Full Version: Python Development with Eclipse IDE?
Hi there.
Threre just must be an easy way to develop Pythons to XBMC than with notepad via XBMC_PC.
In general Eclipse is the most common and the best IDE there is.
http://www.eclipse.org/downloads/
OnTop of Eclipse user can install PlugIns like J2EE environments, Symbian devs etc.
I found PyDEV plugin for Eclipse http://pydev.sourceforge.net/index.html
and I was wondering has anyone tested Python dev with these settings?
The question is HOW to make XBMC runnable (WinXML?) Pythons with Eclipse & PyDEV?
if it's XBMC specific, your best bet is to use any good text editor (I use scite) and XBMC_PC.
I can make available the modded files for XBMC that highlights xbmc and xbmcgui keywords if you choose scite.
If you're on linux, use the linux port for the same thing.
I used vim on Unix Wink
