Full Version: Intel Apollo Lake
Well There is a nightly with Apollo Lake Support
But for that i First have to install a normal Version...and this doesnt gets Starter...Made my Stick with the USB Tool from libreelec Homepage
(2016-10-26, 21:05)flyingernst Wrote: [ -> ]4k hevc 10 bit runs in Win 10 with the Release from this threat.
Gesendet von meinem ONEPLUS A3003 mit Tapatalk
11-13 Watts playing Hevc. Deactivated some unused Controllers in BIOS.
Thanks for testing the Windows MVC Build..
WoofWink
(2016-10-26, 21:39)flyingernst Wrote: [ -> ]Well There is a nightly with Apollo Lake Support
did you try to disable some options in bios like fastboot and IntelRMT ...
for me instalation works on default bios settings, but on LE nothing to testing Sad
did you try this : http://forum.kodi.tv/showthread.php?tid=...pid2444080
Build Highlights:
Kodi 17 Beta5 development opens
libcec 3.2.0
Chris Wilson patch added to LE master
Add some Apollo Lake and Kaby Lake support
Drop FernetMenta repo from current and future builds
Whatever I Change in BIOS, it ends hereImage
try enable Legacy for USB in bios Wink, or other USB stick
No Chance, whatever I Change, nothing gets better. BIOS, Stick, whatever
Worked with installing on j1900, Update to latest Version and Plug HDD Back to j4205
But it is realy Buggy. It Starts, but isnt usable. No hd Audio (Stream), No dlna, smb or Just sometimes...Video Codecs fine, only hevc10bit uses Software decoding.
When I make an "Update" to Alpha 7 then it is Not booting again. Looks like i have to use Windows the next view Days. Thanks for your Support anyway.
After some test on windows 10
(there is no driver for lower windows like 8.1 etc Sad, only for 10 and still not avaiable on intel webstie)
Benchmark Geekbench
https://browser.geekbench.com/v4/compute/181328
https://browser.geekbench.com/v4/cpu/864581
Screens from LiveTV test (included HDR test channel)
http://imgur.com/a/C270m
99% of samples from here http://kodi.wiki/view/Samples#4K_.28UltraHD.29 - Works
tested so far and OK :
H.264 29.970fps, 51Mbps (in MOV, hdmkv's iPhone 6S raw 4K footage)
HEVC 10-bit 59.940fps (in TS)
HEVC 10-bit 59.940fps (Korean ATSC 3.0 satellite TV capture sample)
HDR 10-bit HEVC 24.000fps (in MP4, 'Exodus' and 'Life of Pi' samples)
HDR 10-bit HEVC 25.000fps (in TS, Astra DVB satellite capture sample; no audio) (thanks wrxtasy, courtesy WeTek)
HDR 10-bit HEVC 59.940fps (in MP4, Camp by Sony)
DolbyVision 10-bit HEVC 23.976fps (in TS, LG Comparison Demo) (thanks soyhakan)
DolbyVision 10-bit HEVC 23.976fps (in TS, LG Trailer) (thanks soyhakan)
VP9 (open-source alternative to HEVC) (YouTube) - perfect
5K (5120x2700) 60.000fps (in MP4) (YouTube) - 5k pixels (almost no picture) - 4k perfect
8K (7680x4320) 29.970fps (in MP4) (YouTube) --> 8K pixels (almost no picture) --> 4k perfect
(2016-10-27, 04:02)piotrasd Wrote: [ -> ]tested so far and OK :
What do you mean by "OK" for these HDR clips? Is the playback actually with HDR?
Same question I was going to ask...
And are these clips actually being displayed on a 4K HDR compatible display ?
As an example - All those clips wesk05 just mentioned also play "OK" on a $40 AML S905 Wink
yes sorry Smile i never before tested HDR so i just supposed normal is black screen, and i dont have TV with HDR support. (yet)
What is strange only for me there is some bug for bigger resultion than 4k
On cherry trail z8300 Gen8 gpu, i had samples 4k (3D) that was 8k picture ... and was eveything fine (h264)
here this same sample only pixels
(2016-10-26, 22:05)movie78 Wrote: [ -> ]Thanks for testing the Windows MVC Build..
WoofWink
MVC (framepacking) is working too, I forgot to post that fact. I ripped MVC Blurays with makemkv, all of them and the Blurayimages themselve work perfect.
Today will be my first 3D Kodi Cinema-Evening jippie :-)
(2016-10-28, 14:33)flyingernst Wrote: [ -> ]
WoofWink
Thank you for taking time doing this testCool
