Full Version: Intel Apollo Lake
(2017-01-10, 14:55)Sniffer77 Wrote: [ -> ]Hi all. Are the NUC versions of apollo lake available yet ? If not isctgerr a release date?
I'm not too in the know with computers , I'm just but looking to upgrade me dn2820
Cheers
You will find some here http://www.cnx-software.com/tag/apollo-lake/
If you are looking for Intel than search for NUC6CAYS & NUC6CAYH , there are some store listings with this one promising delivery from stock https://www.amazon.com/Intel-BOXNUC6CAYS...s=NUC6CAYS
Cheers
They are late, but I have seen at least one retailer say January 16. I am also eagerly awaiting this.
There was a post earlier on this thread saying someone had tested one of @piotrasd's builds on the Apollo Lake NUC, so maybe he had early access?
This was the post I was referring to:
(2016-12-19, 23:42)trsqr Wrote: [ -> ]Confirmed 10-bit HEVC works fine on a NUC6CAYH with the LE build from Piotrasd (devel-20161217173209-r24948-gb7cc543). Same HD audio bitstreaming issues are present.
Nice find on the NUC6CAYS on Amazon @Dr. Feelgood; wonder how real that is. I'm waiting for NUC6CAYH
Thank s for the replies.
Wonder what uk prices will be .
I will purely be running libreelec on mine .
Probably look at the h version so I can have add and HDD
any way I can contribute to the HD audio issue? Seems there is not much going on in the bug report. I am not a programmer but i can provide logs, etc. if needed.
Nope.
k, so @fritsch do you know if there is something going on behind the scenes?
(2017-01-10, 16:14)kekomat Wrote: [ -> ]Sorry, I put two different thoughts from opposing points of view in the same line:
A
Maybe raidflex is right and I might run into issues while importing LE settings and such from my curernt ION1 installation into the fresh AL installation. In this case I should just do a library backup/import, correct?
B
Or would my LE installation maybe behave like a windows PC that is booted in safe mode after HW changes so that it can adapt and load the correct drivers and stuff? In this case I could just swap the SSD from my ION1 box into my AL box, correct?
But given your advice I assume A is not necessary and B not possible without running into issues (just like htpcero pointed out).
LE doesn't store any hardware specific settings by default that would prevent booting, so backing up your existing client and then importing this backup into a fresh LE installation will work, as would moving the HDD directly from your old machine into the Apollo Lake machine (assuming there are no BIOS/UEFI issues). So A and B should work. I would probably favour A, as this will give you a fresh installation (increased FAT partition, UEFI support).
Hey guys,
I am following your thread since a few weeks now and I'm getting close to ordering an ASRock J3455-ITX to build a budget Kodi Player. The machine is also supposed to manage some other tasks but [email protected] HEVC playback and 10bit content is the most important part.
The other day somebody said that especially the onboard graphics benefits from dual channel. Do I need two 4GB RAM modules to be able to use dual channel or will a single 4 GB RAM module be enough for a smooth playback?
(2017-01-11, 12:08)jaysn8 Wrote: [ -> ]Hey guys,
According to this http://www.technikaffe.de/anleitung-396-...or_im_test the dual DDR "improves graphic performance significantly".
Not sure if 4K will suffer from single channel but for what is worth the single 4GB DDR is around ~20EUR ...
10bit HEVC works fine for me with only 4gb of ram on the same board. Not sure if that will change or not, still very early days.
Hi
Guys, latest build here
https://www.sendspace.com/file/s5a5ua
changes:
all patches for HEVC10 updated (kodi, mesa, kernel)
bumped to latest kodi, mesa, x86-video-intel, libva-vaapi, linux-drm-nighlty
based on latest LE 8
(2017-01-11, 18:39)piotrasd Wrote: [ -> ]Hi
changes:
Thanks will try when I get home from work.
(2017-01-12, 01:26)chrisk2305 Wrote: [ -> ]New Bios for J4205-ITX:
http://www.asrock.com/mb/Intel/J4205-ITX...ad&os=BIOS
Thx!
I hate whey they release something without release notes/change list. Or did I miss it?
Edit: just noticed there's beta bios which talks about some setting for HDMI...
http://www.asrock.com/mb/Intel/J4205-ITX/?cat=Beta
"Modify vBIOS setting for HDMI display"
