Only thing that sucks is I may have to hire a professional contractor. Cutting 4x circles in ceiling and installing the speakers, no problem. Sending speaker wires from speakers to wall, no problem, as studs are going the right way, so can fish wires to wall. The problem is from ceiling to wall though wood supports, then across each vertical stud to closet where a/v rack is.
This is how my HT room looked pre-drywall...
It looks like you have a big tasks ahead of you, my wasn't too bad to install, run the cable in the attic then cut the speakers holes.
The in-ceiling speakers installation was pretty easy.
Wish they made wireless speakers
Did not even know about those type of wires existed..
PS: Are you going to Putty over it before painting?
Yes, so it doesn't look like this guy's
Looks good, but i think a little Putty will let blend well with the wall..
Decided to do it correctly... PITA, but will cut out holes in drywalls and wire the right way.
Ordered 8" Polks (RC80i) after going back and forth between several ceiling speakers.
(2016-04-25, 23:25)hdmkv Wrote: [ -> ]Decided to do it correctly... PITA, but will cut out holes in drywalls and wire the right way.
Once it's done right, you don't have to look back
And hopefully deadpool now
(2016-04-26, 14:57)Skank Wrote: [ -> ]And hopefully deadpool now
I hope Deadpool come in ATMOS or DTS:X in 3D, but chances are it will release in 4K only with DTS:X or ATMOS, at least that is what the trends are going these days
then we will miss out all atmos titles
For Deadpool i dont want 3d
dont htink it will fit it
