Full Version: Intel Apollo Lake
(2017-06-04, 22:02)vidCanuck Wrote: [ -> ]
(2017-06-04, 19:56)fritsch Wrote: [ -> ]Overwrite your edid information, LibreELEC wiki has a howto on how to do that. This will fake an always on TV.
Worked perfect, thanks a lot.
I spoke too soon. It seems to work for a few TV toggles but after 10h or so it reverts back to HDMI.
If you think this is Libreelec specific let me know and I'll post on their forum.
The Kodi log doesn't show much, no errors. Devices are discovered the same:
03:16:56.328 T:140673106503808 NOTICE: Device 4
03:16:56.328 T:140673106503808 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=0
03:16:56.328 T:140673106503808 NOTICE: m_displayName : HDA Intel PCH
03:16:56.328 T:140673106503808 NOTICE: m_displayNameExtra: GSM LG TV on DisplayPort #0
03:16:56.328 T:140673106503808 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
03:16:56.328 T:140673106503808 NOTICE: m_channels : FL,FR,LFE,FC,BC,BL,BR,FLOC,FROC,BLOC,BROC,TFC,TC,TFL,TFR,UNKNOWN1
03:16:56.328 T:140673106503808 NOTICE: m_sampleRates : 32000,44100,48000
03:16:56.328 T:140673106503808 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
03:16:56.328 T:140673106503808 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
10:20:11.694 T:140672996734720 NOTICE: Device 4
10:20:11.694 T:140672996734720 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=0
10:20:11.694 T:140672996734720 NOTICE: m_displayName : HDA Intel PCH
10:20:11.695 T:140672996734720 NOTICE: m_displayNameExtra: GSM LG TV on HDMI #0
10:20:11.695 T:140672996734720 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
10:20:11.695 T:140672996734720 NOTICE: m_channels : FL,FR,LFE,FC,BC,BL,BR,FLOC,FROC,BLOC,BROC,TFC,TC,TFL,TFR,UNKNOWN1
10:20:11.695 T:140672996734720 NOTICE: m_sampleRates : 32000,44100,48000
10:20:11.695 T:140672996734720 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
10:20:11.695 T:140672996734720 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
EDID seems to load ok (from startup log):
[ 0.000000] Kernel command line: root=/dev/ram0 rdinit=/init usbcore.autosuspend=-1 BOOT_IMAGE=/KERNEL boot=LABEL=System disk=LABEL=Storage quiet initrd=/edid.cpio drm_kms_helper.edid_firmware=DP-1:edid/edid.bin video=DP-1:D
[ 2.173297] [drm] Got external EDID base block and 1 extension from "edid/edid.bin" for connector "DP-1"
After several hours when I turn the TV on and check settings it's still DisplayPort but as soon as I try to play TV (no audio) I get:
18:59:16.862 T:140269547980544 NOTICE: Found 2 Lists of Devices
18:59:16.862 T:140269547980544 NOTICE: Enumerated ALSA devices:
and then the device shows up as HDMI again.
Update -----------------------------------------------------------------------------------------------------
Fixed this by setting "Keep audio device alive" to "Always"
just a question is there any updated LE9-KODI_AGILE build that have the secure Inputstream.adaptive build in? only 1 I can found is from april 12.
I don't think Ive seen one around. As far as I know Milhouse exclusively builds from master and not agile ?
(2017-06-06, 19:15)lejose Wrote: [ -> ]I don't think Ive seen one around. As far as I know Milhouse exclusively builds from master and not agile ?
Correct. @piotrasd might have an agile build though.
Normally I use millhouse builds, but like netlfix on kodi also Smile now switching between builds.
I have been looking into a solution that will allow me to replace the roku2 for watching uk on demand TV and my HTPC for movies (1K/4K) & lossless HD music playback. HDR and 3D would be nice to have for future upgrade as currently I'm still in love with my reference Kuro pioneer TV. Maybe 2018 will be year for OLED screen upgrade.
The plan is to use the current HTPC as a fileserver and have it remotely stored to minimise noise to the TV room. Ethernet will be used for connectivity.
I came across the new Mele Apollo PC and it seems to tick all the boxes.
My concerns are whether the onboard fixed 4gb memory will be enough to run w10 and 4K movies and
Also will the Intel firmware upgrades also work on this to fix known audio pass through issues etc.
What are your thoughts on this solution ?
Does this box use DP>HDMI and if so will the Intel FW upgrades work to fix it or are they specifically for their NUC's only ?
MeLE PCG03 Apo mini PC specifications:
SoC – Intel Celeron N3450 quad core “Apollo Lake” processor @ 1.10 / 2.20 GHz with 12 EU Intel HD Graphics 500 (6W TDP)
System Memory – 4GB DDRL3L (soldered)
Storage – 32GB eMMC 5.0 flash (soldered), 1x M.2 SSD slot, 1x SD slot
Video Output – HDMI 2.0 up to 4K @ 60 Hz, and VGA
Audio – Via HDMI, 3.5mm audio combo jack
Connectivity – Gigabit Ethernet, 802.11 ac WiFi & Bluetooth 4.0
USB – 3x USB 3.0 ports, 1x USB 2.0 port, 1x USB3.0 Type-C port
http://www.cnx-software.com/2017/04/10/m...-0-output/
Box is on special offer of £123 delivered !
Possibly huge bargain.
I picked up a J4205-ITX after reading about it on this thread. The main reason was for its ability to output 4k to tv and audio to my non-4k receiver via DVI. I got it up and running with a picoPSU, 8gb ram and 120gb SSD. Windows 10 and LE worked fine via HDMI. However when I connected via DVI, the screen flickers quite badly, or doesnt seem to 'sync' with the TV at all. I then returned the J4205 thinking it was faulty and got a J3455 (as J4205 was out of stock by then). I have the same problem with the J3455 too. I have tried everything I can think of but cant fix the problem. Did any of the J4205 or J3455 owners have similar problems with their DVI port?
(2017-06-07, 15:27)sm83 Wrote: [ -> ]I picked up a J4205-ITX after reading about it on this thread. The main reason was for its ability to output 4k to tv and audio to my non-4k receiver via DVI. I got it up and running with a picoPSU, 8gb ram and 120gb SSD. Windows 10 and LE worked fine via HDMI. However when I connected via DVI, the screen flickers quite badly, or doesnt seem to 'sync' with the TV at all. I then returned the J4205 thinking it was faulty and got a J3455 (as J4205 was out of stock by then). I have the same problem with the J3455 too. I have tried everything I can think of but cant fix the problem. Did any of the J4205 or J3455 owners have similar problems with their DVI port?
Yes, but note i only had similar problems in windows, and only when connecting HDMI->4k tv and DVI-> receiver. Others have done it ok, but i couldn't ever really make it work.
Just bought a 4k receiver, problem solved.(although costly)
(2017-06-07, 15:34)honcho Wrote: [ -> ]
I have not experienced this issue with the J4205 and have been running LE for about 6 months now. I can't say this is not an issue with Windows 10, because I have not used W10 with the J4205. I have a Pioneer VSX-53 receiver and a Samsung JS8500 4k TV.
(2017-06-07, 13:55)archy121 Wrote: [ -> ]I have been looking into a solution that will allow me to replace the roku2 for watching uk on demand TV and my HTPC for movies (1K/4K) & lossless HD music playback. HDR and 3D would be nice to have for future upgrade as currently I'm still in love with my reference Kuro pioneer TV. Maybe 2018 will be year for OLED screen upgrade.
Tear down of the pc has been done including details of chips inside and photos.
Quote:Realtek ALC269 audio coded for the headphone jack
M-TEK G24101SCGX Gigabit Ethernet transformer
ParadeTech PS175HDM DisplayPort 1.2 to HDMI 2.0a converter
ITE IT6513FN DisplayPort to VGA controller
Realtek RTS5170 card reader controller driver
Richtek RT5074A, probably a power management IC
Intel 3165D2W wireless module for 802.11 b/g/n/ac WiFi and Bluetooth 4.0 LE
http://www.cnx-software.com/2017/06/08/m...ent-542849
With confirmed inclusion of M.2 SSD and IR this could make an excellent value HTPC if the DP>HDMI has been implemented well with fully functional HD pass thru.
thanks!
does anybody know if there is still work in progress on the hd audio issue?
Silence on intel bugtracker, feel free to bump it: https://bugs.freedesktop.org/show_bug.cgi?id=98797 by providing another dmesg with drm.debug=0xe booted.
Edit: Btw. what even more sucks for me is, that sometimes the kernel does not want to open > 2 channels, e.g. you end up with a 5.1 sink but only 2 channels (FL, FR working) ... also a kernel bug. As I currently have no time for kodi in my freetime I switched to the DVI (HDMI) out.
The LibreELEC Intel guys (on Slack) when I last chatted to them recommended users wait for a proper HDMI 2.0 implementation and skip the current Apollo and Kaby Lake series all together.
Apparently new Intel Iron with proper HDMI 2.0 is going to be called something like Coffee Lake and Gemini Lake. Wink
Agree.
But to be honest, native port on hdmi1.4 (either directly on chipset or via DVI->hdmi) runs without issues. Currently running on windows but libreelec also ran fine. So up to 4k 30hz I still find Apollo lake nice platform. I watch only movies anyway, so I don't care about 4k 60hz at all.
Only issue I encounter is av sync in some 3d material, but I doubt whether that is related to CPU/gpu.
Sent from my HTC One_M8
