4k.bin (256 Byte in size)
If you follow the howto correctly (and use Ubuntu), you should end up with that in /etc/default/grub:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash video=DP-1:1920x1080@50D drm_kms_helper.edid_firmware=DP-1:edid/edid.bin
And the kernel should tell something like that:
Quote:[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-fritsch1+ root=UUID=8d88c5de-5de8-42a3-8ab2-b8302262e45e ro quiet splash video=DP-1:1920x1080@50D drm_kms_helper.edid_firmware=DP-1:edid/edid.bin vt.handoff=7
[ 3.213031] [drm] Got external EDID base block and 1 extension from "edid/edid.bin" for connector "DP-1"
[ 3.900449] [drm] Got external EDID base block and 1 extension from "edid/edid.bin" for connector "DP-1"
[ 15.260562] [drm] Got external EDID base block and 1 extension from "edid/edid.bin" for connector "DP-1"
[ 15.301152] [drm] Got external EDID base block and 1 extension from "edid/edid.bin" for connector "DP-1"
[ 15.962820] [drm] Got external EDID base block and 1 extension from "edid/edid.bin" for connector "DP-1"
[ 16.807223] [drm] Got external EDID base block and 1 extension from "edid/edid.bin" for connector "DP-1"
[ 17.167520] [drm] Got external EDID base block and 1 extension from "edid/edid.bin" for connector "DP-1"
[ 18.109722] [drm] Got external EDID base block and 1 extension from "edid/edid.bin" for connector "DP-1"
If you use LibreELEC, you can find the howto in the linked thread.
Edit: I run the TV in 1920x1080@50 as I mainly watch LiveTV 1080i50 and let that upscale by the TV. For (rare) 4k@
Whatever content kodi automatically switches up.
The issues with 2160p50 and 2160p59.94 couldn't be related to 4:2:0 vs 4:2:2 / 4:4:4 compatibility could they? I know some displays only accept 4:2:0 at this resolution and frame rate, as they are still using the lower bandwith HDMI 1.4 physical hardware which can just about handle 4:2:0 at 2160p50 and 59.94, rather than the higher bandwith (optional) modes which add support for 4:2:2 and 4:4:4 at these frame rates.
AIUI this is one major reason that a 4:2:0 mode was added to the HDMI 2.0 spec, and meeting it is enough to be considered HDMI 2.0. (And given that pretty much all consumer video is, and will remain, 4:2:0, the only major issues is for UIs and Photo-type display applications, until you need 12 bit for HDR. Not sure if 10 bit is supported or not)
I have to add something, the 50p mode is missing for me ... while the 60 is there. I created an xorg.conf that adds it on top. Until I like to alter my edid.
(2016-12-27, 16:06)fritsch Wrote: [ -> ]I have to add something, the 50p mode is missing for me ... while the 60 is there. I created an xorg.conf that adds it on top. Until I like to alter my edid.
So you cant get 50p neither with your edid?
Enviado desde mi iPhone utilizando Tapatalk
Jep, see:
Quote:DP-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 1872mm x 1053mm
3840x2160 60.00 + 30.00 25.00 24.00 29.97 23.98
4096x2160 24.00 23.98
1920x1080 60.00 50.00 59.94* 30.00 25.00 24.00 29.97 23.98
1920x1080i 60.00 50.00 59.94
1680x1050 59.88
2880x576 50.00
1600x900 60.00
2880x480 60.00 59.94
1280x1024 75.02 60.02
1440x900 59.90
1280x800 59.91
1152x864 75.00
1280x720 60.00 50.00 59.94
1440x576 50.00
1024x768 75.03 70.07 60.00
1440x480 60.00 59.94
832x624 74.55
800x600 72.19 75.00 60.32
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
3840x2160_50.00 50.0
It seems besides the 60p - the EDID contains nothing ... I looked in the 1080p line when I thought all is there.
(2016-12-25, 01:49)feathers Wrote: [ -> ]Does 4K Netflix work on Apollo lake under Windows 10 / Edge browser ?
It works at 4k in the app, it doesn't work in the edge browser. Also, there was some choppyness during playback even though the CPU was only at 25% or so. Not sure what caused it, i only tested for a few seconds.
(2016-12-27, 20:55)753951 Wrote: [ -> ] (2016-12-27, 20:24)gwilly7 Wrote: [ -> ]The case you linked to is fantastic, I was looking for something similar available in the U.S. but am only able to find a "Thin" mini itx from silverstone and I do not think the board will fit.
https://www.amazon.com/MS-Tech-CI-70-120...B00E5YSDC4
Thanks, not sure how I missed that. Searched pretty good I thought. Quite a bit pricier though.
I do have the same issue with 2160p50 with a Panasonic cxw and an Asrock J4205, only 60hz are available but I need 50hz for UHD TV.
xrandr -q -d :0
Screen 0: minimum 8 x 8, current 3840 x 2160, maximum 32767 x 32767
DP1 disconnected (normal left inverted right x axis y axis)
DP2 connected primary 3840x2160+0+0 (normal left inverted right x axis y axis) 1280mm x 720mm
3840x2160 60.00*+ 30.00 25.00 24.00 29.97 23.98
2560x1440 59.95
1920x1080 60.00 50.00 59.94 30.00 25.00 24.00 29.97 23.98
1366x768 59.79
1024x768 60.00
720x576 50.00
720x480 60.00 59.94
640x480 60.00 59.94
HDMI1 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
CU
9000h
