Isn't Apollo Lake(J3455/4205) megachip capable HDMI 2.0 only? HDR require 2.0a if I'm not mistaken.
So Apollo Lake will never output HDR regardless of OS.
I'm happy if someone can prove me wrong because I'm using J3455 myself.
(2017-07-22, 17:34)dumpling Wrote: [ -> ]Isn't Apollo Lake(J3455/4205) megachip capable HDMI 2.0 only? HDR require 2.0a if I'm not mistaken.
Dolby Vision tunnels through HDMI 2.0 (and I think HDMI 1.4b) I think.
HDR10 is HDMI 2.0a.
HLG is HDMI 2.0b, as is I think HDR+10.
So it depends which flavour of HDR you are talking about.
(2017-07-22, 18:31)noggin Wrote: [ -> ]Dolby Vision tunnels through HDMI 2.0 (and I think HDMI 1.4b) I think.
HDR10 is HDMI 2.0a.
Great. There's still hope!
BTW, Mod. Can you edit the first post put a summary of current Apollo Lake compatibility and solution/fix? It will be a great help to the new guys.
Go through all the post in this thread just become too time-consuming now and leads to same question being posted again and again.
The common question I can think of, for instance, HD audio issue & fix, Apollo Lake capability on current Kodi on different OS namely LibreElec, Linux, Win 10.
Someone posted a summary in the thread but I couldn't find it.
If you post the summary, we can for sure add it.
(2017-07-22, 18:31)noggin Wrote: [ -> ] (2017-07-22, 17:34)dumpling Wrote: [ -> ]Isn't Apollo Lake(J3455/4205) megachip capable HDMI 2.0 only? HDR require 2.0a if I'm not mistaken.
HDR10 is HDMI 2.0a.
Yeah but AFAIK HDMI 2.0 to HDMI 2.0a is just a software/firmware/driver update. Not different hardware.
hello @all
is there now any chance that DTS-HD or True-HD will work via libreelec or just on windows 10 so far? (after applying chip set upgrade, latest intel driver)
thank you!
(2017-07-24, 22:48)c_future Wrote: [ -> ]hello @all
thank you!
it's an issue on the Linux driver side, will have to wait for Intel to fix
Thanks a lot for clarification
so I'll wait and use the windows 10 installation for now.
there - everything is working nicely - had my first 4K movie with DTS HD playing.
One last thins came to my attention (maybe due using the lastest nightly 64bit master build?)
http://mirrors.kodi.tv/nightlies/windows/win64/master/
KodiSetup-20170723-51a70ff-master-x64.exe
when using the kodi wasapi as audio output device sound output is silent every some (maybe 5 to 10?) minutes for a couple of seconds (no sync issues - just no sound).
switching to directsound hdmi device "fixes" the issue but its not the preferred output device as described here for example:
http://kodi.wiki/view/Windows_audio
anyone had issues so far with kodi 64bit - Wasapi - win10 - hd audio ?
thanks a lot!
I am really happy with my htpc setup with asrock j3455. I hope we will get HDR working soon, only thing I am missing on my 4k HDR tv.
https://01.org/linuxgraphics/downloads/2...ack-recipe
Quote:Add support for Gemini Lake (aka. GLK)
- Decoding: H.264/MPEG-2/VC-1/JPEG/VP8/HEVC/HEVC 10-bit/VP9/VP9 10-bit
Intel Gemini Lake supports VP9 10-bit Profile2 hardware decoding, Apollo Lake only supported VP9 8-bit Profile0.[/quote]
(2017-08-02, 10:36)HDGMA Wrote: [ -> ]https://01.org/linuxgraphics/downloads/2...ack-recipe
Yeah still needs to support HDR for that to actually matter (Apollo Lake decodes HEVC 10-bit and doesn't support HDR right now... or maybe ever - thanks Intel)
How smooth is the interface on an Apollo Lake device? Is it choppy/jerky while scrolling through a library with fan art, for example? What about using the interface while a video is playing in the background?
You'll have to enable 2160p 60hz to get smooth Interface.
Why that? Running it in 1080p50 perfectly. Here is a video posted somewhere.
