2016-04-19, 10:23
Hi
So I have this problem. I need to buy new media player. For reference - I have Dune Prime 3.0 at the moment. I know what I want but I'm struggling between four concepts:
- HiMedia Q10/Q5 pro
- WeTek new device
- Dune Solo 4k
- HTPC/MiniPC (not NUC, would build it myself on ITX and Windows)
What I want is smooth playback without any configuration hassle - I'd like to make config once and forget about it. Things like check something to play this specific file is big disadvantage. I don't care for 3D and 4k and proper ISO support. I just want full support for everything else with 10bit h265 as a strong example. Player has to have Samba support because all my media is a network share. But the four players I mentioned above should play this nicely.
The description below is what I think about pros and cons for those players. And what I ask of you is to tell me if I'm wrong at some point and guide me towards what's the best. I will edit points below to reflect latest changes in my mind after your suggestions.
HiMedia Q10/Q5 pro
+ All-in-one, almost without the need of configuration
+ Small factor
+ HDMI 2.0
+ Can play almost anything (even h264 10bit from what I understand)
+ Kodi as a library
- Needs wrapper
- Needs native player to use hardware
- I don't trust Chinese companies (especially after playing with some cheap amlogic s905 thing)
- Won't support future codecs
- Firmware problem at the moment. It maybe fixed...but may not so the trust in manufacturer is needed.
WeTek new device
+ Small factor
+ Will play almost anything
+ Kodi as a library
+ Great support from Kodi
- Great unknown for me as those devices are not yet on the market
Dune Solo 4k
+ I have faith in Dune
+ Small factor
+ Can play almost anything and without any problem
+ Can be used as a DVB-T with ability to record (it's interesting but not a deal breaker)
+ I'm familiar with interface
+ YaDIS
- Kodi is better then YaDIS as a library
- Quite expensive
- No HDMI 2.0 - have no idea what will be impact on future so not 100% future proof
HTPC/MiniPC
+ Flexibility - I could choose hardware and therefore power I want
+ Quite future proof - even if new codecs arrives I would change CPU or GPU and still have hardware acceleration
+ Kodi
+ No wrappers or other hacks to work properly
+/- Can be extended with additional modules like DVB-T/T2 sticks but that is also additional cost
- Quite expensive (especially with Windows)
- Hard to choose proper hardware - I know quite a lot about PC hardware but not in context of playing movies so I don't know what CPU I need and if external GPU is needed
- More noise from CPU and maybe GPU fans
- Problem with remote - I would have to choose some small media keyboard with touchpad or play with some irda accessories
- Will use more power
Thx.
- WeTek new device
- Dune Solo 4k
HiMedia Q10/Q5 pro
+ Small factor
+ HDMI 2.0
+ Kodi as a library
- Needs wrapper
WeTek new device
+ Small factor
+ Kodi as a library
Dune Solo 4k
+ Small factor
+ YaDIS
- Quite expensive
HTPC/MiniPC
+ Kodi
Thx.
