2017-01-23, 08:26
2017-01-23, 09:40
AeonMQ7 with latts's holiday mod.
2017-02-23, 21:14
That looks really good, a well thought out layout which I will try to emulate.
I have the Marantz 7010 and am looking to replace my Mede8er 600 with the Asrock Beebox-S i5-7200U which be a similar system to yours.
I didn't want to replace the Mede8er but as you probably discovered recently, you need the power for the latest movies.
Keep up the excellent work you are doing in the KODI forums.
John
John
2017-02-24, 16:56
(2017-02-23, 21:14)JohnWB Wrote: [ -> ]That looks really good, a well thought out layout which I will try to emulate.
John
Thanks for compliments
Don't forget to put pictures of build once its done.
2017-02-25, 12:40
(2017-02-24, 16:56)movie78 Wrote: [ -> ](2017-02-23, 21:14)JohnWB Wrote: [ -> ]That looks really good, a well thought out layout which I will try to emulate.
John
Will do
2017-03-04, 18:57
Did you make your own projector screen? you have a building blog for it?
2017-03-05, 19:34
(2017-03-04, 18:57)Skank Wrote: [ -> ]Did you make your own projector screen? you have a building blog for it?
Try this thread
2017-03-10, 16:25
Very nice,
So you have led light at the back too?
So its zero edge? So cool?
How is picture quality comparing to my screen now : kingpin vfs210 16:9? (https://www.kingpinscreens.nl/velvet-frame-screen)
Is it as good ? even better?
I want a bigger screen, but those kingpin screens have huge borders (8cm), so an edgeless screen gives me the possibilty to go larger... however. edgesless screens are expensive.
Might do a DIY screen edgelesse like yours but then +- 100 inch... if its douable and not too expensive..
How much did you spend?
2017-03-13, 15:11
(2017-03-10, 16:25)Skank Wrote: [ -> ]Very nice,
So you have led light at the back too? Yes
So it's zero edge? So cool? Edgeless much better, just like the movie theater
How is picture quality comparing to my screen now: kingpin vfs210 16:9? (https://www.kingpinscreens.nl/velvet-frame-screen)
Is it as good? even better? I like the edgeless because it give more real estate and movie theater feel
I want a bigger screen, but those kingpin screens have huge borders (8cm), so an edgeless screen gives me the possibility to go larger... however. edgeless screens are expensive.
Might do a DIY screen edgeless like yours but then +- 100 inch... if it's doable and not too expensive.
How much did you spend? The Spandex material cost me about $50 and the wood and accessories about $50 I would say a total of $100
With Spandex screen it allows you to put your front LCR behind the screen and gives you more theater feel because the sound would be coming from the screen.
2017-04-05, 03:23
very nice my friend ,I need to get a 65 inch LG TVHD 4K,and I have a dreamlink hd receiver also I havejynxbox hd.
2017-04-17, 13:26
Hello
2017-06-05, 09:48
That is a beautiful setup you got OP. Looking at those seats, i feel like getting a blanket putting on my favorite movie and just snuggle in.
2017-12-13, 10:40
(2017-01-22, 23:41)movie78 Wrote: [ -> ]New Place SetupNice one!!
Very small living Room but I was able to set up a 5.1.4 Atmos/DTS:X configuration.
PRESENTATIONPOLK OMW3MEDIA EQUIPEMENTSMARANTZ 7011/CABLE BOXPOLK OMW3&DEFTECH SR8040AeonMQ7 W/@latts's Krypton MOD
I notice in your signature you have the same Beebox as me.
You are running Kodi right? Have you been able to get 3D
working? I can't seem to get it working. I have ripped the files correctly.
They just won't play in 3D. Do you know where I could get help with this?
2017-12-13, 15:52
(2017-12-13, 10:40)Luke02 Wrote: [ -> ]For 3D to work on the Beebox you need two things.(2017-01-22, 23:41)movie78 Wrote: [ -> ]New Place SetupNice one!!
1-Make you are connected to the HDMI 1.4 conectoron the Beebox and 1080p/30 or 60hz then 3D enable in the video driver settings
2-Follow @hdmkv thread to complete your setup.3D MVC
