Full Version: Intel Apollo Lake
latest builds
http://piotrasd.libreelec.tv
LE8-HEVC10 - based on LE 8.0.1 with Kodi 17.2rc + HEVC support
LE9-KODI_AGILE - based on LE 9 with Kodi-agile fork with inputstream.adaptive for Netflix -
piotrasd, thx for your work Smile
(2017-04-13, 05:16)piotrasd Wrote: [ -> ]latest builds
LE8-HEVC10 - based on LE 8.0.2 with Kodi 17.2rc + HEVC support
Thanks piotrasd , i can confirm that netflix is working with your build
i know in that version was added subtitle support in Netflix
guide for others
1. download on LE and execute from ssh http://nmacleod.com/public/libreelec/getwidevine.sh
2. default inputstream.adaptive after fresh install is disabled, you need to enable from My Addons
3. Install netflix addon from here https://github.com/asciidisco/plugin.video.netflix az zip
anyone with apollo lake updated to Windows Creators update and newest intel drivers to try HDR?
HDR not working under Windows.
(2017-04-13, 17:38)sunnyfunny Wrote: [ -> ]HDR not working under Windows.
HDR is working with Windows 10 creators update and PDVD17
(2017-04-13, 17:50)movie78 Wrote: [ -> ]
You got it working on your Apollo lake box?
Sent from my Nexus 6P
(2017-04-13, 18:25)Nekromantik Wrote: [ -> ]
Sent from my Nexus 6P (typie typie)
On a Kaby Lake box...
(2017-04-13, 18:27)movie78 Wrote: [ -> ]
(2017-04-13, 17:50)movie78 Wrote: [ -> ]HDR is working with Windows 10 creators update and PDVD17
Relevant!
Yes I wanted to know about apollo lake thats why I put it in this Apollo lake thread.
(2017-04-13, 19:55)Nekromantik Wrote: [ -> ]
(2017-04-13, 18:25)Nekromantik Wrote: [ -> ]You got it working on your Apollo lake box?
I bet he thought he was in the other thread. I can probably test tonight if i don't drink too much beer. My HDR tv is in the living room, and my apollo lake is in the game room. It will require some swapping.
I though there is not difference between Apollo and Kaby lake hardware
I cant install it on my NUC as its only got 32gb EEC and I need extra 8gb for the upgrade tool!
So annoying
(2017-04-13, 22:48)Nekromantik Wrote: [ -> ]I cant install it on my NUC as its only got 32gb EEC and I need extra 8gb for the upgrade tool!
So annoying
wut? You can upgrade just fine, as long as the external media you're upgrading from has 10GB+ free space. Just download the ISO, throw it on a USB, then run the upgrade from there. I just did it on my 16GB Chromebook, which had ~4.5GB free on the internal eMMC.
