There should be another speed improvement in the latest release - HTTP caching is enabled now and thumbnail downloads are using the same method.
Hi Johnsto,
Just tried the new version. Much much faster! :-)
On small bug though. The programme names are all garbled though: b000bm3zc..... etc.
Still, overall this is fantastic. Nice work.
Hi Johnsto,
Still having trouble with random hangs when starting some progs, annoying thing is it's intermittent, sometimes a particular prog will play but other times the sound will start playing but no picture, Xbox then eventually hangs and have to turn it off. Seems to happen about 50% of the time...Other 50% of time works really well!
Can't work out any pattern, and tried using Wii/vp6 streams but happens with both. I've linked a log file from when it hangs, in the hope it might mean something! Anyway cheers for any help you can offer!
http://pastebin.ca/1228798
Is it possible to have this run from a button with a command like
XBMC.RunPlugin(plugin://video/BBC iplayer/default.py)
as it doesn't work i get this in the log
23:23:29 M: 28352512 ERROR: Unable to load: Q:\plugins\video\BBC iplayer\default.py\resources\settings.xml, Line 0
Failed to open file
23:23:29 M: 28352512 ERROR: Unable to run plugin Q:\plugins\video\BBC iplayer\default.py\default.py
use activatewindow, runplugin is specific for items that actually play media not display a list.
Thanks to all involved with this great plugin.
Big up to Johnsto and frosty.
Rocky5 Wrote:Brilliant thank you.
<onclick>XBMC.ActivateWindow(24,plugin://video/BBC iplayer/)</onclick>
Hi Rocky,
I you have created a skin wih an Iplayer button, would you care to share? ;-)
Could someone post a link to a tutorial on how to get the iplayer working on my xbmc. I have been searching but not found anything that helps.
Thanks Gav
frumpy_uk Wrote:Assuming your XBMC has a working internet connection, and you have downloaded the latest version of the plugin, follow this http://forum.xbmc.org/showthread.php?tid=30351
Good luck
Thanks for the link.
so far when I click on the iplayer symbol in the video section it says-
Remote Share
Could not connect to network server.
Even though I can watch youtube in scripts.
Also stream videos from my pc when clicking on "workgroup (smb) network.
ashlartowers Wrote:Hi Rocky,
No i just changed videos in MediaStream to BBC Iplayer as i use library mode and this menu is not needed and also iplayer doesn't work in library mode so this way its launched in video mode and you get all the correct names.
