Full Version: Intel Apollo Lake
I think you mean TMDS is the pixelclock? It's not
# 3840x2160 @ 60.00 Hz (GTF) hsync: 134.10 kHz; pclk: 712.34 MHz
Modeline "3840x2160_60.00" 712.34 3840 4152 4576 5312 2160 2161 2164 2235 -HSync +Vsync
(2016-12-29, 20:19)wesk05 Wrote: [ -> ]I see this in @9000h's post : HDMI max TMDS frequency 300000KHz
I am not sure how 2160p60 can even work if the TMDS pixel clock is limited to 300MHz.
If the figure is the HDMI clock then HDMI 2.0 introduced the concept of a 1/4 clock frequency.
http://www.cedia.co.uk/cda_/images/Resou...er_ENG.pdf Table 2.1 suggests that 2160p59.94 4:2:2 and 10-12 bit 4:2:0 runs at 148.5Mhz TMDS clock, with 594Mcharacters/sec, as HDMI 2.0 introduces the 1/4 character rate TDMS clock?
i.e. the pixel clock is 4x the TMDS clock when you switch to the new HDMI 2.0 rates?
Quote:Where the TMDS character rate is equal
to or less than 340Mcsc, the Clock will run at the same speed as the character rate (1:1). Where the character rate exceeds 340Mcsc, HDMI 2.0 mode will be enabled (in supporting devices) and the Clock will be slowed to just 1⁄4 the character rate;
E.g.; 297Mcsc TMDS = 297MHz Clock 594Mcsc TMDS = 148.5MHz Clock
Yeah :-) - so all fine?
Blah Oo I goofed up. I got it confused with the TMDS character rate, because that is what is actually defined in HDMI 2.0 spec and is reported in HDMI Forum Vendor Specific Data Block (HF-VSDB)
Oh! I didn't even notice that I typed "TMDS pixel clock". I guess it is time for lunch!
Quote:The Sink Device shall indicate the maximum TMDS Character Rate that it supports in the Max_TMDS_Character_Rate field in the HF-VSDB (Section 10.3.2) if it supports TMDS Character Rate above 340Mcsc and upto 600 Mcsc. The Source shall not transmit at TMDS Character Rates higher than the maximum rate supported by the Sink, as indicated by the Max_TMDS_Character_Rate field of the HF-VSDB
(2016-12-29, 20:29)fritsch Wrote: [ -> ]I think you mean TMDS is the pixelclock? It's not
This is with HDMI or DP?
there is still some development ongoing for lspcon in drm-intel patchwork.
CU
9000h
Handle with care:
Section "Device"
Identifier "Device0"
Driver "intel"
VendorName "INTEL Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "DP1"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes "[email protected]" "[email protected]" "[email protected]" "[email protected]" "[email protected]" "[email protected]" "[email protected]"
EndSubSection
EndSection
Section "Monitor"
Identifier "DP1"
HorizSync 14.0 - 150.0
VertRefresh 24.0 - 62.0
Option "PreferredMode" "[email protected]"
Modeline "[email protected]" 74.176 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync
Modeline "[email protected]" 74.250 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync
Modeline "[email protected]" 148.500 1920 2448 2492 2640 1080 1084 1094 1125 +hsync +vsync
Modeline "[email protected]" 148.352 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Modeline "[email protected]" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Modeline "[email protected]" 586.61 3840 4136 4560 5280 2160 2161 2164 2222 -hsync +vsync
Modeline "[email protected]" 712.34 3840 4152 4576 5312 2160 2161 2164 2235 -hsync +vsync
EndSection
Use at your own risk. LE: /storage/.config/xorg.conf Normal Linux Distro: /etc/X11/xorg.conf - you obviously need the DP (HDMI 2.0) being the connected one.
my issue is that 2160p60 is working fine but 2160p50 gives only a black screen on my Panasonic DXW, so is there anyone out there with a similar setup?
Panasonic DXW
Asrock J4205
Ubuntu 16.04.1 LTS
intel-drm-nigthly kernel 4.10.0-994-lowlatency
libva info: VA-API version 0.39.4
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/i386-linux-gnu/dri/i965_drv_video.so
libva info: Found init function __vaDriverInit_0_39
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.39 (libva 1.7.4.pre1)
vainfo: Driver version: Intel i965 driver for Intel® Broxton - 1.7.4.pre1 (1.7.4.pre1)
vainfo: Supported profile and entrypoints
I try to find someone who is able to use 2160p50, all reports I'm able to find have 2160p60 but I need 50Hz.
CU
9000h
I am able to use 2160p50 - I added the modeline manually and it works.
(2016-12-30, 20:44)9000h Wrote: [ -> ]Hi,
May be your TV doesn't "like" the GTF timing in the modline. Try a CEA or CVT-RB timing and see whether it works.
Can you post those @wesk05?
I can do that later today. I don't have access to a timing calculator now.
Here we go:
CEA 861-F
Modeline "[email protected]" 594.00 3840 4896 4984 5280 2160 2168 2178 2250 +hsync +vsync
Modeline "[email protected]" 594.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync
CVT- Reduced Blanking
Modeline "[email protected]" 442.200 3840 3888 3920 4000 2160 2163 2168 2211 +hsync -vsync
Modeline "[email protected]" 533.280 3840 3888 3920 4000 2160 2163 2168 2222 +hsync -vsync
CVT
Modeline "[email protected]" 587.400 3840 4144 4560 5280 2160 2163 2168 2225 -hsync +vsync
Modeline "[email protected]" 712.976 3840 4152 4576 5312 2160 2163 2168 2237 -hsync +vsync
@9000h: try the CEA timing first since your TV declares support for VIC 97 (2160p50).
you made my day wesk05
works fine with my Sony KD-65XD7505
but how can get 59.94fps UHD Videos playing at [email protected] They playhing here at [email protected]
You won't without adding a 59.94 modeline. I implemented it that way: check 100% matching refreshrate. If that one is found, find a better resolution with the same or better matching refreshrate.
Thanks very much @wesk05! I will update the default config line.
Can you post another one for 59.94?
