2016-12-29, 09:24
with the edid-decode from git, the old one in ubuntu did not get all the details correct
VIC 96 3840x2160@50Hz
so the TV is able to accept 3840x2160@50Hz but it's probably a issue with YCbCr 4:2:2 or YCbCr 4:4:4
any ideas?
CU
90000h
xrandr -d :0 --props | ./edid-decode
Extracted contents:
header: 00 ff ff ff ff ff ff 00
serial number: 34 a9 96 a2 01 01 01 01 00 19
version: 01 03
basic params: 80 80 48 78 0a
chroma info: da ff a3 58 4a a2 29 17 49 4b
established: 20 08 00
standard: 31 40 61 40 01 01 01 01 01 01 01 01 01 01 01 01
descriptor 1: 08 e8 00 30 f2 70 5a 80 b0 58 8a 00 ba 88 21 00 00 1e
descriptor 2: 02 3a 80 18 71 38 2d 40 58 2c 45 00 ba 88 21 00 00 1e
descriptor 3: 00 00 00 fc 00 50 61 6e 61 73 6f 6e 69 63 2d 54 56 0a
descriptor 4: 00 00 00 fd 00 17 3d 0f 88 3c 00 0a 20 20 20 20 20 20
extensions: 01
checksum: 21
Manufacturer: MEI Model a296 Serial Number 1684XXXX
Made week 0 of 2015
EDID version: 1.3
Digital display
Maximum image size: 128 cm x 72 cm
Gamma: 2.20
Supported color formats: RGB 4:4:4, YCrCb 4:4:4
First detailed timing is preferred timing
Established timings supported:
640x480@60Hz
1024x768@60Hz
Standard timings supported:
640x480@60Hz
1024x768@60Hz
Detailed mode: Clock 594.000 MHz, 698 mm x 392 mm
3840 4016 4104 4400 hborder 0
2160 2168 2178 2250 vborder 0
+hsync +vsync
Detailed mode: Clock 148.500 MHz, 698 mm x 392 mm
1920 2008 2052 2200 hborder 0
1080 1084 1089 1125 vborder 0
+hsync +vsync
Monitor name: Panasonic-TV
Monitor ranges (GTF): 23-61Hz V, 15-136kHz H, max dotclock 600MHz
Has 1 extension blocks
Checksum: 0x21 (valid)
CEA extension block
Extension version: 3
73 bytes of CEA data
Video data block
VIC 16 1920x1080@60Hz
VIC 31 1920x1080@50Hz
VIC 5 1920x1080i@60Hz
VIC 20 1920x1080i@50Hz
VIC 32 1920x1080@24Hz
VIC 33 1920x1080@25Hz
VIC 34 1920x1080@30Hz
VIC 4 1280x720@60Hz
VIC 19 1280x720@50Hz
VIC 3 720x480@60Hz
VIC 18 720x576@50Hz
VIC 7 1440x480i@60Hz
VIC 22 1440x576i@50Hz
VIC 93 3840x2160@24Hz
VIC 94 3840x2160@25Hz
VIC 95 3840x2160@30Hz
VIC 98 4096x2160@24Hz
VIC 99 4096x2160@25Hz
VIC 100 4096x2160@30Hz
VIC 97 3840x2160@60Hz
VIC 102 4096x2160@60Hz
VIC 101 4096x2160@50Hz
Audio data block
Linear PCM, max channels 2
Supported sample rates (kHz): 48 44.1 32
Supported sample sizes (bits): 16
Vendor-specific data block, OUI 000c03 (HDMI)
Source physical address 3.0.0.0
DC_36bit
DC_30bit
DC_Y444
Maximum TMDS clock: 300MHz
Extended HDMI video details:
3D present
3D-capable-VIC mask present
Base EDID image size is aspect ratio
HDMI VIC 0 3840x2160@30Hz
HDMI VIC 1 3840x2160@25Hz
HDMI VIC 2 3840x2160@24Hz
HDMI VIC 3 4096x2160@24Hz
3D: Side-by-side (half, quincunx)
3D: Side-by-side (half, horizontal)
3D: Top-and-bottom
3D: Frame-packing
3D VIC indices: 2 3 4 7 8
VIC index 0 supports top-and-bottom
VIC index 1 supports top-and-bottom
VIC index 0 supports unknown
VIC index 1 supports unknown
Vendor-specific data block, OUI c45dd8
Extended tag: video capability data block
YCbCr quantization: No Data (0)
RGB quantization: Selectable (via AVI Q) (1)
PT scan behaviour: No Data (0)
IT scan behaviour: Always Underscanned (2)
CE scan behaviour: Support both over- and underscan (3)
Extended tag: Colorimetry data block
xvYCC601
xvYCC709
sYCC601
AdobeYCC601
AdobeRGB
Extended tag: YCbCr 4:2:0 capability map data block
Underscans PC formats by default
Basic audio support
Supports YCbCr 4:4:4
Supports YCbCr 4:2:2
0 native detailed modes
Detailed mode: Clock 241.500 MHz, 698 mm x 392 mm
2560 2608 2640 2720 hborder 0
1440 1443 1448 1481 vborder 0
+hsync -vsync
Detailed mode: Clock 85.500 MHz, 698 mm x 392 mm
1366 1436 1579 1792 hborder 0
768 771 774 798 vborder 0
+hsync +vsync
Checksum: 0x65 (valid)
any ideas?
CU
90000h
