Full Version: Android:- App crash once when installs fresh app and open the particular video
I am facing one weired crash on KODI Android. (KODI Version:- 16.0)
Details:-
i) SoC Details :- Amlogic S-905 SoC
ii) Android OS :- Android-5.1.1
iii) KODI App version:- 16.0 (Source Link:- https://kodi.tv/download/)
iv) Video File Format:- UHD_H265_50fps_4k
Reproducible Steps:-
1) Start the Android TV Box
2) Install the KODI app using downloaded apk file
3) Open the KODI from the Android App list
4) Open the Video File List
5) Select the "UHD_H265_50fps_4k" file format and play the video
6) App crash randomly on first installation.
Issue:- Application crashed randomly on first time when install the fresh app and play the particular video format on first time.
Note:- It crashed continuously 2-3 times and than works perfectly.
KODI Log File Details:-
06:19:28 T:18446744072286195176  NOTICE: special://profile/ is mapped to: special://masterprofile/
06:19:28 T:18446744072286195176  NOTICE: -----------------------------------------------------------------------
06:19:28 T:18446744072286195176  NOTICE: Starting Kodi (16.0 Git:2016-02-20-a5f3a99). Platform: Android ARM 32-bit
06:19:28 T:18446744072286195176  NOTICE: Using Release Kodi x32 build
06:19:28 T:18446744072286195176  NOTICE: Kodi compiled Feb 20 2016 by GCC 4.8.0 for Android ARM 32-bit API level 17 (API level 17)
06:19:28 T:18446744072286195176  NOTICE: Running on amlogic MXplus_S with Android 5.1.1 API level 22, kernel: Linux unknown CPU family 64-bit version 3.14.29
06:19:28 T:18446744072286195176  NOTICE: FFmpeg version: 2.8.6-kodi-2.8.6-Jarvis-16.0
06:19:28 T:18446744072286195176  NOTICE: Host CPU: AArch64 Processor rev 4 (aarch64), 4 cores available
06:19:28 T:18446744072286195176  NOTICE: Product: p200, Device: p200, Board: p200 - Manufacturer: amlogic, Brand: Android, Model: MXplus_S, Hardware: amlogic
06:19:28 T:18446744072286195176  NOTICE: External storage path = /storage/emulated/0; status = ok
06:19:28 T:18446744072286195176  NOTICE: ARM Features: Neon enabled
06:19:28 T:18446744072286195176  NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
06:19:28 T:18446744072286195176  NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
06:19:28 T:18446744072286195176  NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
06:19:28 T:18446744072286195176  NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
06:19:28 T:18446744072286195176  NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
06:19:28 T:18446744072286195176  NOTICE: The executable running is: /system/bin/app_process32
06:19:28 T:18446744072286195176  NOTICE: Local hostname: localhost
06:19:28 T:18446744072286195176  NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
06:19:28 T:18446744072286195176  NOTICE: load settings...
06:19:28 T:18446744072286195176   DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
06:19:28 T:18446744072286195176 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
06:19:28 T:18446744072286195176   DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
06:19:28 T:18446744072286195176   DEBUG: AESinkAUDIOTRACK - 44100 supported
06:19:28 T:18446744072286195176   DEBUG: AESinkAUDIOTRACK - 48000 supported
06:19:28 T:18446744072286195176   DEBUG: AESinkAUDIOTRACK - 96000 supported
06:19:28 T:18446744072286195176  NOTICE: Found 1 Lists of Devices
06:19:28 T:18446744072286195176  NOTICE: Enumerated AUDIOTRACK devices:
06:19:28 T:18446744072286195176  NOTICE:     Device 1
06:19:28 T:18446744072286195176  NOTICE:         m_deviceName      : AudioTrack
06:19:28 T:18446744072286195176  NOTICE:         m_displayName     : android
06:19:28 T:18446744072286195176  NOTICE:         m_displayNameExtra: audiotrack
06:19:28 T:18446744072286195176  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
06:19:28 T:18446744072286195176  NOTICE:         m_channels        : FL,FR,FC,LFE,BL,BR,SL,SR
06:19:28 T:18446744072286195176  NOTICE:         m_sampleRates     : 48000,44100,48000,96000
06:19:28 T:18446744072286195176  NOTICE:         m_dataFormats     : AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS
06:19:28 T:18446744072286195176   ERROR: CSettings: unable to load settings from special://masterprofile/guisettings.xml, creating new default settings
06:19:28 T:18446744072286195176   DEBUG: CSkinSettings: no <skinsettings> tag found
06:19:28 T:18446744072286195176  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
06:19:28 T:18446744072286195176  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
06:19:28 T:18446744072286195176  NOTICE: Default DVD Player: dvdplayer
06:19:28 T:18446744072286195176  NOTICE: Default Video Player: dvdplayer
06:19:28 T:18446744072286195176  NOTICE: Default Audio Player: paplayer
06:19:28 T:18446744072286195176  NOTICE: Disabled debug logging due to GUI setting. Level 0.
06:19:28 T:18446744072286195176  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
06:19:28 T:18446744072286195176  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
06:19:28 T:18446744072286195176  NOTICE: Loaded playercorefactory configuration
06:19:28 T:18446744072286195176  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
06:19:28 T:18446744072286195176  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
06:19:30 T:18446744072286195176  NOTICE: ADDONS: Using repository repository.xbmc.org
06:19:30 T:18446744072286195176  NOTICE: virtual bool CWinSystemEGL::InitWindowSystem(): Using EGL Implementation: amlandroid
06:19:30 T:18446744072286195176  NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
06:19:30 T:18446744072286195176  NOTICE: Previous line repeats 1 times.
06:19:30 T:18446744072286195176  NOTICE: Found resolution 1920 x 1080 for display 0 with 1280 x 720 @ 60.000000 Hz
06:19:30 T:18446744072286195176  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 60.000000 Hz
06:19:30 T:18446744072286195176  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
06:19:30 T:18446744072286195176  NOTICE: Found resolution 1920 x 1080 for display 0 with 1280 x 720 @ 50.000000 Hz
06:19:30 T:18446744072286195176  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 50.000000 Hz
06:19:30 T:18446744072286195176  NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
06:19:30 T:18446744072286195176  NOTICE: Found ([email protected]) at 18, setting to RES_DESKTOP at 16
06:19:30 T:18446744072286195176  NOTICE: Checking resolution 16
06:19:30 T:18446744072286195176  NOTICE: GL_VENDOR = ARM
06:19:30 T:18446744072286195176  NOTICE: GL_RENDERER = Mali-450 MP
06:19:30 T:18446744072286195176  NOTICE: GL_VERSION = OpenGL ES 2.0
06:19:30 T:18446744072286195176  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
06:19:30 T:18446744072286195176  NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_OES_mapbuffer
06:19:31 T:18446744072286195176   ERROR: Unable to load libcec.so, reason: (null)
06:19:31 T:18446744072286195176   ERROR: virtual void PERIPHERALS::CPeripherals::Initialise() - failed to initialise bus cec
06:19:31 T:18446744072286195176  NOTICE: Running database version Addons20
06:19:32 T:18446744072286195176 WARNING: CSkinInfo: failed to load skin settings
06:19:32 T:18446744072286195176 WARNING: Previous line repeats 1 times.
06:19:32 T:18446744072286195176 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
06:19:32 T:18446744072286195176  NOTICE: ActiveAE DSP - starting
06:19:32 T:18446744072286195176  NOTICE: initialize done
06:19:32 T:18446744072286195176  NOTICE: Running the application...
06:19:32 T:18446744072294366648   ERROR: FileZip: failed to decompress. zlib error -3
06:19:32 T:18446744072294366648   ERROR: CRepositoryUpdateJob[repository.xbmc.org] failed to read or parse directory 'http://mirrors.kodi.tv/addons/jarvis/addons.xml.gz'
06:19:33 T:18446744072286195176  NOTICE: starting zeroconf publishing
06:19:33 T:18446744072286195176  NOTICE: starting upnp client
06:19:33 T:18446744072295618568  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
06:19:33 T:18446744072295618568  NOTICE: UDP: Listening on port 9777
06:19:33 T:18446744072286195176  NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
06:19:33 T:18446744072286195176  NOTICE: GL_VENDOR = ARM
06:19:33 T:18446744072286195176  NOTICE: GL_RENDERER = Mali-450 MP
06:19:33 T:18446744072286195176  NOTICE: GL_VERSION = OpenGL ES 2.0
06:19:33 T:18446744072286195176  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
06:19:33 T:18446744072286195176  NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_OES_mapbuffer
06:19:43 T:18446744072286195176  NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
06:19:43 T:18446744072286195176  NOTICE: Enabled debug logging due to GUI setting. Level 2.
06:19:43 T:18446744072286195176   DEBUG: Unfocus WindowID: 10016, ControlID: -76
06:19:43 T:18446744072286195176   DEBUG: ------ Window Init () ------
06:19:48 T:18446744072286195176    INFO: Python, unloading python shared library because no scripts are running anymore
06:19:48 T:18446744072286195176   DEBUG: void XBPython::UnloadExtensionLibs(), clearing python extension libraries
06:19:51 T:18446744072286195176   DEBUG: bool CInputManager::ProcessMouse(int): trying mouse action leftclick
06:19:51 T:18446744072286195176   DEBUG: Unfocus WindowID: 10016, ControlID: -79
06:19:52 T:18446744072286195176   DEBUG: bool CInputManager::ProcessMouse(int): trying mouse action leftclick
06:19:52 T:18446744072286195176   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
06:19:53 T:18446744072286195176   DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
06:19:53 T:18446744072286195176   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
06:19:53 T:18446744072286195176   DEBUG: ------ Window Init (Settings.xml) ------
06:19:53 T:18446744072286195176   DEBUG: Unfocus WindowID: 10004, ControlID: 9000
06:19:54 T:18446744072286195176   DEBUG: bool CInputManager::ProcessMouse(int): trying mouse action leftclick
06:19:54 T:18446744072286195176   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
06:19:54 T:18446744072286195176   DEBUG: ------ Window Deinit (Settings.xml) ------
06:19:54 T:18446744072286195176   DEBUG: CGUIWindowManager::PreviousWindow: Activate new
06:19:54 T:18446744072286195176   DEBUG: ------ Window Init (Home.xml) ------
06:19:54 T:18446744072286195176   DEBUG: Unfocus WindowID: 10000, ControlID: 9000
06:19:56 T:18446744072286195176   DEBUG: bool CInputManager::ProcessMouse(int): trying mouse action leftclick
06:19:56 T:18446744072286195176   DEBUG: Activating window ID: 10025
06:19:56 T:18446744072286195176   DEBUG: ------ Window Deinit (Home.xml) ------
06:19:57 T:18446744072286195176   DEBUG: ------ Window Init (MyVideoNav.xml) ------
06:19:57 T:18446744072286195176    INFO: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
06:19:57 T:18446744072286195176   DEBUG: CGUIMediaWindow::GetDirectory ()
06:19:57 T:18446744072286195176   DEBUG:   ParentPath = []
06:19:57 T:18446744072297613264   DEBUG: Thread BackgroundLoader start, auto delete: false
06:19:57 T:18446744072297613264   DEBUG: Thread BackgroundLoader 18446744072297613264 terminating
06:19:57 T:18446744072286195176   DEBUG: Activating window ID: 11112
06:19:57 T:18446744072286195176   DEBUG: ------ Window Init (custom_SideMenuHelp.xml) ------
06:19:57 T:18446744072286195176    INFO: Loading skin file: custom_SideMenuHelp.xml, load type: KEEP_IN_MEMORY
06:19:58 T:18446744072286195176   DEBUG: bool CInputManager::ProcessMouse(int): unknown mouse command 57605
06:19:58 T:18446744072286195176   DEBUG: bool CInputManager::ProcessMouse(int): unknown mouse command 57606
06:19:58 T:18446744072286195176   DEBUG: Unfocus WindowID: 11112, ControlID: 100
06:19:58 T:18446744072286195176   DEBUG: Unfocus WindowID: 10025, ControlID: 50
06:19:59 T:18446744072286195176   DEBUG: bool CInputManager::ProcessMouse(int): trying mouse action leftclick
06:19:59 T:18446744072286195176   DEBUG: Unfocus WindowID: 11112, ControlID: 100
06:20:00 T:18446744072286195176   DEBUG: ------ Window Deinit (custom_SideMenuHelp.xml) ------
06:20:01 T:18446744072286195176   DEBUG: bool CInputManager::ProcessMouse(int): trying mouse action leftclick
06:20:01 T:18446744072286195176   DEBUG: CGUIMediaWindow::GetDirectory (library://video/files.xml/)
06:20:01 T:18446744072286195176   DEBUG:   ParentPath = []
06:20:01 T:18446744072298536976   DEBUG: Thread BackgroundLoader start, auto delete: false
06:20:01 T:18446744072286195176   DEBUG: Unfocus WindowID: 10025, ControlID: 50
06:20:01 T:18446744072286195176   DEBUG: SECTION:UnloadDelayed(DLL: libImageLib-arm.so)
06:20:01 T:18446744072298536976   DEBUG: Thread BackgroundLoader 18446744072298536976 terminating
06:20:02 T:18446744072286195176   DEBUG: bool CInputManager::ProcessMouse(int): trying mouse action leftclick
06:20:02 T:18446744072286195176   DEBUG: CGUIMediaWindow::GetDirectory (/storage/udisk0/)
06:20:02 T:18446744072286195176   DEBUG:   ParentPath = [sources://video/]
06:20:02 T:18446744072298536976   DEBUG: Thread BackgroundLoader start, auto delete: false
06:20:02 T:18446744072286195176   DEBUG: Unfocus WindowID: 10025, ControlID: 50
06:20:02 T:18446744072294366648   DEBUG: virtual bool CThumbExtractor::DoWork() - trying to extract thumb from video file /storage/udisk0/Demo Ultra-HD - Sony - Surfing_H265_60fps_4k.mp4
06:20:02 T:18446744072294366648   DEBUG: bool CDVDDemuxFFmpeg::Open(CDVDInputStream*, bool, bool) - probing detected format [mov,mp4,m4a,3gp,3g2,mj2]
06:20:02 T:18446744072294366648   DEBUG: bool CDVDDemuxFFmpeg::Open(CDVDInputStream*, bool, bool) - avformat_find_stream_info starting
06:20:02 T:18446744072298536976   DEBUG: Thread BackgroundLoader 18446744072298536976 terminating
06:20:02 T:18446744072294366648   DEBUG: bool CDVDDemuxFFmpeg::Open(CDVDInputStream*, bool, bool) - av_find_stream_info finished
06:20:02 T:18446744072294366648    INFO: ffmpeg[ABA5FDB8]: Input #0, mov,mp4,m4a,3gp,3g2,mj2, /storage/udisk0/Demo Ultra-HD - Sony - Surfing_H265_60fps_4k.mp':
06:20:02 T:18446744072294366648    INFO: ffmpeg[ABA5FDB8]:   Metadata:
06:20:02 T:18446744072294366648    INFO: ffmpeg[ABA5FDB8]:     major_brand     : isom
06:20:02 T:18446744072294366648    INFO: ffmpeg[ABA5FDB8]:     minor_version   : 1
06:20:02 T:18446744072294366648    INFO: ffmpeg[ABA5FDB8]:     compatible_brands: isom
06:20:02 T:18446744072294366648    INFO: ffmpeg[ABA5FDB8]:     creation_time   : 2015-01-26 04:33:07
06:20:02 T:18446744072294366648    INFO: ffmpeg[ABA5FDB8]:   Duration: 00:02:59.05, start: 0.000000, bitrate: 77423 kb/s
06:20:02 T:18446744072294366648    INFO: ffmpeg[ABA5FDB8]:     Stream #0:0(und): Video: hevc (Main) (hvc1 / 0x31637668), yuv420p(tv, bt709), 3840x2160 [SAR 1:1 DAR 16:9], 77228 kb/s, 59.94 fps, 59.94 tbr, 60k tbn, 59.94 tbc (default)
06:20:02 T:18446744072294366648    INFO: ffmpeg[ABA5FDB8]:       creation_time   : 2015-01-26 04:32:42
06:20:02 T:18446744072294366648    INFO: ffmpeg[ABA5FDB8]:       handler_name    : Video Media Handler
06:20:02 T:18446744072294366648    INFO: ffmpeg[ABA5FDB8]:       encoder         : HEVC Coding
06:20:02 T:18446744072294366648    INFO: ffmpeg[ABA5FDB8]:     Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 192 kb/s (default)
06:20:02 T:18446744072294366648    INFO: ffmpeg[ABA5FDB8]:       handler_name    : Sound Media Handler
06:20:02 T:18446744072294366648   DEBUG: CDVDDemuxFFmpeg::AddStream(0, ...) -> 0
06:20:02 T:18446744072294366648   DEBUG: CDVDDemuxFFmpeg::AddStream(1, ...) -> 1
06:20:02 T:18446744072294366648   DEBUG: static void CUtil::ScanForExternalSubtitles(const string&, std::vector<std::basic_string<char> >&): Searching for subtitles...
06:20:02 T:18446744072294366648   DEBUG: static void CUtil::ScanForExternalSubtitles(const string&, std::vector<std::basic_string<char> >&): END (total time: 6 ms)
06:20:02 T:18446744072294366648   DEBUG: CDVDFactoryCodec: compiled in hardware support: AMCodec:yes MediaCodec:yes OpenMax:no libstagefright:no VDPAU:no VAAPI:no iMXVPU:no MMAL:no
06:20:02 T:18446744072294366648   DEBUG: FactoryCodec - Video:  - Opening
06:20:02 T:18446744072294366648  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
06:20:02 T:18446744072294366648   DEBUG: FactoryCodec - Video: ff-hevc - Opened
06:20:02 T:18446744072294366648   DEBUG: static bool CDVDFileInfo::ExtractThumb(const string&, CTextureDetails&, CStreamDetails*, int) - seeking to pos 59683ms (total: 179050ms) in /storage/udisk0/Demo Ultra-HD - Sony - Surfing_H265_60fps_4k.mp4
06:20:02 T:18446744072294366648   DEBUG: virtual bool CDVDDemuxFFmpeg::SeekTime(int, bool, double*) - unknown position after seek
06:20:03 T:18446744072286195176   DEBUG: bool CInputManager::ProcessMouse(int): trying mouse action wheeldown
06:20:03 T:18446744072286195176   DEBUG: Unfocus WindowID: 10025, ControlID: 50
06:20:03 T:18446744072286195176    INFO: void XCURL::DllLibCurlGlobal::CheckIdle() - Closing session to http://mirrors.kodi.tv (easy=0xabaa3c90, multi=0xabaa3b88)
06:20:04 T:18446744072286195176   DEBUG: bool CInputManager::ProcessMouse(int): trying mouse action wheeldown
06:20:04 T:18446744072286195176   DEBUG: Unfocus WindowID: 10025, ControlID: 50
06:20:04 T:18446744072294366648   DEBUG: cached image 'special://masterprofile/Thumbnails/a/a9f7bb46.jpg' size 360x202
06:20:04 T:18446744072294366648   DEBUG: static bool CDVDFileInfo::ExtractThumb(const string&, CTextureDetails&, CStreamDetails*, int) - measured 2411 ms to extract thumb from file </storage/udisk0/Demo Ultra-HD - Sony - Surfing_H265_60fps_4k.mp4> in 17 packets.
06:20:05 T:18446744072286195176    INFO: void XCURL::DllLibCurlGlobal::CheckIdle() - Closing session to http://feeds.kodi.tv (easy=0xabeefe88, multi=0xabb8aef0)
06:20:05 T:18446744072295413920   DEBUG: virtual bool CThumbExtractor::DoWork() - trying to extract thumb from video file /storage/udisk0/Samsung_UHD_7_Wonders_H265_60fps_4k.ts
06:20:05 T:18446744072295413920   DEBUG: bool CDVDDemuxFFmpeg::Open(CDVDInputStream*, bool, bool) - probing detected format [mpegts]
06:20:05 T:18446744072295413920   DEBUG: bool CDVDDemuxFFmpeg::Open(CDVDInputStream*, bool, bool) - avformat_find_stream_info starting
06:20:05 T:18446744072286195176   DEBUG: bool CInputManager::ProcessMouse(int): trying mouse action wheeldown
06:20:05 T:18446744072286195176   DEBUG: Unfocus WindowID: 10025, ControlID: 50
06:20:05 T:18446744072295413920   DEBUG: ffmpeg[ABB5F8A0]: [NULL] start time for stream 1 is not set in estimate_timings_from_pts
06:20:06 T:18446744072295413920   DEBUG: ffmpeg[ABB5F8A0]: [mpegts] Could not find codec parameters for stream 1 (Audio: aac ([15][0][0][0] / 0x000F), 0 channels, fltp): unspecified sample rate
06:20:06 T:18446744072295413920   DEBUG: ffmpeg[ABB5F8A0]: [mpegts] Consider increasing the value for the 'analyzeduration' and 'probesize' options
06:20:06 T:18446744072295413920   DEBUG: bool CDVDDemuxFFmpeg::Open(CDVDInputStream*, bool, bool) - av_find_stream_info finished
06:20:06 T:18446744072295413920    INFO: ffmpeg[ABB5F8A0]: Input #0, mpegts, /storage/udisk0/Samsung_UHD_7_Wonders_H265_60fps_4k.t':
06:20:06 T:18446744072295413920    INFO: ffmpeg[ABB5F8A0]:   Duration: 00:03:50.63, start: 1.050044, bitrate: 51774 kb/s
06:20:06 T:18446744072295413920    INFO: ffmpeg[ABB5F8A0]:   Program 1
06:20:06 T:18446744072295413920    INFO: ffmpeg[ABB5F8A0]:     Stream #0:0[0x101]: Video: hevc (Main 10) ([36][0][0][0] / 0x0024), yuv420p10le(tv), 3840x2160 [SAR 1:1 DAR 16:9], 59.94 fps, 59.94 tbr, 90k tbn, 59.94 tbc
06:20:06 T:18446744072295413920    INFO: ffmpeg[ABB5F8A0]:     Stream #0:1[0x102](und): Audio: aac ([15][0][0][0] / 0x000F), 0 channels, fltp
06:20:06 T:18446744072295413920   DEBUG: CDVDDemuxFFmpeg::AddStream(0, ...) -> 0
06:20:06 T:18446744072295413920   DEBUG: CDVDDemuxFFmpeg::AddStream(1, ...) -> 1
06:20:06 T:18446744072295413920   DEBUG: static void CUtil::ScanForExternalSubtitles(const string&, std::vector<std::basic_string<char> >&): Searching for subtitles...
06:20:06 T:18446744072295413920   DEBUG: static void CUtil::ScanForExternalSubtitles(const string&, std::vector<std::basic_string<char> >&): END (total time: 7 ms)
06:20:06 T:18446744072295413920   DEBUG: CDVDFactoryCodec: compiled in hardware support: AMCodec:yes MediaCodec:yes OpenMax:no libstagefright:no VDPAU:no VAAPI:no iMXVPU:no MMAL:no
06:20:06 T:18446744072295413920   DEBUG: FactoryCodec - Video:  - Opening
06:20:06 T:18446744072295413920  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
06:20:06 T:18446744072295413920   DEBUG: FactoryCodec - Video: ff-hevc - Opened
06:20:06 T:18446744072295413920   DEBUG: static bool CDVDFileInfo::ExtractThumb(const string&, CTextureDetails&, CStreamDetails*, int) - seeking to pos 76876ms (total: 230630ms) in /storage/udisk0/Samsung_UHD_7_Wonders_H265_60fps_4k.ts
06:20:06 T:18446744072295413920   DEBUG: virtual bool CDVDDemuxFFmpeg::SeekTime(int, bool, double*) - seek ended up on time 76517
06:20:06 T:18446744072295413920   ERROR: ffmpeg[ABB5F8A0]: [hevc] Could not find ref with POC 0
06:20:06 T:18446744072286195176   DEBUG: bool CInputManager::ProcessMouse(int): trying mouse action wheelup
06:20:06 T:18446744072286195176   DEBUG: Unfocus WindowID: 10025, ControlID: 50
06:20:10 T:18446744072295413920   DEBUG: ffmpeg[ABB5F8A0]: [src] w:3840 h:2160 pixfmt:yuv420p10le tb:1001/60000 fr:0/1 sar:1/1 sws_param:
06:20:10 T:18446744072295413920   DEBUG: ffmpeg[ABB5F8A0]: [auto-inserted scaler 0] w:iw h:ih flags:'bilinear' interl:0
06:20:10 T:18446744072295413920   DEBUG: ffmpeg[ABB5F8A0]: [out] auto-inserting filter 'auto-inserted scaler 0' between the filter 'src' and the filter 'out'
06:20:10 T:18446744072295413920   DEBUG: ffmpeg[ABB5F8A0]: [auto-inserted scaler 0] w:3840 h:2160 fmt:yuv420p10le sar:1/1 -> w:3840 h:2160 fmt:yuv420p sar:1/1 flags:0x2
06:20:13 T:18446744072286195176   DEBUG: bool CInputManager::ProcessMouse(int): trying mouse action leftclick
06:20:13 T:18446744072286195176   DEBUG: virtual bool CGUIWindowVideoBase::OnPlayMedia(int) /storage/udisk0/Insight_UHD_H265_50fps_4k_with_Dialogues.mkv
06:20:13 T:18446744072286195176   DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc
06:20:13 T:18446744072286195176   DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd
06:20:13 T:18446744072286195176   DEBUG: Loading settings for /storage/udisk0/Insight_UHD_H265_50fps_4k_with_Dialogues.mkv
06:20:13 T:18446744072286195176   DEBUG: CPlayerCoreFactory::GetPlayers(/storage/udisk0/Insight_UHD_H265_50fps_4k_with_Dialogues.mkv)
06:20:13 T:18446744072286195176   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
06:20:13 T:18446744072286195176   DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
06:20:13 T:18446744072286195176   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: mms/udp
06:20:13 T:18446744072286195176   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
06:20:13 T:18446744072286195176   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
06:20:13 T:18446744072286195176   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
06:20:13 T:18446744072286195176   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
06:20:13 T:18446744072286195176   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
06:20:13 T:18446744072286195176   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
06:20:13 T:18446744072286195176   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
06:20:13 T:18446744072286195176   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
06:20:13 T:18446744072286195176   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
06:20:13 T:18446744072286195176   DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
06:20:13 T:18446744072286195176   DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
06:20:13 T:18446744072286195176   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
06:20:13 T:18446744072286195176   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
06:20:13 T:18446744072286195176   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
06:20:13 T:18446744072286195176   DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
06:20:13 T:18446744072286195176   DEBUG: Radio UECP (RDS) Processor - new CDVDRadioRDSData::CDVDRadioRDSData()
06:20:13 T:18446744072286195176  NOTICE: DVDPlayer: Opening: /storage/udisk0/Insight_UHD_H265_50fps_4k_with_Dialogues.mkv
06:20:13 T:18446744072286195176 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
06:20:13 T:18446744072286195176   DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
06:20:13 T:18446744072286195176   DEBUG: LinuxRendererGL: Cleaning up GL resources
06:20:13 T:18446744072297407536   DEBUG: Thread DVDPlayer start, auto delete: false
06:20:13 T:18446744072297407536  NOTICE: Creating InputStream
06:20:13 T:18446744072297407536   DEBUG: static void CUtil::ScanForExternalSubtitles(const string&, std::vector<std::basic_string<char> >&): Searching for subtitles...
06:20:13 T:18446744072297407536   DEBUG: static void CUtil::ScanForExternalSubtitles(const string&, std::vector<std::basic_string<char> >&): END (total time: 12 ms)
06:20:13 T:18446744072297407536  NOTICE: Creating Demuxer
06:20:13 T:18446744072297407536   DEBUG: bool CDVDDemuxFFmpeg::Open(CDVDInputStream*, bool, bool) - probing detected format [matroska,webm]
06:20:13 T:18446744072297407536   DEBUG: bool CDVDDemuxFFmpeg::Open(CDVDInputStream*, bool, bool) - avformat_find_stream_info starting
06:20:13 T:18446744072297407536   DEBUG: bool CDVDDemuxFFmpeg::Open(CDVDInputStream*, bool, bool) - av_find_stream_info finished
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]: Input #0, matroska,webm, /storage/udisk0/Insight_UHD_H265_50fps_4k_with_Dialogues.mk':
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:   Metadata:
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:     encoder         : libebml v1.3.3 + libmatroska v1.4.4
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:     creation_time   : 2015-11-04 20:31:16
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:   Duration: 00:03:59.69, start: 0.000000, bitrate: 18516 kb/s
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:     Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv), 3840x2160, SAR 1:1 DAR 16:9, 50 fps, 50 tbr, 1k tbn, 50 tbc (default)
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       BPS             : 18411320
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       BPS-eng         : 18411320
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       DURATION        : 00:03:58.520000000
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       DURATION-eng    : 00:03:58.520000000
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       NUMBER_OF_FRAMES: 11838
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       NUMBER_OF_FRAMES-eng: 11838
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       NUMBER_OF_BYTES : 548933515
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       NUMBER_OF_BYTES-eng: 548933515
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       _STATISTICS_WRITING_APP: mkvmerge v8.5.1 ('Where you lead I will follow') 64bit
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       _STATISTICS_WRITING_APP-eng: mkvmerge v8.5.1 ('Where you lead I will follow') 64bit
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       _STATISTICS_WRITING_DATE_UTC: 2015-11-04 20:31:16
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       _STATISTICS_WRITING_DATE_UTC-eng: 2015-11-04 20:31:16
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:     Stream #0:1(ger): Audio: mp2, 48000 Hz, stereo, s16p, 192 kb/s (default)
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       BPS             : 192000
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       BPS-eng         : 192000
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       DURATION        : 00:03:58.248000000
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       DURATION-eng    : 00:03:58.248000000
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       NUMBER_OF_FRAMES: 9927
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       NUMBER_OF_FRAMES-eng: 9927
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       NUMBER_OF_BYTES : 5717952
06:20:13 T:18446744072297407536    INFO: ffmpeg[ABD46430]:       NUMBER_OF_BYTES-eng: 5717952
06:20:13 T:18446744072297407536   DEBUG: CDVDDemuxFFmpeg::AddStream(0, ...) -> 0
06:20:13 T:18446744072297407536   DEBUG: CDVDDemuxFFmpeg::AddStream(1, ...) -> 1
06:20:13 T:18446744072297407536  NOTICE: Opening stream: 0 source: 256
06:20:13 T:18446744072297407536  NOTICE: Creating video codec with codec id: 1211250229
06:20:13 T:18446744072297407536   DEBUG: CDVDFactoryCodec: compiled in hardware support: AMCodec:yes MediaCodec:yes OpenMax:no libstagefright:no VDPAU:no VAAPI:no iMXVPU:no MMAL:no
06:20:13 T:18446744072297407536   DEBUG: FactoryCodec - Video: amcodec - Opening
06:20:13 T:18446744072297407536    INFO: CBitstreamConverter::Open bitstream to annexb init
06:20:13 T:18446744072297407536   DEBUG: SECTION:LoadDLL(libamplayer.so)
06:20:13 T:18446744072297407536   DEBUG: Loading: /system/lib/libamplayer.so
06:20:13 T:18446744072297407536    INFO: DVDVideoCodecAmlogic: Opened Amlogic Codec
06:20:13 T:18446744072297407536   DEBUG: FactoryCodec - Video: am-h265 - Opened
06:20:13 T:18446744072297407536  NOTICE: Creating video thread
06:20:13 T:18446744072301491400   DEBUG: Thread DVDPlayerVideo start, auto delete: false
06:20:13 T:18446744072297407536  NOTICE: Opening stream: 1 source: 256
06:20:13 T:18446744072301491400  NOTICE: running thread: video_thread
06:20:13 T:18446744072297407536  NOTICE: Finding audio codec for: 86016
06:20:13 T:18446744072297407536   DEBUG: FactoryCodec - Audio: passthrough - Opening
06:20:13 T:18446744072297407536   DEBUG: FactoryCodec - Audio: passthrough - Failed
06:20:13 T:18446744072297407536   DEBUG: FactoryCodec - Audio: FFmpeg - Opening
06:20:13 T:18446744072297407536   DEBUG: FactoryCodec - Audio: FFmpeg - Opened
06:20:13 T:18446744072297407536  NOTICE: Creating audio thread
06:20:13 T:18446744072303889888   DEBUG: Thread DVDPlayerAudio start, auto delete: false
06:20:13 T:18446744072297407536   DEBUG: bool CEdl::ReadEditDecisionLists(const string&, float, int) - Checking for edit decision lists (EDL) on local drive or remote share for: /storage/udisk0/Insight_UHD_H265_50fps_4k_with_Dialogues.mkv
06:20:13 T:18446744072303889888  NOTICE: running thread: CDVDPlayerAudio::Process()
06:20:13 T:18446744072301491400   DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
06:20:13 T:18446744072303889888   DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_SYNCHRONIZE
06:20:13 T:18446744072297407536   DEBUG: virtual void CApplication::OnPlayBackStarted(): play state was 1, starting 1
06:20:13 T:18446744072297407536   DEBUG: CDVDPlayer::SetCaching - caching state 3
06:20:13 T:18446744072286195176   DEBUG: PlayBackRet CApplication::PlayFile(const CFileItem&, bool): OpenFile succeed, play state 2
06:20:13 T:18446744072286195176   DEBUG: virtual void CApplication::OnPlayBackStarted(): play state was 2, starting 0
06:20:13 T:18446744072301491400   DEBUG: CAMLCodec::SetSpeed, speed(0)
06:20:13 T:18446744072303889888  NOTICE: Creating audio stream (codec id: 86016, channels: 2, sample rate: 48000, no pass-through)
06:20:13 T:18446744072303889888   DEBUG: CDVDPlayerAudio:: synctype set to 0: clock feedback
06:20:13 T:18446744072301491400   DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_RESYNC(1171000.000000, 0)
06:20:13 T:18446744072301491400    INFO: CDVDPlayerVideo - Stillframe left, switching to normal playback
06:20:13 T:18446744072301491400   DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 0
06:20:13 T:18446744072301491400   DEBUG: static int CAndroidFeatures::GetVersion(): android.os.Build.VERSION 22
06:20:13 T:18446744072301491400   DEBUG: CAMLCodec::OpenDecoder, android version 22
06:20:13 T:18446744072301491400   DEBUG: codecid_to_vformat, id(1211250229) -> vformat(11)
06:20:13 T:18446744072301491400   DEBUG: codec_tag_to_vdec_type, codec_tag(1211250229) -> vdec_type(15)
06:20:13 T:18446744072301491400   DEBUG: CAMLCodec::OpenDecoder hints.width(3840), hints.height(2160), hints.codec(1211250229), hints.codec_tag(0), hints.pid(0)
06:20:13 T:18446744072301491400   DEBUG: CAMLCodec::OpenDecoder hints.fpsrate(50), hints.fpsscale(1), hints.rfpsrate(50), hints.rfpsscale(1), video_rate(1920)
06:20:13 T:18446744072301491400   DEBUG: CAMLCodec::OpenDecoder hints.aspect(1.777778), video_ratio.num(1), video_ratio.den(1)
06:20:13 T:18446744072301491400   DEBUG: CAMLCodec::OpenDecoder hints.orientation(0), hints.forced_aspect(1), hints.extrasize(141)
06:20:13 T:18446744072286563368    INFO: CActiveAESink::OpenSink - initialize sink
06:20:13 T:18446744072286563368   DEBUG: CActiveAESink::OpenSink - trying to open device AUDIOTRACK:AudioTrack
06:20:14 T:18446744072301491400   DEBUG: CAMLCodec::SetSpeed, speed(1000)
06:20:14 T:18446744072300835520   DEBUG: Thread CAMLCodec start, auto delete: false
06:20:14 T:18446744072300835520   DEBUG: CAMLCodec::Process Started
06:20:14 T:18446744072301491400   DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 0
06:20:14 T:18446744072301491400   DEBUG: Previous line repeats 16 times.
06:20:14 T:18446744072301491400   DEBUG: DVDVideoCodecAmlogic: detected new framerate(25.000000), video_rate(3840)
06:20:14 T:18446744072301491400   DEBUG: DVDVideoCodecAmlogic: detected new framerate(50.000000), video_rate(1920)
06:20:14 T:18446744072301491400   DEBUG: Previous line repeats 1 times.
06:20:15 T:18446744072303889888   DEBUG: Previous line repeats 27 times.
06:20:15 T:18446744072303889888   ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
06:20:15 T:18446744072301491400  NOTICE:  fps: 50.000000, pwidth: 3840, pheight: 2160, dwidth: 3840, dheight: 2160
06:20:15 T:18446744072301491400   DEBUG: int CDVDPlayerVideo::OutputPicture(const DVDVideoPicture*, double) - change configuration. 3840x2160. framerate: 50.00. format: BYPASS
I've never seen this error application once
