ush285t Wrote:The iplayer plugin seems to crash on my XBMC build with an undefined name error. See debug log - http://pastebin.com/m6a626e6b.
Ta, just fixed the bug which causes this output - but this won't fix the problem you've having. It should have output "Can't find iplayer library - are you sure you installed the plugin correctly?" if that helps
Please make sure you have a 'lib' directory in 'plugins\video\xbmc-iplayer-plugin', as it looks like you extracted the plugin incorrectly and missed most the files! (or they extracted into the wrong place)
Also, just a heads-up the latest release now has fixed support for the A-Z listings and is slightly quicker (temporarily turned off URL resolving until I get a chance to fix it properly)
Just for info' - all seems to be working fine for me now (same version of plugin and XBMC). I thought it would turn out to be a memory issue as the only difference is I hadn't turned on my NAS drive so no SMB connections were live.
But turned NAS on - browsed Movies and Music on NAS drive and then relaunched Iplayer and it still works!!? PLS note I always checked ISP connection before by trying ITV catchup plugin and that always streamed faultlessly.
Anyway all's well that ends well?!
Cheers again Johnsto
The new version doesn't work for me it doesnt even load up the listing here is my log i am on xbox.
the version before hand worked fine though at the end of a program it pauses then if you press A it will start then crash the xbox. (doesnt crash the xbox but the controller no longer works)
23:01:50 M: 57630720 NOTICE: -----------------------------------------------------------------------
23:01:50 M: 57610240 NOTICE: Starting XBMC, Platform: Xbox. Built on Oct 6 2008
23:01:50 M: 57610240 NOTICE: Q is mapped to: C:\Dashboard
23:01:50 M: 57610240 NOTICE: The executable running is: C:\Dashboard\Dashboard.xbe
23:01:50 M: 57610240 NOTICE: Log File is located: Q:\xbmc.log
23:01:50 M: 57610240 NOTICE: -----------------------------------------------------------------------
23:01:50 M: 57610240 NOTICE: Unmapped drive T
23:01:50 M: 57589760 NOTICE: Mapping drive T to Harddisk0\Partition2\Dashboard\UserData
23:01:50 M: 57589760 NOTICE: Setup DirectX
23:01:50 M: 57565184 NOTICE: Mapping drive C to Harddisk0\Partition2
23:01:50 M: 57565184 NOTICE: Mapping drive E to Harddisk0\Partition1
23:01:50 M: 57565184 NOTICE: Unmapped drive D
23:01:50 M: 57565184 NOTICE: Mapping drive D to Cdrom0
23:01:51 M: 57565184 NOTICE: Mapping drive F to Harddisk0\Partition6
23:01:51 M: 57565184 NOTICE: Mapping drive X to Harddisk0\Partition3
23:01:51 M: 57565184 NOTICE: Mapping drive Y to Harddisk0\Partition4
23:01:51 M: 57565184 NOTICE: Unmapped drive Z
23:01:51 M: 57565184 NOTICE: Mapping drive Z to Harddisk0\Partition5
23:01:51 M: 57561088 NOTICE: load settings...
23:01:51 M: 57561088 NOTICE: Mapping drive P to Harddisk0\Partition2\Dashboard\UserData
23:01:51 M: 57561088 NOTICE: loading T:\guisettings.xml
23:01:51 M: 56721408 NOTICE: Getting hardware information now...
23:01:51 M: 56700928 NOTICE: Checking resolution 1
23:01:51 M: 56537088 NOTICE: Getting hardware information now...
23:01:51 M: 56516608 NOTICE: Checking resolution 1
23:01:51 M: 56516608 NOTICE: Per AV pack settings are on
23:01:51 M: 56516608 NOTICE: HDTV found : loading T:\avpacksettings.xml
23:01:51 M: 56422400 NOTICE: Getting hardware information now...
23:01:51 M: 56422400 NOTICE: Checking resolution 1
23:01:51 M: 57344000 NOTICE: q:\UserData\sources.xml
23:01:51 M: 46747648 ERROR: Window Translator: Can't find window xlinkkai
23:01:51 M: 46858240 NOTICE: Checking the Date!
23:01:51 M: 46874624 NOTICE: start dvd mediatype detection
23:01:51 M: 46809088 NOTICE: initializing playlistplayer
23:01:51 M: 46809088 NOTICE: DONE initializing playlistplayer
23:01:51 M: 46809088 NOTICE: setting fanspeed
23:01:51 M: 46800896 NOTICE: load default skin:[MediaStream]
23:01:52 M: 41598976 ERROR: Window Translator: Can't find window settingscategory
23:01:52 M: 41578496 ERROR: Error evaluating boolean expression !Window.Previous(0) + !Window.Previous(SettingsCategory) + !Window.Previous(1001) + !Window.Previous(130) + !Window.Previous(34)
23:01:53 M: 40120320 NOTICE: use DHCP
23:01:53 M: 39804928 NOTICE: Updating video library on startup
23:01:53 M: 39280640 NOTICE: initialize done
23:01:53 M: 39239680 NOTICE: Running the application...
23:01:55 M: 34992128 NOTICE: start timeserver client
23:01:55 M: 34926592 NOTICE: Webserver: Starting...
23:01:55 M: 34848768 NOTICE: XBFileZilla: Starting...
23:01:55 M: 34775040 NOTICE: Webserver: Started
23:01:55 M: 34426880 NOTICE: ES: Starting event server
23:01:55 M: 33366016 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
23:01:55 M: 33304576 NOTICE: UDP: Listening on port 9777
23:01:55 M: 32575488 NOTICE: XBFileZilla: Started
23:02:03 M: 32825344 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://192.168.1.2/media/videos/TV%20Shows/Heroes%20Season%203'
unix_err:'2' nt_err : 'c0000034' error : 'NT_STATUS_OBJECT_NAME_NOT_FOUND'
23:02:04 M: 32825344 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://192.168.1.2/media/videos/TV%20Shows/Smallville%20Season%208'
23:02:05 M: 32825344 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://192.168.1.2/media/videos/TV%20Shows/Stargate%20Atlantis%20Season%205'
23:02:06 M: 32825344 ERROR: SMBDirectory->GetDirectory: Unable to open directory : 'smb://192.168.1.2/media/videos/TV%20Shows/The%20Sarah%20Connor%20Chronicles%20Season%202'
23:02:07 M: 32829440 NOTICE: My Videos: Scanning for video info using worker thread, operation took 00:14
23:02:19 M: 35479552 WARNING: DIRECTORY::CVideoDatabaseDirectory::GetLabel - Unknown nodetype requested 6
23:02:23 M: 34971648 ERROR: Unable to load: Q:\plugins\video\xbmc-iplayer-plugin\resources\settings.xml, Line 0
Error document empty.
23:02:23 M: 32579584 NOTICE: -->Python Initialized<--
23:02:26 M: 27738112 NOTICE: iplayer2 logging to stdout
23:02:26 M: 27738112 NOTICE: Q:\plugins\video\xbmc-iplayer-plugin\iplayer_cache doesn't exist, creating
23:02:26 M: 27738112 NOTICE: ['plugin://video/xbmc-iplayer-plugin/', '0', '']
23:02:26 M: 27738112 NOTICE: Traceback (most recent call last):
23:02:26 M: 27738112 NOTICE: File "Q:\plugins\video\xbmc-iplayer-plugin\default.py", line 266, in ?
23:02:26 M: 27738112 NOTICE: timeout = int(xbmcplugin.getSetting('sockettimeout'))
23:02:26 M: 27738112 NOTICE: ValueError
23:02:26 M: 27738112 NOTICE: :
23:02:26 M: 27738112 NOTICE: invalid literal for int():
23:02:26 M: 27738112 ERROR: Scriptresult: Error
23:02:26 M: 28262400 NOTICE: .
23:02:26 M: 34963456 ERROR: CGUIMediaWindow::GetDirectory(plugin://video/xbmc-iplayer-plugin/) failed
23:02:26 M: 34951168 WARNING: DIRECTORY::CVideoDatabaseDirectory::GetLabel - Unknown nodetype requested 6
Whoops, sorry about that, think I've fixed it in the latest release.
Works for me now thank you.
And my daughter says thank you to
Cbeebies!!!!
Very grateful for all the work that's gone into this, thanks
unfortunately I've got 2 problems:
1. Is there any reason why i can't get program names? All i get are names like b000dv5d4streaming93655638. I've tried messing with the settings but it doesn't make any difference, any ideas?
2. When I try to watch a program it randomly fails to show the video but plays the audio... if i try to stop playing it, the xbox then hangs... log here:
http://pastebin.ca/1225233
I'm using beta2 on xbox.
thanks.
Hi, works great here also.
xbox, Beta 2, iplayer .....121223.zip.
Looking forward to the gloss being added to this brill plugin!
cromity123 Wrote:1. Is there any reason why i can't get program names? All i get are names like b000dv5d4streaming93655638. I've tried messing with the settings but it doesn't make any difference, any ideas?
Those names are the filenames from the URL (e.g.
http://www.some_site.com/blah/b000dv5d4s...ng93655638), which suggests you do have a setting somewhere to show filenames rather than titles. Not sure where though
I'm suffering from the same problem, both the xbox's in the house display all the program names like that, was hoping someone knew the cure
Old and no longer relevant perhaps, but you may remember myself and some others being unable to locate the iplayer.log file.
When recently upgrading an application on my Mac, I discovered an iplayer.log file in the main Applications directory, that is
/Applications/
This is where Plex (and XBMC) reside. So previously your plugin was (incorrectly) creating the log file in the same location as the application. Standard log file locations on a Mac (which as a reminder is a Unix based operating system) are
/Library/Logs/
/var/log/
/Users/username/Library/Logs/
I believe you switched to using the standard xbmc.log (or plex.log) so this no longer applies. Those logs are located in
which is what I believe would be the most appropriate location for your iplayer.log
... just thought you might like to know the answer to one mystery.
Manicfodder Wrote:I'm suffering from the same problem, both the xbox's in the house display all the program names like that, was hoping someone knew the cure
Really not sure what's causing this, appears to be displaying URLs rather than the title given. Will have a peek tonight.
jelockwood Wrote:... just thought you might like to know the answer to one mystery.
Ta, yep, or now it just writes to xbmc.log if it can't create iplayer2.log in the cwd. So you may still find iplayer2.log in your Apps folder...
...unless I fix/change it
"Looking forward to the gloss being added to this brill plugin!"
Will there be any
will it ever look like it did as a script? looked DAM good then!
