Hi everyone!
I tried linux xbmc some weeks ago and it started, but back then there was no videoplayback. So after i saw the new screenshots I wanted to try it again but after checking out and compiling I get the following error trying to run xbmc.
X Error of failed request: BadPixmap (invalid Pixmap parameter)
Major opcode of failed request: 1 (X_CreateWindow)
Resource id in failed request: 0xb7f7eff4
Serial number of failed request: 14
Current serial number in output stream: 15
System is running ubuntu edgy and the log stopped at Setup SDL.
Any ideas what the problem could be?
the least you could have mentioned is what gfx adapter it is that you have
but we will probably require alot more info to be able to give an intelligent answer
I know it needs more info and but i thought maybe someone else had a similar problem and thus it could be easily solved.
Its not that important and i think you have better things to do but anyway here is more information:
i have a geforce 6800, driver ver 1.0.8776
import stuff from xorg.conf
Quote:...
Load "glx"
Load "dri"
Load "vbe"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "extmod"
Load "type1"
Load "freetype"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes "1280x1024, 1024x768, 800x600, 640x480"
EndSubSection
glxinfo:
Quote:name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGI_video_sync, GLX_SGI_swap_control,
GLX_ARB_multisample, GLX_NV_float_buffer, GLX_ARB_fbconfig_float
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_SGI_video_sync,
GLX_NV_swap_group, GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGI_swap_control, GLX_NV_float_buffer, GLX_ARB_fbconfig_float
GLX version: 1.3
GLX extensions:
GLX_ARB_multisample, GLX_NV_float_buffer, GLX_ARB_fbconfig_float,
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce 6800/AGP/SSE/3DNOW!
OpenGL version string: 2.0.2 NVIDIA 87.76
OpenGL extensions:
GL_ARB_color_buffer_float, GL_ARB_depth_texture, GL_ARB_draw_buffers,
GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
GL_ARB_fragment_shader, GL_ARB_half_float_pixel, GL_ARB_imaging,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_shadow, GL_ARB_shader_objects, GL_ARB_shading_language_100,
GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3, GL_ARB_texture_float,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_rectangle, GL_ARB_transpose_matrix,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_window_pos, GL_ATI_draw_buffers, GL_ATI_texture_float,
GL_ATI_texture_mirror_once, GL_S3_s3tc, GL_EXT_texture_env_add,
GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
GL_EXT_Cg_shader, GL_EXT_depth_bounds_test, GL_EXT_draw_range_elements,
GL_EXT_fog_coord, GL_EXT_framebuffer_object, GL_EXT_multi_draw_arrays,
GL_EXT_packed_depth_stencil, GL_EXT_packed_pixels,
GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_texture3D,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_lod, GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
GL_EXT_texture_object, GL_EXT_texture_sRGB, GL_EXT_timer_query,
GL_EXT_vertex_array, GL_HP_occlusion_test, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_KTX_buffer_region, GL_NV_blend_square,
GL_NV_copy_depth_to_color, GL_NV_depth_clamp, GL_NV_fence,
GL_NV_float_buffer, GL_NV_fog_distance, GL_NV_fragment_program,
GL_NV_fragment_program_option, GL_NV_fragment_program2,
GL_NV_gpu_program_parameters, GL_NV_half_float, GL_NV_light_max_exponent,
GL_NV_multisample_filter_hint, GL_NV_occlusion_query,
GL_NV_packed_depth_stencil, GL_NV_pixel_data_range, GL_NV_point_sprite,
GL_NV_primitive_restart, GL_NV_register_combiners,
GL_NV_register_combiners2, GL_NV_texgen_reflection,
GL_NV_texture_compression_vtc, GL_NV_texture_env_combine4,
GL_NV_texture_expand_normal, GL_NV_texture_rectangle,
GL_NV_texture_shader, GL_NV_texture_shader2, GL_NV_texture_shader3,
GL_NV_vertex_array_range, GL_NV_vertex_array_range2, GL_NV_vertex_program,
GL_NV_vertex_program1_1, GL_NV_vertex_program2,
GL_NV_vertex_program2_option, GL_NV_vertex_program3,
GL_NVX_conditional_render, GL_SGIS_generate_mipmap, GL_SGIS_texture_lod,
GL_SGIX_depth_texture, GL_SGIX_shadow, GL_SUN_slice_accum
glu version: 1.3
glu extensions:
GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x21 24 tc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 0 0 None
0x22 24 dc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 0 0 None
0x23 24 tc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 0 0 None
0x24 24 tc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 0 0 None
0x25 24 tc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 0 0 None
0x26 24 tc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 0 0 None
0x27 24 tc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 0 0 None
0x28 24 tc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 0 0 None
0x29 24 tc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 0 0 None
0x2a 24 tc 0 32 0 r y . 8 8 8 0 4 16 0 16 16 16 16 0 0 None
0x2b 24 tc 0 32 0 r y . 8 8 8 8 4 16 0 16 16 16 16 0 0 None
0x2c 24 tc 0 32 0 r . . 8 8 8 0 4 16 0 16 16 16 16 0 0 None
0x2d 24 tc 0 32 0 r . . 8 8 8 8 4 16 0 16 16 16 16 0 0 None
0x2e 24 tc 0 32 0 r y . 8 8 8 0 4 0 0 16 16 16 16 0 0 None
0x2f 24 tc 0 32 0 r y . 8 8 8 8 4 0 0 16 16 16 16 0 0 None
0x30 24 tc 0 32 0 r . . 8 8 8 0 4 0 0 16 16 16 16 0 0 None
0x31 24 tc 0 32 0 r . . 8 8 8 8 4 0 0 16 16 16 16 0 0 None
0x32 24 tc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 2 1 Ncon
0x33 24 tc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 2 1 Ncon
0x34 24 tc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 4 1 Ncon
0x35 24 tc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 4 1 Ncon
0x36 24 tc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 2 1 Ncon
0x37 24 tc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 2 1 Ncon
0x38 24 tc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 4 1 Ncon
0x39 24 tc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 4 1 Ncon
0x3a 24 tc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 2 1 Ncon
0x3b 24 tc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 2 1 Ncon
0x3c 24 tc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 4 1 Ncon
0x3d 24 tc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 4 1 Ncon
0x3e 24 tc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 2 1 Ncon
0x3f 24 tc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 2 1 Ncon
0x40 24 tc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 4 1 Ncon
0x41 24 tc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 4 1 Ncon
0x42 24 tc 0 32 0 r y . 8 8 8 0 4 16 0 16 16 16 16 2 1 Ncon
0x43 24 tc 0 32 0 r y . 8 8 8 8 4 16 0 16 16 16 16 2 1 Ncon
0x44 24 tc 0 32 0 r y . 8 8 8 0 4 16 0 16 16 16 16 4 1 Ncon
0x45 24 tc 0 32 0 r y . 8 8 8 8 4 16 0 16 16 16 16 4 1 Ncon
0x46 24 tc 0 32 0 r . . 8 8 8 0 4 16 0 16 16 16 16 2 1 Ncon
0x47 24 tc 0 32 0 r . . 8 8 8 8 4 16 0 16 16 16 16 2 1 Ncon
0x48 24 tc 0 32 0 r . . 8 8 8 0 4 16 0 16 16 16 16 4 1 Ncon
0x49 24 tc 0 32 0 r . . 8 8 8 8 4 16 0 16 16 16 16 4 1 Ncon
0x4a 24 dc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 0 0 None
0x4b 24 dc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 0 0 None
0x4c 24 dc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 0 0 None
0x4d 24 dc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 0 0 None
0x4e 24 dc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 0 0 None
0x4f 24 dc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 0 0 None
0x50 24 dc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 0 0 None
0x51 24 dc 0 32 0 r y . 8 8 8 0 4 16 0 16 16 16 16 0 0 None
0x52 24 dc 0 32 0 r y . 8 8 8 8 4 16 0 16 16 16 16 0 0 None
0x53 24 dc 0 32 0 r . . 8 8 8 0 4 16 0 16 16 16 16 0 0 None
0x54 24 dc 0 32 0 r . . 8 8 8 8 4 16 0 16 16 16 16 0 0 None
0x55 24 dc 0 32 0 r y . 8 8 8 0 4 0 0 16 16 16 16 0 0 None
0x56 24 dc 0 32 0 r y . 8 8 8 8 4 0 0 16 16 16 16 0 0 None
0x57 24 dc 0 32 0 r . . 8 8 8 0 4 0 0 16 16 16 16 0 0 None
0x58 24 dc 0 32 0 r . . 8 8 8 8 4 0 0 16 16 16 16 0 0 None
0x59 24 dc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 2 1 Ncon
0x5a 24 dc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 2 1 Ncon
0x5b 24 dc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 4 1 Ncon
0x5c 24 dc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 4 1 Ncon
0x5d 24 dc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 2 1 Ncon
Install the latest Nvidia drivers from their site and try again.
I already tried that. Upgraded to 100.14.11, but still the same error.
Hi thomasmayer, I've noticed that error pop up occasionally. Usually just another launch attempt or a few more attempts fixes it. We're still tracking that one down. If you don't mind, could you give us details about your system configuration i.e. specs?
Edit: Also make sure you do a 'make clean ; make', just to be safe.
UPDATE: The bug was squashed in r9492.
Hi, I have a similar problem, maybe related to this.
I compiled XboxMediaCenter in a Debian SID environment, with the latest Nvidia drivers and Xorg 7.2. The compilation ended perfectly, but when I try to run XboxMediaCenter I get this:
X Error of failed request: BadValue (integer parameter out of range for operation)
Value in failed request: 0xc
My HW is a Core 2 Duo with a Gforce 7800GT.
If I could help in some way please let me know.
