Full Version: [REQUEST] BBC iPlayer (Video) Plugin or Script?
Strawp Wrote:Oh wow, I thought this thread had died long ago!
So I don't have to trawl through all these pages, what's the status? Do you have a working iPlayer script for XBMC on XBox?
It works on XBox, Windows & Linux using flash vp6 video. XBMC doesn't yet support h.264 over rtmp:// but hopefully will soon. The radio catchup side works well on XBox, not so well on Linux & Windows due to problems supporting rtsp://.
Cheers
Dink
Hi Folks
I've put a new version of the plugin up at http://drop.io/xbmcdink
This version allows Windows & Linux uses to play the Radio catchup streams.
Live radio streams still don't work on Windows and Linux (xbmc issues with mms:// and rtsp:// on these platforms).
In case your interested the catchup radio streams are mp3s, have a bitrate of 128k and use rtmp as the transport protocol.
Cheers
Dink
just tried iplayer from 26/04/09 downloaded from http://drop.io/xbmcdink , on my xbox. i extracted it to my video plugins folder and started it. it gets the thumbnails of the various programs but it gives an error when trying to play the actual video. am i doing something wrong or is it still not working?
Great release! This works for me on an Xbox with the latest T3CH release.
I tried a live radio stream, a couple of listen again streams and a TV stream. All seemed to work except when playing a listen again stream of Danny Baker on BBC London. Perhaps this is due to it being in real audio?
any idea what might be wrong here? newest t3ch release (april 23), uses mplayer as default video player, but it gives an error that it doesnt locate the flash stream. help, anyone?
Johnnyfive Wrote:Great release! This works for me on an Xbox with the latest T3CH release.
I've made a minor mod 2009-04-26B that falls back on real if it can't find the mp3 stream.
Cheers
Dink
gilsil Wrote:any idea what might be wrong here? newest t3ch release (april 23), uses mplayer as default video player, but it gives an error that it doesnt locate the flash stream. help, anyone?
Sorry not enough info can you post a log. Look for a xbmc.log file under the directory where XBMC is installed on your xbox (e:\xbmc e:\apps\xbmc) and paste it onto http://pastebin.com/
Cheers
Dink
There was some talk a few weeks/1month ago about getting the HQ streams added into the SVN. (i havent updated in a while) - do we have the HQ streams available now?
thanks
PantsOnFire Wrote:There was some talk a few weeks/1month ago about getting the HQ streams added into the SVN. (i havent updated in a while) - do we have the HQ streams available now?
thanks
Not quite there yet. There is a couple of patches from Frosty that need to go into SVN http://xbmc.org/ticket/5548 which should (fingers crossed) sort out the remaining issues with video "jerkyness". The plugin itself is all ready to go, with the latest drop you can change the video stream to one of the h.264 streams. It just won't work very well yet.
Cheers
Dink
That fixes it. Thanks for the quick response.
has anyone got this working through a http proxy?
Thanks to all the plugin contributors.
Working for me as well, thanks.
dink Wrote:Sorry not enough info can you post a log. Look for a xbmc.log file under the directory where XBMC is installed on your xbox (e:\xbmc e:\apps\xbmc) and paste it onto http://pastebin.com/
Cheers
Dink
thanks Dink,
here is the log file:
http://pastebin.com/m73f11790
it is the first one i actually looked at so i dont know what it means, and what are the errors, but i tried to play a few video streams using the Iplayer plugin, without success. thanks for any help!
gilsil Wrote:thanks Dink,
The plugin is failing at the point were it is requesting the media selector xml file. I've seen someone else with this problem in the past. It turned out that the BBC had misidentified their IP address as non UK. An easy test for this is to use a PC on the same broadband connection, navigate to the IPlayer website and see if you can play a video.
Cheers
Dink
I tried this from the US http://www.xroxy.com/proxy-country-GB.htm but iplayer/py just returned an error after I enabled http proxy....Huh
